MPU6050_DMP error
Hi guys, I am newbie here, it is my first question. I hope i can get your response :wink:
Actually I want to construct a B-robot from this website " https://github.com/JJulio/b-robot" and I use Arduino leonardo .
and now can get the data from data from MPU6050 by including only MPU6050.h, I2Cdev.h, Wire.h. ( the code is below). I connect SDA , SCL arduino-pin SDA SCL MPU605-pin, and it work well when i connect int-pin of MPU to nothing , but when I connect int_pin of MPU to digital pin 3(int #0_pin) of Arduino, the data is not sent .
and the second problem is that i want the get the data in euler or row pitch roll format. and I use the example code in the folder MPU6050_DMP6 (you will have this code if you go to that link and download). It does not work even though I connect or not connect the int_pin of MPU. Could anyone help me ??? thanks in advance :smiley:
#include “I2Cdev.h”
#include “MPU6050.h”
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include “Wire.h”
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
//MPU6050 accelgyro(0x69); // ← use for AD0 high
int16_t ax, ay, az;
int16_t gx, gy, gz;
// uncomment “OUTPUT_READABLE_ACCELGYRO” if you want to see a tab-separated
// list of the accel X/Y/Z and then gyro X/Y/Z values in decimal. Easy to read,
// not so easy to parse, and slow(er) over UART.
#define OUTPUT_READABLE_ACCELGYRO
// uncomment “OUTPUT_BINARY_ACCELGYRO” to send all 6 axes of data as 16-bit
// binary, one right after the other. This is very fast (as fast as possible
// without compression or data loss), and easy to parse, but impossible to read
// for a human.
//#define OUTPUT_BINARY_ACCELGYRO
#define LED_PIN 13
bool blinkState = false;
// join I2C bus (I2Cdev library doesn’t do this automatically)
Wire.begin();
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
// initialize serial communication
// (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
// it’s really up to you depending on your project)
Serial.begin(38400);
// initialize device
Serial.println(“Initializing I2C devices…”);
accelgyro.initialize();
// verify connection
Serial.println(“Testing device connections…”);
Serial.println(accelgyro.testConnection() ? “MPU6050 connection successful” : “MPU6050 connection failed”);
// use the code below to change accel/gyro offset values
Serial.println(“Updating internal sensor offsets…”);
// -76 -2359 1688 0 0 0
Serial.print(accelgyro.getXAccelOffset()); Serial.print("\t"); // -76
Serial.print(accelgyro.getYAccelOffset()); Serial.print("\t"); // -2359
Serial.print(accelgyro.getZAccelOffset()); Serial.print("\t"); // 1688
Serial.print(accelgyro.getXGyroOffset()); Serial.print("\t"); // 0
Serial.print(accelgyro.getYGyroOffset()); Serial.print("\t"); // 0
Serial.print(accelgyro.getZGyroOffset()); Serial.print("\t"); // 0
Serial.print("\n");
accelgyro.setXGyroOffset(220);
accelgyro.setYGyroOffset(76);
accelgyro.setZGyroOffset(-85);
Serial.print("\n");
// configure Arduino LED for
pinMode(LED_PIN, OUTPUT);
// read raw accel/gyro measurements from device
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
// these methods (and a few others) are also available
//accelgyro.getAcceleration(&ax, &ay, &az);
//accelgyro.getRotation(&gx, &gy, &gz);
#ifdef OUTPUT_READABLE_ACCELGYRO
// display tab-separated accel/gyro x/y/z values
Serial.print(“a/g:\t”);
Serial.print(ax); Serial.print("\t");
Serial.print(ay); Serial.print("\t");
Serial.print(az); Serial.print("\t");
Serial.print(gx); Serial.print("\t");
Serial.print(gy); Serial.print("\t");
Serial.println(gz);
#endif
#ifdef OUTPUT_BINARY_ACCELGYRO
Serial.write((uint8_t)(ax >> 8)); Serial.write((uint8_t)(ax & 0xFF));
Serial.write((uint8_t)(ay >> 8)); Serial.write((uint8_t)(ay & 0xFF));
Serial.write((uint8_t)(az >> 8)); Serial.write((uint8_t)(az & 0xFF));
Serial.write((uint8_t)(gx >> 8)); Serial.write((uint8_t)(gx & 0xFF));
Serial.write((uint8_t)(gy >> 8)); Serial.write((uint8_t)(gy & 0xFF));
Serial.write((uint8_t)(gz >> 8)); Serial.write((uint8_t)(gz & 0xFF));
#endif
// blink LED to indicate activity
blinkState = !blinkState;
digitalWrite(LED_PIN, blinkState);
You don’t need to use the interrupt pin in case you are trying to extract the raw data. I guess you are also using the Pull up resistors with SCL and the SDA lines.
To get the DMP data, connect the interrupt(INT) pin from MPU-6050 to interrupt#0 pin of your Arduino board.
If you are using the following code as the base-line:
https://github.com/jrowberg/i2cdevlib/blob/master/Arduino/MPU6050/Examples/MPU6050_DMP6/MPU6050_DMP6.ino
-Uncomment line 93 : to have the data in readable Euler
#define OUTPUT_READABLE_EULER
or
  • Uncomment line 100: to have yaw,pitch, roll
    #define OUTPUT_READABLE_YAWPITCHROLL
-You need to send a character in the serial monitor to initiate the interrupt and have the DMP data.
*(For MPU-9150, the magnetometer registers need proper assembling as the High Byte and the Low byte of magnetometer registers has a reverse order than that of the accelerometer and the gyroscope).
Cheers!
