Moving stepper moto with Photoresistor ad L298n
I'm trying to use a photoresistor to control a stepper motor but I don't know if I coded it correctly.
#include <Stepper.h>
// Number of steps per output rotation
const int analogPin = A0;
int lightValue = analogRead(A0);
const int stepsPerRevolution = 200;
// Create Instance of Stepper library
Stepper myStepper(stepsPerRevolution, 5, 6, 7, 8);
	// set the speed at 60 rpm:
	myStepper.setSpeed(60);
	// initialize the serial port:
if (lightValue < 300) {
	Serial.println("clockwise");
	myStepper.step(stepsPerRevolution);
} else if (lightValue>300) {
	// step one revolution in the other direction:
	Serial.println("counterclockwise");
	myStepper.step(-stepsPerRevolution);
You need read analog(A0) inside the loop to work.
  lightValue = analogRead(A0);      //  <<<<<<-------------
  } else if (lightValue > 300) {
Thanks you i will put that in when i have the chance.
After putting that line in it is only turning one direction.
Use this circuit and set the threshold to 512 (change 300 to 512)
