Multiple i2c writes on request
Hi
i ve trying since houres. Maybe a very simple mistake that i just don't see but i am really going crazy
Just request from clients 4 floats values... send them as 4 Byte array, and output them on Server on Serial Output after converting Bytearrays to Float
Server
union u_tag {
   byte b[4];
   float fval;
void clientRequest()    called in Loop
   Wire.requestFrom(8, 16);     // Request 16 bytes fromClient
   u_tag u1;
   u1.b[0] = Wire.read();
   u1.b[1] = Wire.read();
   u1.b[2] = Wire.read();
   u1.b[3] = Wire.read();
   Serial.println(u1.fval);
   u_tag u2;
   u2.b[0] = Wire.read();
   u2.b[1] = Wire.read();
   u2.b[2] = Wire.read();
   u2.b[3] = Wire.read();
   Serial.println(u2.fval);
   u_tag u3;
   u3.b[0] = Wire.read();
   u3.b[1] = Wire.read();
   u3.b[2] = Wire.read();
   u3.b[3] = Wire.read();
   Serial.println(u3.fval);
   u_tag u4;
   u4.b[0] = Wire.read();
   u4.b[1] = Wire.read();
   u4.b[2] = Wire.read();
   u4.b[3] = Wire.read();
   Serial.println(u4.fval);
Client
void requestEvent() {
  Wire.write((char*)&VOLTAGE1,sizeof(float));
  Wire.write((char*)&VOLTAGE2,sizeof(float));
  Wire.write((char*)&VOLTAGE3,sizeof(float));
  Wire.write((char*)&CURRENT,sizeof(float));
Serialoutput Server:
511.20
nan
nan
nan
511.20
nan
nan
nan
511.20 should be the last write value "CURRENT" from client.. but out put as first? if i decomment last write i already get that Value one bevore =>Voltage 3. but i never get all .. always just the last.. Any ideas????
Its should looks like that
12.52
24.54
23.29
511.20
12.52
24.54
23.29
511.20
regards
Peter
On the slave side, you need to place all the bytes to be sent in one buffer before sending it with Wire.write().
One way to do it is with a struct. Your receive sketch will work with this.
#include <Wire.h>
struct
  float Voltage1;
  float Voltage2;
  float Voltage3;
  float Current;
floatsToSend;
void requestEvent ()
  floatsToSend.Voltage1 = 12.52;
  floatsToSend.Voltage2 = 25.54;
  floatsToSend.Voltage3 = 23.29;
  floatsToSend.Current = 511.20;
  Wire.write((byte*)&floatsToSend, sizeof(floatsToSend));
  Wire.begin(8);
  Wire.onRequest(requestEvent);
void loop() {}
Thank you for response. Very good to know for next time
I already solved it one houre bevore with a workaround
First send ID of requested value to client and set ID in client
Second request value and client response value by ID set before
Server loop for each value
thanks peter
