I need your help I received the Arduino UNO Board and trying to make a
project i.e. multi function(Mode) LED like ABCD I want to glow
A,B,C,D one by one then
Glow A on B,C,D off ,B on A,C,D Off so on..
Glow all A B C D slowely or light fade
I interfaced the Arduino with Matlab so in GUI I want to use 3 buttons
for this for each function
I don interfacing GUI(Matlab) and On Off program using push button but I am
not able to program the Button for One by One and fading please help me
Whenever a Matlab button is pressed, you write a command on the serial port. On the Arduino side, you receive bytes via Serial.available(), Serial.read(), and execute the commands sent by the Matlab program.
To fade a led use analogWrite() and cycle the pwm value between 0 and 255 and back to 0. To have a smooth fading try different increment / decrement values and different delays between those.
Please post the code so far (at least the Arduino code). Remember to hit CTRL+T inside the IDE and use the # button (code tags) to post the code here.
