MQTT Subscribing is not working
Hi Experts,
I have arduino Mega and Ethernet shield, want to run MQTT publish and subscribe examples.
Uploaded the below code into arduino board and trying to send/receive the data in ubunut linux PC (also tried raspberry pi).
Arduino MQTT publisher is working (Linux PC is Subscriber here) :
linux-host$ mosquitto_sub -t outTopic -h 192.168.0.123
Arduino MQTT subscriber is not working (Linux PC is Publisher here) :
linux-host$ mosquitto_pub -t inTopic -h 192.168.0.110 -m 1
I have attached the code. Can you please help me on this ?
 Publishing in the callback
  - connects to an MQTT server
  - subscribes to the topic "inTopic"
  - when a message is received, republishes it to "outTopic"
  This example shows how to publish messages within the
  callback function. The callback function header needs to
  be declared before the PubSubClient constructor and the
  actual callback defined afterwards.
  This ensures the client reference in the callback function
  is valid.
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
//IPAddress ip(192, 168, 0, 110);
IPAddress server(192, 168, 0, 123);
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
EthernetClient ethClient;
PubSubClient client(server, 1883, callback, ethClient);
void callback(char* topic, byte* payload, unsigned int length) {
  // In order to republish this payload, a copy must be made
  // as the orignal payload buffer will be overwritten whilst
  // constructing the PUBLISH packet.
  // Allocate the correct amount of memory for the payload copy
  byte* p = (byte*)malloc(length);
  // Copy the payload to the new buffer
  memcpy(p,payload,length);
  client.publish("outTopic", p, length);
  // Free the memory
  free(p);
  Serial.println("Setup 2 is done!");
    // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for (;;)
  // print your local IP address:
  printIPAddress();
//  Ethernet.begin(mac, ip);
  if (client.connect("arduinoClient")) {
    client.publish("outTopic","hello world");
    client.subscribe("inTopic");
  Serial.println("Setup is done!");
  client.loop();
  delay(2000);
  Serial.println("Loop is running...");
void printIPAddress()
  Serial.print("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
Regards,
Titus S.
