Motor Sensor
Ok, so I found this little DC motor. 18VDC, 3450 RPM 0.075Amp. But it has what I think is an rpm counter mounted to the rear shaft.
It has a small circular plastic disk connected to the shaft. The disk is scribed with black lines and they pass through a bridge kind of thing that I think is a laser or led light/light sensor. I think it senses the interruptions in the light created by the scribed lines on the clear plastic disk.
So if my assumptions are correct, then I need to determine the outputs of this device. It is mounted to the motor with a PCB soldered to the + - pins of the motor. The PCB has 8 outputs. I assume two are for power, the other six must be for counting rpm/controlling the motor speed. I think I can trace the power easily enough with my multimeter.
So here's my question(s):
  1. First, what is a device of this type called? I cannot search for information without a proper name.
  2. How can I determine the function and limits of the remaining six inputs/outputs.
  3. What are the functions of the other outputs.
I know what I am asking is more of a "give me your best guess", but right now that's about all I can ask for until I have more information to do some searches or make some measurements.
Thanks.
Quadrature encoder?
Ok, Thanks. Actually an Optical Rotary Encoder. Your suggestion of quadature encoder lead me to the correct page.
Now I know what it is, maybe I can determine how to use it.
I have traced the power inputs to the two left most pins. That just leaves the other 6 pins.
Thanks.
OK,
Stand corrected. From what I have found it is a quadrature encoder. I have tracked the six pins as follows.
Pins 1, 2, 3, 4 are all connected together through the motor. I used an led to check and 1 and 2 seem to be positive, 3 and 4 negative.
There are three resistors, a 220 ohm and two 1.8K ohm. Pin 5 is connected to the 220, and one of the 1.8K. Pin 6 is connected to one of the 1.8 as is pin 7. Pin 8 is connected to a cap that is so small I can read the specs from the cap.
So I think the data leads are 5,6 and 7, but not sure what pin 8 is.
Any help on figuring this out would be appreciated. Can't find the data sheet for this thing.
So you've found the basic working principles of an optical quadrature encoder. You know that you need a light source (maybe two) and a photodiode or other light detector (definitely two.) Those components probably share a ground pin. The light needs power. The outputs will probably interface to a microcontroller pin at 0-5V or 0-3.3V.
Does that help to identify the connections?
MorganS:
I think so. Times like this I wish I had an O-Scope. I use an led to trace the motor connections, but I think one of them is actually the power for the sensor light(s). I just need to figure out which set of +/- actually run the motor and which run the light source. I'm thinking a 5V power supply connected to each set may give me the information I need. Then just a question of determining which of the other 4 leads are connected to the sensors.
Thanks.
