Majority of i2c devices have a main address and then address of registers that store data.
I want to create an arduino i2c slave with the same config.
How can I have an arduino slave with multiple addresses each storing different values.
Thanks.
Thanks.
I've been playing with this for a while. Maybe these will help you. The master sends the slave a number from 0 to 3 over and over. The slave returns 2 byte registers from the "array" array.
I2C Master
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
Wire.beginTransmission(13); // transmit to device #13
Wire.write(x); // sends one byte
Wire.endTransmission(); // stop transmitting
delayMicroseconds(100);
if(Wire.requestFrom(13, 2) > 0) { // request 2 bytes from slave device #13
while(Wire.available()) // slave may send less than requested
char c = Wire.read(); // receive a byte as character
Serial.print(c,DEC); // print the character
Serial.print(" ");
else {
Serial.println(F("Fail"));
x++;
if(x > 3) x = 0;
I2C Slave
#include <Wire.h>
// these are the "registers"
byte array[8] = {2,4,6,8,10,12,14,16};
volatile byte regReq = 0;
volatile byte* rtnPtr;
Wire.begin(13);
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
void receiveEvent(int byteCount)
regReq = Wire.read();
rtnPtr = &array[regReq*2];
void requestEvent()
Wire.write((byte*)rtnPtr,2);
Hmm.. interesting method.
But i was looking for more like a one way communication, like in a mouse without the master "requesting" any thing, it just reads said registers.
ric96:
How would your slave arduino know which "register" to send?
ric96:
That's not how it works. You will have to send requests from the master to the slave. If you don't want to send requests from the master, I2C is not the right 'tool'.
You can obviously swap the functionalities around so what you call master now will be slave and vice versa and the new master just spits out data to the slave.
sterretje:
That's not how it works. You will have to send requests from the master to the slave. If you don't want to send requests from the master, I2C is not the right 'tool'.You can obviously swap the functionalities around so what you call master now will be slave and vice versa and the new master just spits out data to the slave.
What should i use then?
Depends, what EXACTLY are you trying to do?
Typical XY problem
