The NodeMCU has the watchdog timer enabled by default. It will reset the timer after each return from loop. When you increase the loop function's execution time by setting the loop bound to 2 (now you have 100ms delay in your loop instead of 50ms), the watchdog will trigger, because it wasn't reset in time.
You can either remove the for loop and let the loop function be your for loop, or reset the watchdog manually inside the for loop.
LightuC:
I'm still got the same error when I put second ultrasonic.
groundFungus:
What change(s) did you make? When you change your code, post the new version so that we can keep up.
I try to deal with Watchdog by add-in setup() and loop().
#include <Wire.h> // use the Wire library
// connect address pins: A0=0 (GND), A1=0 (GND), A2=0 (GND)
//#define ADDR_BITS (0B000) // A0=0,A1=0,A2=0
//#define I2C_SLAVE_ADDR ((0B0111000) | ADDR_BITS) // 7-bit address
#define PCF8574_ADDR (0x20)
#define MAX_DISTANCE_IN_MM (4000) // max. valid value for distance
#define DURATION_TO_DISTANCE(x) ((17*(x))/100) // usec -> mm.
#define ECHOPIN D5 //(External Interrupt 0)
volatile uint32_t tH, tL, pulse_width = 0;
uint16_t dist_mm; // distance in mm.
char sbuf[32]; // used for sprintf()
ESP.wdtDisable();
ESP.wdtEnable(WDTO_8S); //WDTO_8S → https://github.com/esp8266/Arduino/blob/master/cores/esp8266/Esp.h
Wire.begin();
Wire.setClock(400000L);// for 400kHz
writeOutput(0xF0);
attachInterrupt(ECHOPIN , eint_isr, CHANGE );
Serial.begin( 115200 );
void writeOutput( byte value ) { // write one byte
Wire.beginTransmission( PCF8574_ADDR );
Wire.write( value );
Wire.endTransmission();
byte readInput( void ) { // read one byte
byte data = 0xff;
Wire.requestFrom( PCF8574_ADDR, 1 );
delayMicroseconds(4);
if ( Wire.available() ) {
data = Wire.read();
return data;
uint16_t read_ultrasonic_sensor( int pin ) {
writeOutput( 0xF0 | (1 << pin) );
writeOutput( 0xF0 );
pulse_width = 0;
while ( pulse_width == 0 ) {} // wait until pulse_width > 0
return DURATION_TO_DISTANCE( pulse_width );
for (int i = 0; i < 1; i++ ) {
dist_mm = read_ultrasonic_sensor( i );
if ( dist_mm > MAX_DISTANCE_IN_MM ) {
Serial.println( "Out of range." );
sprintf( sbuf, "Sensor %d, %d.%1d cm", i, (dist_mm / 10), (dist_mm % 10) );
Serial.println( sbuf );
delay(5);
ESP.wdtDisable();
// reset the watchdog
ESP.wdtFeed();
delay( 250 );
ESP.wdtFeed();
volatile uint32_t timestamp;
void eint_isr() { // ISR for Ext. Interrupt
timestamp = micros(); // read the timestamp (in microseconds)
if ( digitalRead( ECHOPIN ) == HIGH ) {
tH = timestamp;
} else { // LOW
tL = timestamp;
pulse_width = (tL - tH);
I decode error using EspExceptionDecoder.
Decoding stack results
0x40201936: eventTask at /Users/MolomitZ/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.0/cores/esp8266/core_esp8266_si2c.c line 519
0x4020340c: loop_task(ETSEvent*) at /Users/MolomitZ/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.0/cores/esp8266/core_esp8266_main.cpp line 133
0x4010149d: realloc at /Users/MolomitZ/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.0/cores/esp8266/umm_malloc/umm_malloc.c line 1628
