Hello friends.
Since 3 days i am fighting with this problem and i cant figure out what the problem is.
I am simply collecting my temp. and humidity at 2 different places. To do so, i am using MQTT
The problem: I have 2 MC. Both are sending data to different topics on MQTT.
Both are subscribing to different topics on MQTT ( to make the
MC parameterizable)
When 1 MC is connected, everything is fine. But when both MC are connected everything went downhill and i cant figure out why. It took me 2 days to recognize that somehow they cause the problem when both are connected to LAN. I cant even articulate what the problem my be.
Here is my (simplyfied code)
#define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT
#define ETH_PHY_POWER 12
#include <ETH.h>
//#include <ESP32Ping.h>
#include <WiFi.h>
#include "time.h"
#include <EEPROM.h>
#include "ESP32_MailClient.h"
#include <Preferences.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Smoothed.h> // Include the library
#include "globals.h"
#include "DHT.h"
#include <SPI.h>
#include <PubSubClient.h>
//String Company = "Test1";
String Company = "Test2";
#define POWER_SENSE 39
#define BATTERY 35
#define DHTPIN 1
#define DHTTYPE DHT11
// To send Emails using Gmail on port 465 (SSL), you need to create an app password: https://support.google.com/accounts/answer/185833
#define emailSenderAccount "hello@hello.com"
#define emailSenderPassword "password"
#define smtpServer "smtp.office365.com"
#define smtpServerPort 587
#define emailSubject "[ALERT] "
#define emailSenderAccount_mon "hello@hello.com"
#define emailSenderPassword_mon "password"
#define smtpServer_mon "smtp.office365.com"
#define smtpServerPort_mon 587
#define emailSubject_mon "[MONITORING] "
//topics send to mqtt
String topic_macadress = Company + "/data/macadress";
String topic_devicename = Company + "/data/devicename";
String topic_status = Company + "/data/status";
String topic_timestamp = Company + "/data/timestamp";
String topic_temperature = Company + "/data/temperature";
String topic_huminity = Company + "/data/huminity";
String topic_flood = Company + "/data/flood";
String topic_battery = Company + "/data/battery";
//topics listen from mqtt
//Subscribe to monitoring Email
String topic_mo_header = Company + "/form/mo_header";
String topic_mo_time = Company + "/form/mo_time";
String topic_mo_rec1 = Company + "/form/mo_rec1";
String topic_mo_rec2 = Company + "/form/mo_rec2";
String topic_mo_rec3 = Company + "/form/mo_rec3";
String topic_mo_rec4 = Company + "/form/mo_rec4";
String topic_mo_onoff = Company + "/form/mo_onoff";
// Subscribe to alert Email;
String topic_al_header = Company + "/form/al_header";
String topic_al_rec1 = Company + "/form/al_rec1";
String topic_al_rec2 = Company + "/form/al_rec2";
String topic_al_rec3 = Company + "/form/al_rec3";
String topic_al_rec4 = Company + "/form/al_rec4";
String topic_al_onoff = Company + "/form/al_onoff";
//Subscribe to input
String topic_t_min = Company + "/form/t_min";
String topic_t_max = Company + "/form/t_max";
String topic_h_min = Company + "/form/h_min";
String topic_h_max = Company + "/form/h_max";
/*****Objects*****/
Preferences preferences;
DHT dht(DHTPIN, DHTTYPE);
long lastMsg = 0;
static char macadress[20];
uint32_t statusbuffer;
static char timebuffer[100];
float temperature = 0;
float temperature_last = 0;
float huminity = 0;
float huminity_last = 0;
bool flood = false;
int battery;
/********helpers*****/
static bool eth_connected = false;
// Flag variable to keep track if email notification and SMS notification was sent or not
bool emailSent_temp = false;
bool emailSent_hum = false;
bool smsSent = false;
bool monitoringSent = false;
static int counter = 0;
static int counter_mon = 0;
static int counter_sms = 0;
String emailMessage;
//-----------------T I M E------------------------------
// Variables to save date and time
String formattedDate;
String dayStamp;
String timeStamp;
//struct tm tmS;
//const char* const PROGMEM ntpServer[] = {"fritz.box", "de.pool.ntp.org", "at.pool.ntp.org", "ch.pool.ntp.org", "ptbtime1.ptb.de", "europe.pool.ntp.org"};
const char* ntpServer = "pool.ntp.org";//"at.pool.ntp.org";
const long gmtOffset_sec = 5;
const int daylightOffset_sec = 3600;
const char* TZ_INFO = "CET-1CEST-2,M3.5.0/02:00:00,M10.5.0/03:00:00";
//*******functions*****/
void ReadSensorData_Temp_Hum();
void getTime();
float RandomFloat(float, float);
void checkIfDeviceParameter();
void save_settings_pref(String, String);
String get_settings_pref(String);
void InitialisizeMemberVariabelWith_EPROM_Values();
bool sendEmailNotification(String emailMessage);
void sendCallback(SendStatus msg);
void printLocalTime();
void checkIfDeviceIsOnline();
Smoothed <float> tempSensor;
class MonitoringEmail { // The class
public: // Access specifier
String Header; // Attribute (string variable)
String Time;
String Email_I;
String Email_II;
String Email_III;
String Email_IV;
String OnOff;
class AlertEmail { // The class
String Email_I;
String Email_II;
String Email_III;
String Email_IV;
String OnOff;
class Input { // The class
String temp_min; // Attribute (string variable)
String temp_max;
String hum_min;
String hum_max;
MonitoringEmail monitoringEmail;
AlertEmail alertEmail;
Input input;
// The Email Sending data object contains config and data to send
SMTPData smtpData;
void callback(char* topic, byte* message, unsigned int length) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
String messageTemp;
for (int i = 0; i < length; i++) {
Serial.print((char)message[i]);
messageTemp += (char)message[i];
//MonitoringEmail
if (String(topic) == topic_mo_header) {
monitoringEmail.Header = messageTemp;
save_settings_pref("monHeader",monitoringEmail.Header);
if (String(topic) == topic_mo_time) {
monitoringEmail.Time = messageTemp;
save_settings_pref("monTime",monitoringEmail.Time);
if (String(topic) == topic_mo_rec1) {
monitoringEmail.Email_I = messageTemp;
save_settings_pref("monEmail_I",monitoringEmail.Email_I);
if (String(topic) == topic_mo_rec2) {
monitoringEmail.Email_II = messageTemp;
save_settings_pref("monEmail_II",monitoringEmail.Email_II);
if (String(topic) == topic_mo_rec3) {
monitoringEmail.Email_III = messageTemp;
save_settings_pref("monEmail_III",monitoringEmail.Email_III);
if (String(topic) == topic_mo_rec4) {
monitoringEmail.Email_IV = messageTemp;
save_settings_pref("monEmail_IV",monitoringEmail.Email_IV);
if (String(topic) == topic_mo_onoff) {
monitoringEmail.OnOff = messageTemp;
save_settings_pref("monOnOff",monitoringEmail.OnOff);
//AlertEmail
if (String(topic) == topic_al_header) {
alertEmail.Header = messageTemp;
save_settings_pref("alertHeader",alertEmail.Header);
if (String(topic) == topic_al_rec1) {
alertEmail.Email_I = messageTemp;
save_settings_pref("alertEmail_I",alertEmail.Email_I);
if (String(topic) == topic_al_rec2) {
alertEmail.Email_II = messageTemp;
save_settings_pref("alertEmail_II",alertEmail.Email_II);
if (String(topic) == topic_al_rec3) {
alertEmail.Email_III = messageTemp;
save_settings_pref("alertEmail_III",alertEmail.Email_III);
if (String(topic) == topic_al_rec4) {
alertEmail.Email_IV = messageTemp;
save_settings_pref("alertEmail_IV",alertEmail.Email_IV);
if (String(topic) == topic_al_onoff) {
alertEmail.OnOff = messageTemp;
save_settings_pref("alertOnOff",alertEmail.OnOff);
//InputFORM_Input/TempMin
if (String(topic) == topic_t_min) {
input.temp_min = messageTemp;
save_settings_pref("inputTMin",input.temp_min);
if (String(topic) == topic_t_max) {
input.temp_max = messageTemp;
save_settings_pref("inputTMax",input.temp_max);
if (String(topic) == topic_h_min) {
input.hum_min = messageTemp;
save_settings_pref("inputHMin",input.hum_min);
if (String(topic) == topic_h_max) {
input.hum_max = messageTemp;
save_settings_pref("inputHMax",input.hum_max);
IPAddress server(111, 222, 3, 14);
WiFiClient espClient;
PubSubClient mqttClient(server, 1883, callback, espClient);
long lastReconnectAttempt = 0;
char msg[50];
int value = 0;
void reconnect() {
// Loop until we're reconnected
while (!mqttClient.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (mqttClient.connect("mqtt_ids", "user", "password")) {
Serial.println("connected");
// Subscribe to monitoring Email
mqttClient.subscribe(topic_mo_header.c_str());
mqttClient.subscribe(topic_mo_time.c_str());
mqttClient.subscribe(topic_mo_rec1.c_str());
mqttClient.subscribe(topic_mo_rec2.c_str());
mqttClient.subscribe(topic_mo_rec3.c_str());
mqttClient.subscribe(topic_mo_rec4.c_str());
mqttClient.subscribe(topic_mo_onoff.c_str());
mqttClient.subscribe(topic_al_header.c_str());
mqttClient.subscribe(topic_al_rec1.c_str());
mqttClient.subscribe(topic_al_rec2.c_str());
mqttClient.subscribe(topic_al_rec3.c_str());
mqttClient.subscribe(topic_al_rec4.c_str());
mqttClient.subscribe(topic_al_onoff.c_str());
mqttClient.subscribe(topic_t_min.c_str());
mqttClient.subscribe(topic_t_max.c_str());
mqttClient.subscribe(topic_h_min.c_str());
mqttClient.subscribe(topic_h_max.c_str());
else {
Serial.print("failed, rc=");
Serial.print(mqttClient.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_ETH_START:
Serial.println("ETH Started");
//set eth hostname here
ETH.setHostname("esp32-ethernet");
case SYSTEM_EVENT_ETH_CONNECTED:
Serial.println("ETH Connected");
case SYSTEM_EVENT_ETH_GOT_IP:
Serial.print("ETH MAC: ");
Serial.print(ETH.macAddress());
Serial.print(", IPv4: ");
Serial.print(ETH.localIP());
if (ETH.fullDuplex()) {
Serial.print(", FULL_DUPLEX");
Serial.print(", ");
Serial.print(ETH.linkSpeed());
Serial.println("Mbps");
eth_connected = true;
case SYSTEM_EVENT_ETH_DISCONNECTED:
Serial.println("ETH Disconnected");
case SYSTEM_EVENT_ETH_STOP:
Serial.println("ETH Stopped");
default:
void testClient(const char * host, uint16_t port)
Serial.print("\nconnecting to ");
Serial.println(host);
WiFiClient client;
if (!client.connect(host, port)) {
Serial.println("connection failed");
return;
client.printf("GET / HTTP/1.1\r\nHost: %s\r\n\r\n", host);
while (client.connected() && !client.available());
while (client.available()) {
Serial.write(client.read());
Serial.println("closing connection\n");
client.stop();
void setup(){
WiFi.onEvent(WiFiEvent);
Serial.print("Connecting ");
ETH.begin();
delay(3000);
pinMode (POWER_SENSE, INPUT);
pinMode (BATTERY, INPUT);
tempSensor.begin(SMOOTHED_AVERAGE, 10);
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
setenv("TZ", TZ_INFO, 1);
Serial.println("WiFi or ETH connected.");
Serial.println("Use this URL to connect: http://" + ETH.localIP().toString() + "/"); // Print the IP address
mqttClient.connect("server", "user", "password");
dht.begin();
mqttClient.setCallback(callback);
if (!mqttClient.connected()) {
reconnect();
mqttClient.loop();
long now = millis();
if (now - lastMsg > 5000) {
// Convert the temperature to a char array
char tempString[8];
dtostrf(temperature, 1, 2, tempString);
// Convert the huminity to a char array
char statusbufferString[8];
dtostrf(statusbuffer, 1, 2, statusbufferString);
char huminityString[8];
dtostrf(huminity, 1, 2, huminityString);
//Convert the flood to a char array
char floodString[8];
dtostrf(flood, 1, 2, floodString);
char batteryString[8];
dtostrf(battery, 1, 2, batteryString);
mqttClient.publish(topic_macadress.c_str(),macadress);
mqttClient.publish(topic_devicename.c_str(),Company.c_str());
mqttClient.publish(topic_status.c_str(),statusbufferString);
mqttClient.publish(topic_timestamp.c_str(),timebuffer);
mqttClient.publish(topic_temperature.c_str(),tempString);
mqttClient.publish(topic_huminity.c_str(),huminityString);
mqttClient.publish(topic_flood.c_str(),floodString);
mqttClient.publish(topic_battery.c_str(),batteryString);
lastMsg = now;
//##################### F U N C T I O N S #########################################//
float RandomFloat(float a, float b) {
float random = ((float) rand()) / (float) RAND_MAX;
float diff = b - a;
float r = random * diff;
return a + r;
delay(2000);
huminity = dht.readHumidity();
delay(2000);
temperature = dht.readTemperature();
//temperature = RandomFloat(24.5,24.6);
// Check if any reads failed and exit early (to try again).
if (isnan(huminity) || isnan(temperature)) {
Serial.println(F("Failed to read from DHT sensor!"));
huminity = huminity_last;
temperature = temperature_last;
return;
huminity_last = huminity;
temperature_last = temperature;
void save_settings_pref(String key, String value){
preferences.begin("input_settings",0);
preferences.putString(key.c_str(),value);
preferences.end();
//monitoring-Email
monitoringEmail.Header = get_settings_pref("monHeader");
monitoringEmail.Time = get_settings_pref("monTime");
monitoringEmail.Email_I = get_settings_pref("monEmail_I");
monitoringEmail.Email_II = get_settings_pref("monEmail_II");
monitoringEmail.Email_III = get_settings_pref("monEmail_III");
monitoringEmail.OnOff = get_settings_pref("monOnOff");
//Alert-Email
alertEmail.Header = get_settings_pref("alertHeader");
alertEmail.Email_I = get_settings_pref("alertEmail_I");
alertEmail.Email_II = get_settings_pref("alertEmail_II");
alertEmail.Email_III = get_settings_pref("alertEmail_III");
alertEmail.OnOff = get_settings_pref("alertOnOff");
//Input
input.temp_min = get_settings_pref("inputTMin");
input.temp_max = get_settings_pref("inputTMax");
input.hum_min = get_settings_pref("inputHMin");
input.hum_max = get_settings_pref("inputHMax");
String get_settings_pref(String key){
String returnvL;
returnvL = preferences.getString(key.c_str(),"");
preferences.end();
return returnvL;
It kinda seems, when both MCs are connected, the connection to the MQTT broker fails.
I hope someone has an idea. I gave 1 MC the company-name "Test1" and the other "Test2". So the published and subscribed topics should always be different.
thank you
