mylast
October 26, 2019, 2:47pm
1
Hello, everyone.
Today I succeeded in calibrating the MPU6050 6dof for each axis. I used the complementary filter for pitch and roll and I made a slight correction to the drift in yaw with a constant value after observing the small drift.
I am now facing a different issue: If I rotate in two axes, I get a bad drift when one of them is yaw.
If I move in the planes made by X axis and Y axis (pitch and roll), everything is ok, but when I move around JAW, everything drifts out.
Is there a method to add the YAW to the two and vice versa?
How are you calculating roll pitch and yaw?
Why not show your formatted code (right click select auto format) in code tags so that we can better help you?
mylast
October 26, 2019, 3:22pm
3
#include "config.h"
#include <Wire.h>
#include <Arduino.h>
#include "IMU.h"
/* Declare variables for read and calculated
* values from the MPU
int a_raw_x, a_raw_y, a_raw_z;
// These are set by get_ax/get_ay/get_az
float ax, ay, az;
int temp;
int g_raw_x, g_raw_y, g_raw_z;
// These are set by get_gx/get_gy/get_gz
float gx, gy, gz;
unsigned int acc_total_vector;
float angle_pitch_acc, angle_roll_acc, angle_pitch_acc_raw, angle_roll_acc_raw;
float angle_pitch_gyro, angle_roll_gyro, angle_yaw_gyro;
float angle_pitch = 0, angle_roll = 0, angle_yaw = 0;
long int gex = 0, gey = 0, gez = 0;
int aex, aey, aez;
int init_angle_flag = 0;
// Initialize the connection with the MPU through i2c and initialize all variables
void IMU_init() {
Wire.begin();
// Set i2c to MPU6050 to 400kHz
Wire.setClock(400000);
Wire.beginTransmission(MPU_addr);
// PWR_MGMT_1 register
Wire.write(0x6B);
/* REGISTER 6B
* B0-B2 - Set CLKSEL (selects the 8MHz internal oscilator) // 000
* B3 - Disable temp sensor // 0
* B4 - N/A
* B5 - Cycle // 0
* B6 - Sleep mode (1 for on) // 0
* B7 - Device reset
Wire.write(0b00000000);
Wire.endTransmission(true);
// 0x1B is register 27 in MPU6050 which sets the full scale range for GYRO
Wire.write(0x1B);
// 250 deg/sec max
// 0x1C is register 27 in MPU6050 which sets the full scale range for ACCELEROMETER
Wire.write(0x1C);
// +/- 4g max
Wire.write(0b00001000);
calc_acc_error();
calc_gyro_error();
// This function will set the gex gey gez values from the mean of readings from the MPU
void calc_gyro_error () {
// Read 2000 values and get the mean
for(int i = 0; i < error_no_reads; i++) {
read_imu_raw_data();
gex += g_raw_x;
gey += g_raw_y;
gez += g_raw_z;
delay(2);
gex /= error_no_reads;
gey /= error_no_reads;
gez /= error_no_reads;
void calc_acc_error () {
read_imu_data();
aex += a_raw_x;
aey += a_raw_y;
aez += a_raw_z;
// Delay is important so we don't read the same value twice
delay(2);
aex = aex / error_no_reads;
aey = aey / error_no_reads;
aez = aez / error_no_reads - accel_sensitivity_LSB;
void compute_acc_angles() {
calc_acc_pitch_angle();
calc_acc_roll_angle();
calc_acc_yaw_angle();
void compute_gyro_angles() {
if(init_angle_flag) {
angle_roll_gyro += (float) gx * refresh_constant;
angle_pitch_gyro += (float) gy * refresh_constant;
angle_yaw_gyro += (float) gz * refresh_constant;
angle_roll_gyro = angle_roll_acc;
angle_pitch_gyro = angle_pitch_acc;
init_angle_flag = 1;
// We apply the complementary filter
void compute_final_angles() {
angle_pitch = (float) (angle_pitch_acc * 0.02) + (angle_pitch_gyro * 0.98);
angle_roll = (float) (angle_roll_acc * 0.02) + (angle_roll_gyro * 0.98);
void read_imu_data() {
* This function uses the raw gyro and accelerometer data.
* Each value is filtered by the error obtained by averaging
* the error in x reads (x = error_no_reads)
ax = (float) (a_raw_x - aex) / accel_sensitivity_LSB;
ay = (float) (a_raw_y - aey) / accel_sensitivity_LSB;
az = (float) (a_raw_z - aez) / accel_sensitivity_LSB;
gx = (float) (g_raw_x - gex) / gyro_sensitivity_LSB;
gy = (float) (g_raw_y - gey) / gyro_sensitivity_LSB;
gz = (float) (g_raw_z - gez) / gyro_sensitivity_LSB;
compute_acc_angles();
compute_gyro_angles();
compute_final_angles();
void read_imu_raw_data() {
// Start with the ACCEL_XOUT_H (addr 59)
Wire.write(0x3B);
// Do not release transmission and set restart message
Wire.endTransmission(false);
// Request data from register 59 up to register 73 (0x3B - 0x48)
Wire.requestFrom(MPU_addr, 14, true);
/* The code `read1 << 8 | read2`
* reads one register (high), shifts it
* by 8 bits and then sums it with read2
a_raw_x = Wire.read()<< 8 | Wire.read(); // 0x3B and 0x3C
a_raw_y = Wire.read()<< 8 | Wire.read(); // 0x3D and 0x3E
a_raw_z = Wire.read()<< 8 | Wire.read(); // 0x3F and 0x40
temp = Wire.read()<< 8 | Wire.read(); // 0x41 and 0x42
g_raw_x = Wire.read()<< 8 | Wire.read(); // 0x43 and 0x44
g_raw_y = Wire.read()<< 8 | Wire.read(); // 0x45 and 0x46
g_raw_z = Wire.read()<< 8 | Wire.read(); // 0x47 and 0x48
float get_acc_sensitivity() {
return accel_sensitivity_LSB;
float get_gyro_sensitivity() {
return gyro_sensitivity_LSB;
void calc_acc_total_vector() {
acc_total_vector = sqrt((ax*ax) + (ay*ay) + (az*az));
void calc_acc_roll_angle() {
angle_roll_acc = atan2(ay, az) * TO_DEG_CONST;
void calc_acc_pitch_angle() {
angle_pitch_acc = atan2(-1 * ax, sqrt(ay * ay + az * az)) * TO_DEG_CONST;
//TODO: Approximate the yaw drift and fill this
void calc_acc_yaw_angle() {
float get_acc_pitch_angle() {
return angle_pitch_acc;
float get_acc_roll_angle() {
return angle_roll_acc;
float get_gyro_roll_angle() {
return angle_roll_gyro;
float get_gyro_pitch_angle() {
return angle_pitch_gyro;
float get_gyro_yaw_angle() {
return angle_yaw_gyro;
float get_angle_roll() {
return angle_roll;
float get_angle_pitch() {
return angle_pitch;
* DEBUGGING functions
int get_raw() {
return a_raw_x;
For a stable yaw value, a magnetometer or other external reference is required.
Consider getting an MPU-9250 or more recent 9 DOF module from Pololu, and using Kris Winer's Mahoney AHRS, or RTIMUlib for Arduino.
mylast
October 26, 2019, 4:09pm
5
Thanks for the input, but I don't really care about the drift of the yaw right now. I know it will affect the pitch/roll over time, but I am interested more in the maths of adding that to the pitch/roll
Without an external reference, the yaw value is meaningless, and can't be taken into consideration for pitch and roll calculations.
You should learn how Euler angles are actually defined (there are six ways). One place to start is here: http://www.chrobotics.com/library
Pitch and roll are defined by the accelerometer, when the sensor is not accelerating or rotating. The gyro is useful only to correct for errors in acceleration values, introduced by the accelerations associated with rotational motion.
