Hi. I want to control my mouse with gyroscope and accelerometer. I'll use bluetooth protocol for controlling mouse, but i'm not sure how to do that. I finished first part:calibrating and filtering.
I don't want to use bluetooth module rn-42(too expensive) and i think i need to build mouse driver.
Can i control my mouse directly by bluetooth or i need to buy bluetooth usb stick?
If the main issue is writing a PC Bluetooth/mouse driver/emulator, then I guess your post would be better under Interfacing w/ Software on the Computer
You should be able to achieve the same thing with more hardware, though, with the addition of, say, a Pro Micro and another Bluetooth module.
The Pro Micro would have a Bluetooth module (slave mode) and be connected to the PC via the USB interface. The Pro Micro can emulate a mouse etc. Link
Your gyroscope/accelerometer would be connected to another Arduino device and a bluetooth module (master mode) as you originally intended.
The Two Bluetooth devices would, of course, be linked.
6v6gt:
Thanks you very much. Seems to be logic what are you saying.
