Hi all,
I bought 2 mq131 sensor for ozone detection from different suppliers. First one was obtained from aliexpress, so i though the sensor was broken. Second one is from a spanish supplier.
I have the same problem with both sensors: no changes in analog output when they are exposured to ozone. Ozone is also measured with an industrial sensor for I+D so I am completely sure that it is correctly generated.
I know this kind of sensors are very difficult cause there are several models, etc. As consequence, before calibrating it, i just checked the analog response to ozono.
The serial monitor shows this all the time (with and without ozone 5ppm)
D0: 1 -- A0: 6
D0: 1 -- A0: 6
D0: 1 -- A0: 6
D0: 1 -- A0: 6
D0: 1 -- A0: 6
D0: 1 -- A0: 6
This is the sensor I have and my code
wiring:
I'd appreciate any kind of help! Thanks in advance
int sensor_AOUT = A0; //connected from AOUT to the sensor to A1 on the Arduino
int sensor_DOUT = 9; //connect DOUT from sensor to Arduino pin 2
int wartosc_AOUT ; //variable for the value of AOUT
int wartosc_DOUT ; //variable for the value of DOUT
Serial.begin(9600); //start the monitor serial port
pinMode(9, INPUT); //set pin 2 as input
wartosc_AOUT = analogRead(sensor_AOUT); //load values from AOUT
wartosc_DOUT = digitalRead(sensor_DOUT); //load values DOUT
Serial.print("D0: "); //display on serial monitor
Serial.print(wartosc_DOUT);
Serial.print(" -- A0: ");
Serial.println(wartosc_AOUT);
delay(200); //delay between consecutive readings
Did you "burn in" the sensor for at least 24 hours, as required? See the data sheet (preheat time).
jremington:
yes, I did.
Preheat for 48h, 6V from adapter, not USB
Where did you get the ozone you used to test with? How old was the source? Ozone is not a persistent gas, if I remember correctly.
Paul
Hello everyone,
I'm having the same issue, my analog output is always the same. First I read the sensor in a normal environment, then I took it to a sealed cabin where I have an ozone gerenator.
marcusvicentini:
Hello everyone,
But, did the digital out ever go LOW? That is supposed to indicate ozone.
Paul
Today I ran a few more tests. The analog out is now varying to 3 or 4 when I place the sensor inside the cabin. The digital out is always the same. I regulated the Dout very close to 0 and yet it didn't change
marcusvicentini:
That is good news, but what do you mean "regulated the Dout very close to 0"? Dout should be watched with an Arduino digital pin by doing a digital read on that pin.
Paul
Paul_KD7HB:
Paul
the "good one" is an industrial ozone meter (8.000€) got from 2B technology. You are right, ozone is not persistent but, in my case, it is generated continuously.
Paul_KD7HB:
Paul
Generaly, not. It is always HIGH. Increasing sensivity to the maximum, DOUT is always LOW, even when there is no ozone.
I asked the seller and he said to me that he is going to sent me a new one, If it (the third sensor I test) shows same behaviour, It will mean Im doing something wrong
