Motor controller and XY slider
Hello
I am new to arduino
i am working on XY slider with the help of stepper motors and arduino
i wrote a code which has fixed delay values which works
now i am trying to wrote the code with the help of serial monitor which ask me to enter the delay time but that is not working
Please help me as early as possible
as my project submission dates are closer
i am pasting the code as below
#define EN        8
//Direction pin
#define X_DIR     5
#define Y_DIR     6
//#define Z_DIR     7
//Step pin
#define X_STP     2
#define Y_STP     3
//#define Z_STP     4
//A4988
int delayTime=900; //Delay between each pause (uS)
int stps=2000 ;// Steps to move
int a,b,c,d,e;
//int steps=5000;//steps to move in reverse direction
int someArray[5];
 void step(boolean dir, byte dirPin, byte stepperPin, int steps)
  digitalWrite(dirPin, dir);
  delay(100);
  for (int i = 0; i < steps; i++) {
    digitalWrite(stepperPin, HIGH);
    delayMicroseconds(delayTime);
    digitalWrite(stepperPin, LOW);
  pinMode(X_DIR, OUTPUT); pinMode(X_STP, OUTPUT);
  pinMode(Y_DIR, OUTPUT); pinMode(Y_STP, OUTPUT);
 // pinMode(Z_DIR, OUTPUT); pinMode(Z_STP, OUTPUT);
  pinMode(EN, OUTPUT);
  //digitalWrite(EN, LOW);
  Serial.begin(9600) ;
Serial.println("Enter the number of iterations");
Serial.print(someArray[a]);
a=Serial.read();
Serial.println("Enter the Dipping time for first Precursor");
if(Serial.available()>=0)
Serial.print(someArray[b]);
Serial.println("Enter the Dipping time in distilled Water");
Serial.print(someArray[c]);
Serial.println("Enter the Dipping time in second Precursor");
Serial.print(someArray[d]);
Serial.print(someArray[e]);
for(int i=1; i<=a; i++)
step(false, X_DIR, X_STP, stps); //X, Clockwise
    b=Serial.read();
  delay(b); // dipping time in solution
  step(true, X_DIR, X_STP, stps); //X, Counterclockwise
  step(false, Y_DIR, Y_STP, stps); //Y, Clockwise
 c=Serial.read();
  delay(c); // dipping time in solution
 d=Serial.read();
  delay(d); // dipping time in solution
 e=Serial.read();
  delay(e); // dipping time in solution
step(true, Y_DIR, Y_STP, stps); //Y, Counterclockwise
step(true, Y_DIR, Y_STP, stps); //Y, Counterclockwise*/
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
stepper.ino (2.94 KB)
@kbchavan30, do not hijack. Thread split.
 a = Serial.read();
   if (Serial.available() >= 0)
Interesting, you read one byte from serial before you know if there is anything to read, then you check to see if anything is available but never read from the serial port after that. I am at a loss as to what you are actually doing there.
Have a look at the serial input basics thread for some ideas on how to read data from the serial port and how to build data packets.
There is a simple User Input example in Planning and Implementing a Program
...R
Thanks to all
i have modified the code.
but i think the value which i have entered in serial monitor are converted in to ASCII code
how to store the delay times which are in the form of integers, means suppose i entered 10 then it must store 10 only
NOT ASCII equivalent of 10
kbchavan30:
The parse example in Serial Input Basics shows how to deal with that.
...R
