I am building a gear indicator for my motorcycle. My main problem is that sometimes the shiftings are quite fast so I want my code to be as fast as possible because 1 gear up can take lets say 0.1 seconds.
I know my arduino (Uno) is fast enough for this but I dont know if my code is.
I also have a clock on the screen and a temp sensor. Does this slows my code so much?
Also I got an issue with the neutral gear. Going from the 1st to the 2nd gear will activate neutral gear for a few miliseconds. I though about adding a delay before I activate the neutral but this will slow down my code and will also not be stable as I cant be sure in puting 10ms or 100ms.
Note for gear I use 2 hall sensors. For the neutral I ll get the signal from the "neutral led" of the motorcycle.
Here is the main code. I would love any suggestions as I am still a newbie.
If you ve ever drive a motorcycle with clutch you should know what I am looking for about the "neutral".
Only about 750,000 miles in the last 30 years. Yes, the neutral light flashes going from 1st to 2nd, and from 2nd to 1st. But, so what? Showing Gear 1, Neutral, Gear 2 on the LCD will be accurate. Why do you want to show something else?
you could be a bit more polite next time
And you could indent your code properly, and comment it, before posting it. You could not take exception to the fact that code needs to look neat.
+1 when I push the shift "up"
-1 when I push the shift "down"
if you push from 0 to 1st gear the indicator would be -1 (easy to solve)
if you push from 1st gear to second and the "gear" value becomes mementary 0 the indicator will show "1" insted of "2".
Thats why I need to "stay" a bit more on the neutral to confirm that the gear is really on neutral and not just "pass" from there.
I said from the start of the topic that I am a newbie so I think that there are thousands of ways to do this better and there will be obviously mistakes on my code (otherwise I would post it here).
I can up-shift from 1st to neutral or from 1st to 2nd. I presume that you can, too.
The key to knowing whether the up-shift was to neutral or to 2nd depends on how the hall-effect sensors are positioned. You have not explained that.
If the neutral light is not on, you must be in some gear. If you were in first, you shifted, and the neutral light is not on, then there is only one possibility.
PaulS:
yeah BUT...sometimes when I change from 1st to second the neutral light flashed momentary. So ,acording to my "idea", the momment that the ligh will flash the gear will go to "0" so the "up shift" will go to 1 instead of 2.
I think I have to think about a completely different code that this...
I use 2 hall sensors placed on the shift. One to determine the "up" and a second for the "down".
If the sensors are not placed so that you can tell the difference between shifting part way (to neutral) vs. all the way (to 2nd), then the sensors are not well positioned.
I like the idea of what you are doing, but apparently it is not all that easy. My Harley lights up an indicator when it is in neutral and another when it is in 6th. No other gear positions are shown.
My Aspencade showed what gear it was in, for every gear.
PaulS:
Well...I only need a way (if possible) to delay the input from the neutral...If I can do this everything will run smooth.
I though about putting a relay with a delay of 0.5 seconds to get the signal for the neutral in order to not "slow" my code more.
I dont know if there is any other way to force my arduino "read" an input after some time...
Looks like I ll have to use my brain a bit more...
PS My Honda got an indicator for the Neutral only. My main aim is the clock, but adding a temperature and a gear indicator would be great!
Why is neutral light a problem? If you can accurately detect an upshift and a downshift of the gear lever, it's return to centre and the neutral light then internal to the code the gear numbers would go from -1 (first), 0 (neutral), 1 (second) and so on up to 5 (sixth). Just substitute these for gear numbers on the display.
If your in neutral and downshift it will be first gear. As you upshift, if the neutral light is still on when gear lever centres your back in neutral if the neutral light is not on then you must have moved through to second.
Resetting counter to zero if the neutral light comes on and gear lever is currently moved (off centre) then either increment or decrement counter when it returns to centre should work.
I had a Suzuki many many years ago with built in gear shift indicator but it never worked well as I could sometimes end up in 9th gear and that's hard to do with only 5 to start with.
