For reading out sensors in a production environment, I need to transmit data via MQTTS. I did this before with an ESP32, using WifiSecureClient. For the connection, I need to provide authentication and a root certificate.
Now, I need to use an Arduino MKR Wifi 1010 device, as I intend to utilize the M-BUS shield for data readout of an energy meter. This part already works fine.
But, I have trouble to get MQTTS up and running. At the end I switched to the test.mosquitto.org MQTT server to test my sketch/code.
What I did so far:
1. upload of the root certificate:
I did this like described on the arduino website with help of the firmware updater and the root certificate uploader from the IDE 2.0.3. No errors occured during this operation.
I used test.mosquitto.org:8883 as address.
2. preparation of the sketch:
With the code below I managed to connect unencrypted to the mosquitto test server, with and without authentication. For that the port has to be changed to 1883 and the mqttClient uses the wifiClient, not the sslClient.
However, I didn't manage to connect with encryption (unauthenticated on port 8883), providing the root certificate on the device.
I always got error -2 after the connect attempts.
Is some reference required in the sketch / code to make it work? What am I making wrong??
I spent almost the complete day with this topic and am a bit frustrated about the missing results. I'd be very happy if someone has a solution!!
This is the code I used:
#include <ArduinoBearSSL.h>
#include <ArduinoECCX08.h>
#include <ArduinoMqttClient.h>
#include <WiFiNINA.h> // change to #include <WiFi101.h> for MKR1000
//#include "arduino_secrets.h"
/////// Enter your sensitive data in arduino_secrets.h
const char ssid[] = "SuperWifi";
const char pass[] = "***";
const char broker[] = "test.mosquitto.org";
const int port = 8883;
// const char* certificate = SECRET_CERTIFICATE;
WiFiClient wifiClient; // Used for the TCP socket connection
BearSSLClient sslClient(wifiClient); // Used for SSL/TLS connection, integrates with ECC508
MqttClient mqttClient(sslClient);
unsigned long lastMillis = 0;
while (!Serial);
if (!ECCX08.begin()) {
Serial.println("No ECCX08 present!");
while (1);
// Set a callback to get the current time
// used to validate the servers certificate
ArduinoBearSSL.onGetTime(getTime);
// Set the message callback, this function is
// called when the MQTTClient receives a message
mqttClient.onMessage(onMessageReceived);
if (WiFi.status() != WL_CONNECTED) {
connectWiFi();
if (!mqttClient.connected()) {
// MQTT client is disconnected, connect
connectMQTT();
// poll for new MQTT messages and send keep alive
mqttClient.poll();
// publish a message roughly every 5 seconds.
if (millis() - lastMillis > 5000) {
lastMillis = millis();
publishMessage();
unsigned long getTime() {
// get the current time from the WiFi module
return WiFi.getTime();
void connectWiFi() {
Serial.print("Attempting to connect to SSID: ");
Serial.print(ssid);
Serial.print(" ");
while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
// failed, retry
Serial.print(".");
delay(5000);
Serial.println("You're connected to the network");
void connectMQTT() {
Serial.print("Attempting to MQTT broker: ");
Serial.print(broker);
Serial.println(" ");
//mqttClient.setUsernamePassword("rw", "readwrite");
while (!mqttClient.connect(broker, port)) {
// failed, retry
Serial.print("connect error: ");
Serial.println(mqttClient.connectError());
delay(5000);
Serial.println("You're connected to the MQTT broker");
// subscribe to a topic
mqttClient.subscribe("arduinot/incoming");
void publishMessage() {
Serial.println("Publishing message");
// send message, the Print interface can be used to set the message contents
mqttClient.beginMessage("arduinot/outgoing");
mqttClient.print("hello ");
mqttClient.print(millis());
mqttClient.endMessage();
void onMessageReceived(int messageSize) {
// we received a message, print out the topic and contents
Serial.print("Received a message with topic '");
Serial.print(mqttClient.messageTopic());
Serial.print("', length ");
Serial.print(messageSize);
Serial.println(" bytes:");
// use the Stream interface to print the contents
while (mqttClient.available()) {
Serial.print((char)mqttClient.read());
