Hello Everyone I need Help for MQTT server. who help me MQTT Arduino Mega ethernet sheld2 server?
Could you give just a little bit more information please!
What help do you need, what code have you got, what is the requirment of use?
// I need to add MQTT server my project? please check
#include <SPI.h>
#include <Ethernet2.h>
#include <SD.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ 60
const int buzzer = 13; //buzzer to arduino pin 13
//---------LCD 16x2 LiquidCrystal_I2C----------//
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
//---------LCD 16x2 LiquidCrystal_I2C--------//
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 0, 180);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
File webFile; // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0; // index into HTTP_req buffer
unsigned char LED_state[3] = {0}; // stores the states of the LEDs, 1 bit per LED
byte customChar[] = {
B00001,
B00011,
B00111,
B11111,
B11111,
B00111,
B00011,
B00001
int i;
// disable Ethernet chip
pinMode(buzzer, OUTPUT); // Set buzzer - pin 13 as an output
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
pinMode(3, INPUT); // switch is attached to Arduino pin 3
lcd.setBacklight(HIGH);
//---------LCD 16x2 LiquidCrystal_I2C----------------------//
//lcd.begin(); // initialize the LCD
lcd.init(); // initialize the lcd
lcd.backlight(); // Turn on the blacklight and print a message.
lcd.setCursor(4, 0); // Set the cursor on the first column and first row.
lcd.print("NEWTECH");
lcd.setCursor(1, 1); // Set the cursor on the first column and first row.
lcd.print("Home Automation");
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
lcd.clear();
delay(200);
lcd.setCursor(1, 0); // Set the cursor on the first column and first row.
lcd.print("!System Fail!");
lcd.createChar(0, customChar);
lcd.setCursor(14, 0); // move cursor to (2, 0)
lcd.write((byte)0); // print the custom char at (2, 0)
lcd.clear();
lcd.setCursor(0, 1); // Set the cursor on the first column and first row.
lcd.print("Put The SD Card?");
// delay(1000);
tone(buzzer, 1000); // Send 1KHz sound signal...
delay(1000); // ...for 1 sec
//noTone(buzzer); // Stop sound...
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
lcd.clear();
delay(200);
lcd.print("SD Initialized");
lcd.setCursor(2, 1); // Set the cursor on the first column and first row.
lcd.print("SD Card Found");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
// pins 26 to 49 are outputs
for (i = 26; i <= 49; i++) {
pinMode(i, OUTPUT); // set pins as outputs
digitalWrite(i, LOW); // switch the output pins off
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("Newtech Server IP is at = ");
Serial.println(Ethernet.localIP());
void SendOKpage(EthernetClient &client)
// send a standard http response header
void SendAuthentificationpage(EthernetClient &client)
client.println("HTTP/1.1 401 Authorization Required");
client.println("WWW-Authenticate: Basic realm=\"Secure Area\"");
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<HTML> <HEAD> <TITLE>Error</TITLE>");
client.println(" </HEAD> <BODY><H1>401 Unauthorized.</H1></BODY> </HTML>");
char linebuf[80];
int charcount = 0;
boolean authentificated = false;
/* //lcd.clear();
lcd.print("!Ethernet Fail!");
lcd.print("00:00:00:00??");
/* //lcd.clear();
lcd.print("NEWTECH Teconlogy");
// print your local IP address:
// listen for incoming clients
if (client) {
Serial.println("new client");
// lcd.clear();
lcd.setCursor(1, 0); // Set the cursor on the LCD to Col 1 Row 1
lcd.print("Lan IP Address:"); // Print on text on the LCD
lcd.setCursor(2, 1); //set the cursor on the LCD to Col 0 Row 2
lcd.print(Ethernet.localIP()); // Print the IP address on the LCD
memset(linebuf, 0, sizeof(linebuf));
charcount = 0;
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
linebuf[charcount] = c;
if (charcount < sizeof(linebuf) - 1) charcount++;
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
if (authentificated )
SendOKpage(client);
SendAuthentificationpage(client);
// remainder of header follows below, depending on if
// web page or XML page is requested
// Ajax request - send XML file
if (StrContains(HTTP_req, "ajax_inputs")) {
// send rest of HTTP header
client.println("Content-Type: text/xml");
client.println("Connection: keep-alive");
client.println();
SetLEDs();
// send XML file containing input states
XML_response(client);
else { // web page request
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while (webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// display received HTTP request on serial port
//Serial.print(HTTP_req);
// reset buffer index and all buffer elements to 0
req_index = 0;
StrClear(HTTP_req, REQ_BUF_SZ);
if (c == '\n') {
// you're starting a new line
if (strstr(linebuf, "Authorization: Basic") > 0 && strstr(linebuf, "Z2lhc2g6Z2lhc2g=") > 0)
authentificated = true;
charcount = 0;
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
// checks if received HTTP request is switching on/off LEDs
// also saves the state of the LEDs
void SetLEDs(void)
char str_on[12] = {0};
char str_off[12] = {0};
unsigned char i;
unsigned int j;
int LED_num = 1;
for (i = 0; i < 3; i++) {
for (j = 1; j <= 0x80; j <<= 1) {
sprintf(str_on, "LED%d=%d", LED_num, 1);
sprintf(str_off, "LED%d=%d", LED_num, 0);
if (StrContains(HTTP_req, str_on)) {
LED_state[i] |= (unsigned char)j; // save LED state
digitalWrite(LED_num + 25, HIGH);
tone(buzzer, 5000); // Send 1KHz sound signal...
delay(100); // ...for 1 sec
lcd.clear();
lcd.print("Data Pass HIGH"); // Print on text on the LCD
delay (500);
Serial.println("ON");
else if (StrContains(HTTP_req, str_off)) {
LED_state[i] &= (unsigned char)(~j); // save LED state
digitalWrite(LED_num + 25, LOW);
lcd.clear();
lcd.print("Data Pass LOW"); // Print on text on the LCD
delay (500);
LED_num++;
//------------------------End Loop--------------------------------------------//
// send the XML file with analog values, switch status
// and LED status
void XML_response(EthernetClient cl)
unsigned char i;
unsigned int j;
cl.print("<?xml version = \"1.0\" ?>");
cl.print("<inputs>");
cl.print("<LED>");
if ((unsigned char)LED_state[i] & j) {
cl.print("checked");
//Serial.println("ON");
else {
cl.print("unchecked");
cl.println("</LED>");
cl.print("</inputs>");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
for (int i = 0; i < length; i++) {
str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
char found = 0;
char index = 0;
char len;
len = strlen(str);
if (strlen(sfind) > len) {
return 0;
while (index < len) {
if (str[index] == sfind[found]) {
found++;
if (strlen(sfind) == found) {
return 1;
else {
found = 0;
index++;
return 0;
The Mega cannot run MQTT server. You can use an online MQTT Broker (server) or you can run your own MQTT Broker on a PC of your choosing.
The Mega should be able to run PubSubClient which can connect to a MQTT server.
Here is some ESP32 MQTT client code you can use as a model.
Chappie Weather upgrade/addition
process wind speed direction and rain fall.
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp_system.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include "driver/pcnt.h"
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
#include <ESP32Time.h>
ESP32Time rtc;
WiFiClient wifiClient;
PubSubClient MQTTclient(mqtt_server, mqtt_port, wifiClient);
float CalculatedVoltage = 0.0f;
float kph = 0.0f;
float rain = 0.0f;
PCNT PCNT_UNIT_0, PCNT_CHANNEL_0 GPIO_NUM_15 = pulse input pin
PCNT PCNT_UNIT_1, PCNT_CHANNEL_0 GPIO_NUM_4 = pulse input pin
pcnt_unit_t pcnt_unit00 = PCNT_UNIT_0; //pcnt unit 0 channel 0
pcnt_unit_t pcnt_unit10 = PCNT_UNIT_1; //pcnt unit 1 channel 0
hw_timer_t * timer = NULL;
#define evtAnemometer ( 1 << 0 )
#define evtRainFall ( 1 << 1 )
#define evtParseMQTT ( 1 << 2 )
EventGroupHandle_t eg;
#define OneMinuteGroup ( evtAnemometer | evtRainFall )
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 100;
struct stu_message
char payload [payloadSize] = {'\0'};
String topic ;
} x_message;
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
SemaphoreHandle_t sema_CalculatedVoltage;
int mqttOK = 0; // stores a count value that is used to cause an esp reset
volatile bool TimeSet = false;
A single subject has been subscribed to, the mqtt broker sends out "OK" messages if the client receives an OK message the mqttOK value is set back to zero.
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
x_message.topic = ""; //clear topic string buffer
x_message.topic = topic; //store new topic
int i = 0; // extract payload
for ( i; i < length; i++)
x_message.payload[i] = ((char)payload[i]);
x_message.payload[i] = '\0';
xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR onTimer()
BaseType_t xHigherPriorityTaskWoken;
xEventGroupSetBitsFromISR(eg, OneMinuteGroup, &xHigherPriorityTaskWoken);
} // void IRAM_ATTR onTimer()
eg = xEventGroupCreate(); // get an event group handle
// x_message.topic.reserve(300);
adc1_config_width(ADC_WIDTH_12Bit);
adc1_config_channel_atten(ADC1_CHANNEL_6, ADC_ATTEN_DB_11);// using GPIO 34 wind direction
adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39 current
adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11);// using GPIO 36 battery volts
// hardware timer 4 set for one minute alarm
timer = timerBegin( 3, 80, true );
timerAttachInterrupt( timer, &onTimer, true );
timerAlarmWrite(timer, 60000000, true);
timerAlarmEnable(timer);
/* Initialize PCNT's counter */
int PCNT_H_LIM_VAL = 3000;
int PCNT_L_LIM_VAL = -10;
// 1st PCNT counter
pcnt_config_t pcnt_config = {};
pcnt_config.pulse_gpio_num = GPIO_NUM_15;// Set PCNT input signal and control GPIOs
pcnt_config.ctrl_gpio_num = PCNT_PIN_NOT_USED;
pcnt_config.channel = PCNT_CHANNEL_0;
pcnt_config.unit = PCNT_UNIT_0;
// What to do on the positive / negative edge of pulse input?
pcnt_config.pos_mode = PCNT_COUNT_INC; // Count up on the positive edge
pcnt_config.neg_mode = PCNT_COUNT_DIS; // Count down disable
// What to do when control input is low or high?
pcnt_config.lctrl_mode = PCNT_MODE_KEEP; // do not count if low reverse
pcnt_config.hctrl_mode = PCNT_MODE_KEEP; // Keep the primary counter mode if high
// Set the maximum and minimum limit values to watch
pcnt_config.counter_h_lim = PCNT_H_LIM_VAL;
pcnt_config.counter_l_lim = PCNT_L_LIM_VAL;
pcnt_unit_config(&pcnt_config); // Initialize PCNT unit
pcnt_set_filter_value( PCNT_UNIT_0, 1); //Configure and enable the input filter
pcnt_filter_enable( PCNT_UNIT_0 );
pcnt_counter_pause( PCNT_UNIT_0 );
pcnt_counter_clear( PCNT_UNIT_0 );
pcnt_counter_resume( PCNT_UNIT_0); // start the show
// setup 2nd PCNT
pcnt_config = {};
pcnt_config.pulse_gpio_num = GPIO_NUM_4;
pcnt_config.unit = PCNT_UNIT_1;
//pcnt_set_filter_value( PCNT_UNIT_1, 1 );
//pcnt_filter_enable ( PCNT_UNIT_1 );
pcnt_counter_pause ( PCNT_UNIT_1 );
pcnt_counter_clear ( PCNT_UNIT_1 );
pcnt_counter_resume ( PCNT_UNIT_1 );
xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
sema_CalculatedVoltage = xSemaphoreCreateBinary();
xSemaphoreGive( sema_CalculatedVoltage );
sema_mqttOK = xSemaphoreCreateBinary();
xSemaphoreGive( sema_mqttOK );
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 15000, NULL, 5, NULL, 1 );
xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
xTaskCreatePinnedToCore( fReadBattery, "fReadBattery", 4000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fReadCurrent, "fReadCurrent", 4000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fWindDirection, "fWindDirection", 10000, NULL, 4, NULL, 1 );
xTaskCreatePinnedToCore( fAnemometer, "fAnemometer", 10000, NULL, 4, NULL, 1 );
xTaskCreatePinnedToCore( fRainFall, "fRainFall", 10000, NULL, 4, NULL, 1 );
xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 3, NULL, 1 ); // assign all to core 1
} //void setup()
void fWindDirection( void *pvParameters )
// read the wind direction sensor, return heading in degrees
float adcValue = 0.0f;
uint64_t TimePastKalman = esp_timer_get_time();
SimpleKalmanFilter KF_ADC( 1.0f, 1.0f, .01f );
float high = 0.0f;
float low = 2000.0f;
float ADscale = 3.3f / 4096.0f;
TickType_t xLastWakeTime = xTaskGetTickCount();
const TickType_t xFrequency = 100; //delay for mS
int count = 0;
String windDirection;
windDirection.reserve(20);
String MQTTinfo = "";
MQTTinfo.reserve( 150 );
while ( !MQTTclient.connected() )
vTaskDelay( 250 );
for (;;)
windDirection = "";
adcValue = float( adc1_get_raw(ADC1_CHANNEL_6) ); //take a raw ADC reading
KF_ADC.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
adcValue = KF_ADC.updateEstimate( adcValue ); // apply simple Kalman filter
TimePastKalman = esp_timer_get_time(); // time of update complete
adcValue = adcValue * ADscale;
log_i( " adc %f", adcValue );
if ( (adcValue >= 0.0f) & (adcValue <= .25f ) )
// log_i( " n" );
windDirection.concat( "N" );
// if ( (adcValue >= .25f) & adcValue <= .5f )
// log_i( " nne" );
// windDirection.concat( "NNE");
if ( (adcValue > .25f) & (adcValue <= .6f ) )
// log_i( " e" );
windDirection.concat( "E" );
// if ( (adcValue > 1.0f) & (adcValue < 1.75f) )
// log_i( " sse" );
// windDirection.concat( "S-SE");
// if ( (adcValue >= 1.75f) & (adcValue < 2.2f) )
// log_i( " nnw" );
// windDirection.concat( "N-NW" );
if ( (adcValue > 2.0f) & ( adcValue < 3.3f) )
// log_i( " s" );
windDirection.concat( "S");
// if ( (adcValue > 2.6f) & (adcValue < 3.0f ) )
// log_i( " ssw" );
// windDirection.concat( "S-SW" );
if ( (adcValue >= 1.7f) & (adcValue < 2.0f ) )
// log_i( " w" );
windDirection.concat( "W" );
if( count >= 30 )
MQTTinfo.concat( String(kph, 2) );
MQTTinfo.concat( ",");
MQTTinfo.concat( windDirection );
MQTTinfo.concat( String(rain,2) );
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
MQTTclient.publish( topicWSWDRF, MQTTinfo.c_str() );
xSemaphoreGive( sema_MQTT_KeepAlive );
count = 0;
count++;
MQTTinfo = "";
vTaskDelayUntil( &xLastWakeTime, xFrequency );
vTaskDelete ( NULL );
// read rainfall
void fRainFall( void *pvParemeters )
int16_t count = 0;
pcnt_counter_pause( PCNT_UNIT_1 );
pcnt_counter_clear( PCNT_UNIT_1 );
pcnt_counter_resume( PCNT_UNIT_1 );
for (;; )
xEventGroupWaitBits (eg, evtRainFall, pdTRUE, pdTRUE, portMAX_DELAY);
pcnt_get_counter_value( PCNT_UNIT_1, &count );
if ( count != 0 )
// 0.2794mm of rain per click clear clicks at mid night
rain = 0.2794f * (float)count;
log_i( "count %d, rain rain = %f mm", count, rain );
void fAnemometer( void *pvParameters )
int16_t count = 0;
pcnt_counter_clear(PCNT_UNIT_0);
pcnt_counter_resume(PCNT_UNIT_0);
for (;;)
xEventGroupWaitBits (eg, evtAnemometer, pdTRUE, pdTRUE, portMAX_DELAY);
pcnt_get_counter_value( PCNT_UNIT_0, &count); //int16_t *count
// A wind speed of 2.4km/h causes the switch to close once per second
kph = 2.4 * ((float)count / 60.0f);
//if ( count != 0 )
log_i( "count %d, wind Kph = %f", count, kph );
count = 0;
pcnt_counter_resume( PCNT_UNIT_0 );
void fmqttWatchDog( void * paramater )
int UpdateImeTrigger = 86400; //seconds in a day
int UpdateTimeInterval = 86300; // 1st time update in 100 counts
int maxNonMQTTresponse = 60;
for (;;)
vTaskDelay( 1000 );
if ( mqttOK >= maxNonMQTTresponse )
ESP.restart();
xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
mqttOK++;
UpdateTimeInterval++; // trigger new time get
if ( UpdateTimeInterval >= UpdateImeTrigger )
TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
UpdateTimeInterval = 0;
vTaskDelete( NULL );
void fparseMQTT( void *pvParameters )
struct stu_message px_message;
for (;;)
if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
// parse the time from the OK message and update MCU time
if ( String(px_message.topic) == topicOK )
if ( !TimeSet)
String temp = "";
temp = px_message.payload[0];
temp += px_message.payload[1];
temp += px_message.payload[2];
temp += px_message.payload[3];
int year = temp.toInt();
temp = "";
temp = px_message.payload[5];
temp += px_message.payload[6];
int month = temp.toInt();
temp = "";
temp = px_message.payload[8];
temp += px_message.payload[9];
int day = temp.toInt();
temp = "";
temp = px_message.payload[11];
temp += px_message.payload[12];
int hour = temp.toInt();
temp = "";
temp = px_message.payload[14];
temp += px_message.payload[15];
int min = temp.toInt();
rtc.setTime( 0, min, hour, day, month, year );
log_i( "rtc %s ", rtc.getTime() );
TimeSet = true;
} //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
mqttOK = 0;
} // void fparseMQTT( void *pvParameters )
void fReadCurrent( void * parameter )
float ADbits = 4096.0f;
float ref_voltage = 3.3f;
float offSET = .0f;
uint64_t TimePastKalman = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
SimpleKalmanFilter KF_I( 1.0f, 1.0f, .01f );
float mA = 0.0f;
int printCount = 0;
const float mVperAmp = 100.0f;
float adcValue = 0;
float Voltage = 0;
float Power = 0.0;
String powerInfo = "";
powerInfo.reserve( 150 );
vTaskDelay( 250 );
const TickType_t xFrequency = 1000; //delay for mS
for (;;)
adc1_get_raw(ADC1_CHANNEL_3); // read once discard reading
adcValue = ( (float)adc1_get_raw(ADC1_CHANNEL_3) );
Voltage = ( (adcValue * ref_voltage) / ADbits ) + offSET; // Gets you mV
mA = Voltage / mVperAmp; // get amps
KF_I.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
mA = KF_I.updateEstimate( mA ); // apply simple Kalman filter
printCount++;
if ( printCount == 60 )
xSemaphoreTake( sema_CalculatedVoltage, portMAX_DELAY);
Power = CalculatedVoltage * mA;
log_i( "Voltage=%f mA=%f Power=%f", CalculatedVoltage, mA, Power );
printCount = 0;
powerInfo.concat( String(CalculatedVoltage, 2) );
powerInfo.concat( ",");
powerInfo.concat( String(mA, 2) );
powerInfo.concat( String(Power, 4) );
MQTTclient.publish( topicPower, powerInfo.c_str() );
powerInfo = "";
} //void fReadCurrent( void * parameter )
void fReadBattery( void * parameter )
//float ADbits = 4096.0f;
//float ref_voltage = 3.3f;
float offSET = 0.0f;
const float r1 = 50500.0f; // R1 in ohm, 50K
const float r2 = 10000.0f; // R2 in ohm, 10k potentiometer
//float Vscale = (r1+r2)/r2;
float Vbatt = 0.0f;
int printCount = 0;
float vRefScale = (3.3f / 4096.0f) * ((r1 + r2) / r2);
SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
for (;;)
adc1_get_raw(ADC1_CHANNEL_0); //read and discard
adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading
KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
adcValue = KF_ADC_b.updateEstimate( adcValue ); // apply simple Kalman filter
Vbatt = adcValue * vRefScale;
xSemaphoreTake( sema_CalculatedVoltage, portMAX_DELAY );
CalculatedVoltage = Vbatt;
// printCount++;
// if ( printCount == 3 )
// log_i( "Vbatt %f", Vbatt );
// printCount = 0;
//log_i( "fReadBattery %d", uxTaskGetStackHighWaterMark( NULL ) );
void MQTTkeepalive( void *pvParameters )
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
// setting must be set before a mqtt connection is made
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
for (;;)
//check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
MQTTclient.loop();
else {
log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
vTaskDelay( 250 ); //task runs approx every 250 mS
void connectToWiFi()
int TryCount = 0;
//log_i( "connect to wifi" );
while ( WiFi.status() != WL_CONNECTED )
TryCount++;
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
vTaskDelay( 4000 );
if ( TryCount == 10 )
ESP.restart();
WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void connectToMQTT()
MQTTclient.setKeepAlive( 90 ); // needs be made before connecting
byte mac[5];
WiFi.macAddress(mac);
String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
// boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password, NULL , 1, true, NULL );
vTaskDelay( 250 );
MQTTclient.setCallback( mqttCallback );
MQTTclient.subscribe( topicOK );
} // void connectToMQTT()
void loop() {}
Good luck.
Online MQTT Broker (server) or you can run your own MQTT Broker on a PC?
Please do you have any idea how to my pc build MQTT server please give me the some documents.
What were your results when you tried using the words "eclipse mqtt broker" in an internet search? When I did a internet search I found lots of documentation on how to build a MQTT Broker on a PC.
You should be able to run MQTT broker on a Raspberry Pi - plenty of online resources.
I found so many tutorial but I am don't understand, how to build my pc MQTT server so please do you have any Idea MQTT server?
I found MQTT Explore : http://mqtt-explorer.com/
I am try to later Raspberry Pi, because now our invest Original Ethernet sheld2 Italian or Mega 2560 modal hardware so I am now start our in this hardware.
So do you have any idea share me? pc build MQTT server.
Have you tried using the words "installing mqtt broker onto a pc"?
MQTT explorer is NOT a MQTT Broker.
Please tell me details ?
Did you click clicky on the link I last posted? Did you follow those details?
OK I will try
But where I am configure my IP ?
At the place where you connect to the MQTT Broker using the pubsubclient library, using the connection function like so: MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password, NULL , 1, true, NULL );
You can use the network name of the PC that is running MQTT Broker or the IP address to connect to the MQTT Broker. What is the name of the computer where you installed MQTT Broker onto?
Any Body Help me this projects MQTT server control any where ?
File here ?Newtech_Home_Automation_V_4.02_Mega_2560_Tested_OK.ino (11.1 KB)
Processing: index.htm...
<!DOCTYPE html>
<html>
<head>
<head>
<title>Newtech_Home_Automation</title>
</head>
<body>
<table width = "100%" border = "0">
<tr>
<td colspan = "2" bgcolor = "#b5dcb3">
<img src="Home Automation_Logo.GIF" alt="Paris" style="width:100%;">
<h2 style='font-size:25px;color:blue;text-align:center;'>Newtech Smart Home Automation Web System</h2>
</td>
</tr>
<tr>
<body>
<style>
h1 {
text-align: center;
body {
background-color: #E6E6FA;
</style>
<script>
strLED = "";
function GetArduinoIO()
nocache = "&nocache=" + Math.random() * 1000000;
var request = new XMLHttpRequest();
request.onreadystatechange = function()
if (this.readyState == 4) {
if (this.status == 200) {
if (this.responseXML != null) {
// XML file received - contains LED states
var re;
var num_LEDs;
var i;
var ledstr = "";
re = this.responseXML.getElementsByTagName('LED');
num_LEDs = re.length;
for (i = 0; i < num_LEDs; i++) {
ledstr = "LED" + (i + 1);
if (re[i].childNodes[0].nodeValue === "checked") {
document.getElementsByName(ledstr)[0].checked = true;
else {
document.getElementsByName(ledstr)[0].checked = false;
// send HTTP GET request with LEDs to switch on/off if any
request.open("GET", "ajax_inputs" + strLED + nocache, true);
request.send(null);
setTimeout('GetArduinoIO()', 1000);
strLED = "";
// service LEDs when checkbox checked/unchecked
function GetCheck(led_num_str, cb)
if (cb.checked) {
strLED += ("&" + led_num_str + "=1");
else {
strLED += ("&" + led_num_str + "=0");
</script>
<style>
.out_box {
float: left;
margin: 0 20px 20px 0;
border: 2px solid blue;
padding: 0 5px 0 5px;
min-width: 280px;
input {
margin: 10px;
input {
vertical-align: -3px;
h1 {
font-size: 120%;
color: blue;
margin: 0 0 10px 0;
h2 {
font-size: 85%;
color: #5734E6;
margin: 5px 0 5px 0;
p, form, button {
font-size: 80%;
color: #252525;
.small_text {
font-size: 70%;
color: #737373;
</style>
</head>
<body onload="GetArduinoIO()">
<div class="out_box">
<form class="check_LEDs" name="LED_form6">
<h2 style='font-size:15px;color:red;text-align:center;'>Monitoring Control Panel</h2>
<style>
@keyframes example {
from {color: yellow;}
to {color: green;}
h1 {
animation-name: example;
animation-iteration-count: infinite;
animation-duration: 1s;
color: red;
</style>
<body>
<h1>System Is Running !!</h1>
</body>
<script>
function updateOnlineStatus() {
document.getElementById("status").innerHTML = "System Internet Online";
function updateOfflineStatus() {
document.getElementById("status").innerHTML = "System Internet Offline";
window.addEventListener('online', updateOnlineStatus);
window.addEventListener('offline', updateOfflineStatus);
</script>
</head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/4.7.0/css/font-awesome.min.css">
<body>
<h1 id="status">System Internet Online <i class="fa fa-wifi" style="font-size:20px;color:green"></i></h1>
</body>
<!-- weather widget start --><a target="_blank" href="https://www.booked.net/weather/dhaka-2125"><img src="https://w.bookcdn.com/weather/picture/12_2125_1_1_2071c9_118_2071c9_ffffff_ffffff_3_2071c9_ffffff_0_6.png?scode=124&domid=w209&anc_id=84209" alt="booked.net"/> </a><!-- weather widget end -->
<h2 style='font-size:15px;color:red'> Syetem Temp: 0:0℃</h2>
<h2 style='font-size:10px;color:green'>Motion Sensor1 Not Dedect!!</h2>
<h2 style='font-size:10px;color:green'>Motion Sensor2 Not Dedect!!</h2><br />
<h2 style='font-size:10px;color:green'>Fire Sensor1 Not Dedect!!</h2>
<h2 style='font-size:10px;color:green'>Fire Sensor2 Not Dedect!!</h2>
</form>
</div>
<form class="check_LEDs" name="LED_form1">
<h2 style='font-size:15px;color:red;text-align:center;'>Main Power Control Panel (1)</h2>
<input type="checkbox" name="LED1" value="0" onclick="GetCheck('LED1', this)" />Main Meter 1 (D26)
<input type="checkbox" name="LED2" value="0" onclick="GetCheck('LED2', this)" />Sub Meter 2 (D27)<br />
<input type="checkbox" name="LED3" value="0" onclick="GetCheck('LED3', this)" />Main Switch 3 (D28)
<input type="checkbox" name="LED4" value="0" onclick="GetCheck('LED4', this)" />Main Gate 4 (D29)
</form>
</div>
<form class="check_LEDs" name="LED_form2">
<h2 style='font-size:15px;color:red;text-align:center;'>Control Panel (2)</h2>
<input type="checkbox" name="LED5" value="0" onclick="GetCheck('LED5', this)" />LED 5 (D30)
<input type="checkbox" name="LED6" value="0" onclick="GetCheck('LED6', this)" />LED 6 (D31)<br />
<input type="checkbox" name="LED7" value="0" onclick="GetCheck('LED7', this)" />LED 7 (D32)
<input type="checkbox" name="LED8" value="0" onclick="GetCheck('LED8', this)" />LED 8 (D33)
</form>
</div>
<form class="check_LEDs" name="LED_form3">
<h2 style='font-size:15px;color:red;text-align:center;'>Control Panel (3)</h2>
<input type="checkbox" name="LED9" value="0" onclick="GetCheck('LED9', this)" />LED 9 (D34)
<input type="checkbox" name="LED10" value="0" onclick="GetCheck('LED10', this)" />LED 10 (D35)<br />
<input type="checkbox" name="LED11" value="0" onclick="GetCheck('LED11', this)" />LED 11 (D36)
<input type="checkbox" name="LED12" value="0" onclick="GetCheck('LED12', this)" />LED 12 (D37)
</form>
</div>
<form class="check_LEDs" name="LED_form4">
<h2 style='font-size:15px;color:red;text-align:center;'>Control Panel (4)</h2>
<input type="checkbox" name="LED13" value="0" onclick="GetCheck('LED13', this)" />LED 13 (D38)
<input type="checkbox" name="LED14" value="0" onclick="GetCheck('LED14', this)" />LED 14 (D39)<br />
<input type="checkbox" name="LED15" value="0" onclick="GetCheck('LED15', this)" />LED 15 (D40)
<input type="checkbox" name="LED16" value="0" onclick="GetCheck('LED16', this)" />LED 16 (D41)
</form>
</div>
<form class="check_LEDs" name="LED_form5">
<h2 style='font-size:15px;color:red;text-align:center;'>Control Panel (5)</h2>
<input type="checkbox" name="LED17" value="0" onclick="GetCheck('LED17', this)" />LED 17 (D42)
<input type="checkbox" name="LED18" value="0" onclick="GetCheck('LED18', this)" />LED 18 (D43)<br />
<input type="checkbox" name="LED19" value="0" onclick="GetCheck('LED19', this)" />LED 19 (D44)
<input type="checkbox" name="LED20" value="0" onclick="GetCheck('LED20', this)" />LED 20 (D45)
</form>
</div>
<h2 style='font-size:15px;color:red;text-align:center;'>Control Panel (6)</h2>
<input type="checkbox" name="LED21" value="0" onclick="GetCheck('LED21', this)" />LED 21 (D46)
<input type="checkbox" name="LED22" value="0" onclick="GetCheck('LED22', this)" />LED 22 (D47)<br />
<input type="checkbox" name="LED23" value="0" onclick="GetCheck('LED23', this)" />LED 23 (D48)
<input type="checkbox" name="LED24" value="0" onclick="GetCheck('LED24', this)" />LED 24 (D49)
</form>
</div>
</body>
<tr>
<center>
<h2 style = text-align:center;color:DarkGreen;font-size:12px;> Copyright © Verson - (4.02) April - 2020</h2>
<h2 style = text-align:center;color:DarkGreen;font-size:12px;>© Newtech Technologies | All Rights Reserved</h2>
<h2 style = text-align:center;color:Red;font-size:15px;>Our Help Line : +8801720037200 / +8801618884010 / +8801618884009 / Email ID : giashsmart@gmail.com</h2>
</center>
<tr>
</html>
See where I use the variable mqtt_server as the name or IP address of the MQTT Broker as part of the initialization?
