MPU6050 stops randomly
I'm building a robot that uses an MPU6050 module, it works perfectly fine for a bit and then suddenly stops. No output is being sent to the serial monitor, and everything freezes up. It seems like all code execution is stopped. But the thing is, this doesn't always happen the same time. It happens more randomly.
Here's my code:
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu;
double roll, pitch;
double rolld, pitchd;
double rollf, pitchf;
void setup(void) {
  pinMode(35,OUTPUT);
  pinMode(36,OUTPUT);
  pinMode(37,OUTPUT);
  pinMode(38,OUTPUT);
	// Try to initialize!
	if (!mpu.begin()) {
		Serial.println("Failed to find MPU6050 chip");
		while (1) {
		  delay(10);
	// set accelerometer range to +-8G
	mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
	// set gyro range to +- 500 deg/s
	mpu.setGyroRange(MPU6050_RANGE_500_DEG);
	// set filter bandwidth to 21 Hz
	mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
	delay(100);
  roll = 0;
  pitch = 0;
  pinMode(35,OUTPUT);
unsigned long currentTime = 0;
unsigned long dt = 0;
double dp;
double dr;
double pr;
double pp;
float k = 0.30; // Filtering constant
double ms = 0.25; // Motor microstep multiplier
int s1 = 0; // Motor speeds in RPM
int s2 = 0;
  dp = pitch - pp;
  dr = roll - pr;
  pp = pitch;
  pr = roll;
	/* Get new sensor events with the readings */
  dt = millis() - currentTime;
	sensors_event_t a, g, temp;
	mpu.getEvent(&a, &g, &temp);
	/* Print out the values */
  Serial.print("Time elapsed:");
	Serial.println(dt);
  currentTime = millis();
  roll = (roll + g.gyro.x*dt/1000)*0.5 + 0.5*atan(a.acceleration.y / sqrt(pow(a.acceleration.x, 2) + pow(a.acceleration.z, 2)));
  pitch = (pitch + g.gyro.y*dt/1000)*0.5 + 0.5*atan(-1 * a.acceleration.x / sqrt(pow(a.acceleration.y, 2) + pow(a.acceleration.z, 2)));
  rollf = (1-k)*rollf + k*roll;
  pitchf = (1-k)*pitchf + k*pitch;
  rolld = rollf * 180 / 3.1415926;
  pitchd = pitchf * 180 / 3.1415926;
  Serial.println("");
  Serial.print("Roll: ");
  Serial.print(rolld);
  Serial.print(" Pitch: ");
  Serial.print(pitchd);
  Serial.println("");
	delay(10);
What's going on here?
The MPU-6050 was discontinued by the original manufacturer many years ago, and you can only hope that the counterfeits or clones you can buy today will perform correctly and reliably, if at all.
Try this much simpler code and see if it shows a similar problem.
// minimal MPU-6050 tilt and roll. Works with MPU-9250 too.
// works perfectly with GY-521, pitch and roll signs agree with arrows on sensor module 7/2019
// Tested with 3.3V eBay Pro Mini with no external pullups on I2C bus (worked with internal pullups)
// Add 4.7K pullup resistors to 3.3V if required. A4 = SDA, A5 = SCL
#include<Wire.h>
const int MPU_addr1 = 0x68;
float xa, ya, za, roll, pitch;
  Wire.begin();                                      //begin the wire communication
  Wire.beginTransmission(MPU_addr1);                 //begin, send the slave adress (in this case 68)
  Wire.write(0x6B);                                  //make the reset (place a 0 into the 6B register)
  Wire.write(0);
  Wire.endTransmission(true);                        //end the transmission
  Wire.write(0x3B);  //send starting register address, accelerometer high byte
  Wire.endTransmission(false); //restart for read
  Wire.requestFrom(MPU_addr1, 6); //get six bytes accelerometer data
  int t = Wire.read();
  xa = (t << 8) | Wire.read();
  t = Wire.read();
  ya = (t << 8) | Wire.read();
  t = Wire.read();
  za = (t << 8) | Wire.read();
// formula from https://wiki.dfrobot.com/How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing
  roll = atan2(ya , za) * 180.0 / PI;
  pitch = atan2(-xa , sqrt(ya * ya + za * za)) * 180.0 / PI; //account for roll already applied
  Serial.print("roll = ");
  Serial.print(roll,1);
  Serial.print(", pitch = ");
  Serial.println(pitch,1);
  delay(400);
Actually I solved the problem by connecting AD0 to ground, apparently it causes I2C issues if left floating
I appreciate the help, thanks
Glad you solved the problem, but leaving an address input floating is an inexcusably poor board design.
I was able to confirm it was in fact the floating pin by running it for extended time while grounded, no freezing. Then I disconnected the pin and it would occasionally freeze. And I could reproduce the issue and cause instant freeze by feeding the pin a logic high.
