Hey guys, I have an AC dimmer created through this website: http://wiki.dxarts.washington.edu/groups/general/wiki/4dd69/
I hooked up a second breadboard with the exact same setup to try to have a second light bulb feed into it and gain control of each one individually, unfortunately I am stuck on the coding aspect it seems because I can get them to dim still but not individually. Right now I am testing it from pin 9 and 10 with just two to start but I am looking to have a good amount by the end.
On a side note... is this the best way to pursue this? Is there any way I could build a sort of switch on a seperate breadboard to do the switching? besides having the information parsed out 5 different times in the serial port like i have now coming from max.
lemme know!
AC Light Control
Updated by Robert Twomey <rtwomey@u.washington.edu>
Changed zero-crossing detection to look for RISING edge rather
than falling. (originally it was only chopping the negative half
of the AC wave form).
Also changed the dim_check() to turn on the Triac, leaving it on
until the zero_cross_detect() turns it off.
Attach AC_PIN output to optotriac input on circuit board.
Attach Zero Cross Detector output (on circuit board) to Pin 2 (interrupt 0)
optional LED to pin 3
Attach arduino GND to GND.
Attach arduino +5 to +5V.
Attach AC Hot (120v) to AC Hot wire on circuit board.
Attach AC Neutral to AC Neutral wire on circuit board.
Attach one wire from bulb to Bulb 1 on circuit board.
Attach other wire from bulb to Bulb 2 on circuit board (also AC neutral)
details here: http://wiki.dxarts.washington.edu/groups/general/wiki/4dd69/AC_Dimmer_Circuit.html
Thanks to http://www.andrewkilpatrick.org/blog/?page_id=445
and http://www.hoelscher-hi.de/hendrik/english/dimmer.htm
int dim2 = 0;
int dimLevel = 0;
int dimPick = 0;
int dimPinArray[] = {10,9,8,7,6};
volatile int dimIterArray[5];
int dimLevelArray[5];
unsigned char serIn;
#include <TimerOne.h> // Avaiable from http://www.arduino.cc/playground/Code/Timer1
volatile boolean zero_cross=0; // Boolean to store a "switch" to tell us if we have crossed zero
int AC_pin = 10; // Output to Opto Triac
int POT_pin = 0; // Pot for testing the dimming
int LED = 3; // LED for testing
int dim = 0; // Dimming level (0-128) 0 = on, 128 = 0ff
int freqStep = 65; // Set the delay for the frequency of power (65 for 60Hz, 78 for 50Hz) per step (using 128 steps)
// freqStep may need some adjustment depending on your power the formula
// you need to us is (500000/AC_freq)/NumSteps = freqStep
// You could also write a seperate function to determine the freq
void setup() { // Begin setup
pinMode(10, OUTPUT); // Set the Triac pin as output
pinMode(9, OUTPUT);
pinMode(LED, OUTPUT); // Set the LED pin as output
attachInterrupt(0, zero_cross_detect, RISING); // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
Timer1.initialize(freqStep); // Initialize TimerOne library for the freq we need
Timer1.attachInterrupt(dim_check, freqStep);
Serial.begin(19200);
// Use the TimerOne Library to attach an interrupt
// to the function we use to check to see if it is
// the right time to fire the triac. This function
// will now run every freqStep in microseconds.
void zero_cross_detect() {
zero_cross = true; // set the boolean to true to tell our dimming function that a zero cross has occured
for (int i=0; i<1; i++){
dimIterArray[i]=0;
digitalWrite(dimPinArray[i], LOW);
// Function will fire the triac at the proper time
void dim_check() {
if(zero_cross == true) {
if(dimIterArray[i]>=dimLevelArray[i]) {
digitalWrite(dimPinArray[i], HIGH);
dimIterArray[i]=0;
zero_cross = false;
else {
dimIterArray[i] = dimIterArray[i]+1;
serReadInt();
dimLevelArray[0] = 80;
dimLevelArray[1] = 120;
analogWrite(LED, dimIterArray[0]);
Serial.println(dimLevelArray[1]);
int serReadInt()
int i, serAva; // i is a counter, serAva hold number of serial available
char inputBytes[20];
char deviceId[20];
char dimLevel[20];
// Array hold input bytes
//char * inputBytesPtr = &inputBytes[0]; // Pointer to the first element of the array
char * deviceIdPtr = &deviceId[0];
char * dimLevelPtr = &dimLevel[0];
// char * inputBytesPtr2 = &inputBytes[2];
if (Serial.available()>0) // Check to see if there are any serial input
delay(5); // Delay for terminal to finish transmitted
// 5mS work great for 9600 baud (increase this number for slower baud)
serAva = Serial.available(); // Read number of input bytes
for (i=0; i<serAva; i++){ // Load input bytes into array
inputBytes[i] = Serial.read();
if (i<1){
deviceId[0] = inputBytes[0];
deviceId[1] = '\0';
else if (i>1){
dimLevel[i-2] = inputBytes[i];
dimLevel[i-1] = '\0';
dimPick = atoi(deviceIdPtr);
dim2 = atoi(dimLevelPtr);
dimLevelArray[dimPick] = dim2;
Serial.print(dimPick+" ");
Serial.println(dim2);
return -1; // Return -1 if there is no input
