MQTT Pubsubclient library - message queue
Hello!
These days I tested how to integrate Arduino into MQTT, how to publish and how to subscribe to a topic.
For the most part, it's fine, I succeeded, but I'm facing a problem.
For example, in MQTT, the current hour, minute and second are published on a topic (with a frequency of once per second).
In arduino, due to the fact that the loop has a delay of, let's say 1.5 seconds or 2 seconds, when it reads the hour, minute and second from MQTT, at some point it ends up falling behind, because arduino seems to read all the old messages that were published on that topic, and not just the last message. As if these messages are somewhere in a queue, and the arduino reads them in turn.
If I stop the publication of the clock on that topic, the arduino reads all the messages until the moment I stop the publication. The behavior I want is for the arduino to read only the last message published there, and not the entire history, so the clock stays in sync. I need this functionality, not only for the clock, but also for other applications that require publishing data in mqtt very often, in which case I want the arduino to read my last message.
If I publish less often than the speed of the loop, the problem obviously disappears. But this is not a solution.
I tried to play with QOS or retain flag, but it doesn't solve the problem.
Is there a setting somewhere in the library where it can be set not to do message queing?
Thank you in advance for your answer!
Adrian.
Your topic was MOVED to its current forum category which is more appropriate than the original
The obvious answer is to eliminate the delay in loop(). What is causing it ?
Show us your code.
I can't because it has work to do, sensors to read, etc :slight_smile: I am reading data from a solar inverter, and from 2 smart meters, and that requires time, can't do this without some delay...
As requested, please post your code
using millis() for delay does not cause the same do nothings as does using delay().
Look at File|Examples|02.Digital|BlinkWithoutDelay to use millis() for timing instead of delay().
I've never had my MQTT Broker retain payload history.
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include <PubSubClient.h>
const char* mqttServer = "x.x.x.x";
const int mqttPort = 1883;
const char* mqttUser = "xxxx";
const char* mqttPassword = "xxxxx";
const char* ssid = "xx";
const char* password = "xxxxx";
String serverName = "http://x.x.x.x/test/add_data.php?";
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 5 seconds (5000)
unsigned long timerDelay = 20000;
int var1, var2, var3, var4;
float fvar1;
int  valint1, valint2, valint3;
float valfloat1, valfloat2, valfloat3;
int cday, chour, cminutes, cseconds;
int day_value, h_value, min_value, sec_value ;
//char cdy[8];
char ch[8];
char cmin[8];
char csec[8];
WiFiClient espClient;
PubSubClient client(espClient);
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
  while(WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  client.setServer(mqttServer, mqttPort);
  client.setCallback(callback);
  Serial.println("Connecting to MQTT...");
  if (client.connect("ESP8266Client", mqttUser, mqttPassword )) {
    Serial.println("connected");
       Serial.print("failed with state ");
      Serial.print(client.state());
      delay(2000);
    client.subscribe("homeassistant/datetime/day");
    client.subscribe("homeassistant/datetime/hour");
    client.subscribe("homeassistant/datetime/minutes");
    client.subscribe("homeassistant/datetime/seconds");
void callback(char* topic, byte* payload, unsigned int length) {
    String messageDay;
    String messageHour;
    String messageMinutes;
    String messageSeconds;
    if (strcmp(topic,"homeassistant/datetime/day") == 0){
       for (int i=0;i<length;i++) {
                                     messageDay += (char)payload[i];
       day_value = messageDay.toInt();
  if (strcmp(topic,"homeassistant/datetime/hour") == 0){
                                  messageHour += (char)payload[i];
       h_value = messageHour.toInt();
     if (strcmp(topic,"homeassistant/datetime/minutes") == 0){
                                  messageMinutes += (char)payload[i];
       min_value = messageMinutes.toInt();
   if (strcmp(topic,"homeassistant/datetime/seconds") == 0){
                                  messageSeconds += (char)payload[i];
        sec_value = messageSeconds.toInt();
   transmitdata();
     var1 = -1159;
    fvar1 = 99545.2;
    var2 = 35;
    var3 = 45;
    var4 = 55;
    delay(1000); // this is where I induce the delay...
        Serial.print("Current day is:");
        Serial.println(day_value);
        Serial.println("Current time is:");
        Serial.print(h_value);
        Serial.print(":");
        Serial.print(min_value);
        Serial.print(":");
        Serial.print(sec_value);
    client.loop();
void transmitdata() { // function that posts some data to mysql server
  // Send an HTTP POST request depending on timerDelay
  if ((millis() - lastTime) > timerDelay) {
    //Check WiFi connection status
    if(WiFi.status()== WL_CONNECTED){
      WiFiClient client;
      HTTPClient http;
      String add_data = serverName;
      add_data += "var1=";
      add_data += var1;
      add_data += "&";
      add_data += "var2=";
      add_data += var2;
      add_data += "&";
      add_data += "var3=";
      add_data += var3;
      add_data += "&";
      add_data += "var4=";
      add_data += var4;
      // Your Domain name with URL path or IP address with path
      http.begin(client, add_data.c_str());
      // Send HTTP GET request
      int httpResponseCode = http.GET();
      // Free resources
      http.end();
   lastTime = millis();
I know delay is bad (but this is not the original code, I can't test the code live, that's why I induce the delay manually. Everytime I test something new, I test with a blank code and a new nodemcu to see how and if it works as desired. I know that is a delay, and can't do nothing about it, trust me. The original reads from 3 serials, one serial is the inverter, and the other 2 is a RS485 communication with 2 smart meters. There is no way I can read this instantaneously...
Trust us this delay is not needed.
unsigned long OneKDelay = 1000;
unsigned long PastOneKTime = millis();
float fvar1;
//char cdy[8];
char ch[8];
char cmin[8];
char csec[8];
    Serial.print(".");
  Serial.println("");
    delay(2000);
  String messageDay;
  String messageHour;
  if (strcmp(topic, "homeassistant/datetime/day") == 0) {
    for (int i = 0; i < length; i++) {
  if (strcmp(topic, "homeassistant/datetime/hour") == 0) {
  if (strcmp(topic, "homeassistant/datetime/minutes") == 0) {
  if (strcmp(topic, "homeassistant/datetime/seconds") == 0) {
  transmitdata();
  var1 = -1159;
  fvar1 = 99545.2;
  var2 = 35;
  var3 = 45;
  var4 = 55;
  if ( (millis() - PastOneKTime) >= OneKDelay )
    ///delay(1000); // this is where I induce the delay...
    Serial.print(":");
    Serial.print(":");
  client.loop();
    if (WiFi.status() == WL_CONNECTED) {
      WiFiClient client;
      HTTPClient http;
      add_data += var1;
      add_data += "&";
      add_data += var2;
      add_data += "&";
      add_data += var3;
      add_data += "&";
      add_data += var4;
      // Free resources
      http.end();
that does not delay printing by one second?
Also doing a client loop without a WiFi connected test and a MQTT connected test is not wise.
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  // setting must be set before a mqtt connection is made
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
    vTaskDelay( 250 ); //task runs approx every 250 mS
  vTaskDelete ( NULL );
extracting payload messages
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
  x_message.topic = ""; //clear topic string buffer
  x_message.topic = topic; //store new topic
  memcpy( x_message.payload, payload, length );
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
don't need those for loop to extract payload data. for loops are slow.
Agreed. As far as I know, MQTT is "memoryless", messages from the broker to the client are not "queued". There is one exception ... messages published with the "retain" flag allow the last (and only last) message published to a topic to be downloaded when the client reconnects.
It's also not necessary to have your callback() function convert the c-string message to a String object just to then convert it to an integer. That's rather convoluted.
Why in the world are you doing that to begin with? The ESP8266 has a built-in RTC and access to NTP servers. It can always know the time without subscribing to an MQTT "Time' topic.
[/quote]
[/quote]
Ok. ESP has built-in RTC, but what about ArduinoMEGA2560 ?:slight_smile:
As I sayd before, ignore the time example. let's pretend it's not the time in the topic, it's the available power from my solar panels to pass it directly and fast to the SSR of the boiler.
This value changes often and it must be read as fast as I can (and it should read the LAST message, not the whole history :slight_smile: I consider that my question was not answered... why is this behaviour... thus I will make the suggested changes from the posts above, but I am afraid the problem is still there...
Thank you!
What MQTT broker are you using that is apparently queuing the messages? Have you inquired with their Tech Support about the behavior?
I use mosquitto, on my linux server. I did not spoke to their tech support, since I was convinced it is arduino related :slight_smile: but...should I ?
With everything being under your control, it seems a logical place to start would be checking the broker's settings and logs.
Looking through the PubSubClient library's source code, I could find no place where it is queuing messages.
Install a MQTT client in your PC and subscribe for the same topics and check if you will receive this message history too.
something like MQTT.fx would do the trick. MQTT.fx® 5.0 – Softblade and be a 3rd party confirmation that a MQTT Broker can now retain multiple messages.
