multiple loops
Is there a way that I can have multiple loops, which each preform different functions, but the bit that I find hardest to figure out is if I can disable the loop functions to only be used when I need them, e.g. I apply a signal and there are 4 ways to modulate it, and currently I will have 4 different loops which provide modulation, but I want to be able to choose which modulation to activate, Is it possible to maybe call a desired loop?
You only have one loop() but trust me, that is more than enough.
I think you are just looking at your problem from the wrong angle. You don't really need multiple loops - what you need is conditional statements (e.g. IF).
For example, consider this code:
int currentAction = 1; // declare current action variable
    if ( currentAction == 0 ) { // check the value of currentAction variable
        // do stuff
    else if ( currentAction == 1 ) { // check the value of currentAction variable
        // do something else
Now you can trigger different behaviors by changing the value of currentAction
indasingh:
How many brains do you have? One? And it can do a lot of complex things, right? Same with the loop function.
YemSalat:
        // do stuff
Now you can trigger different behaviors by changing the value of *currentAction*
Hi thanks for your response, but how would I apply this if the parameters do not change such as if i apply a 10K signal which will always be the same but at but at times I would like to use modulation one and at others modulation type 2 how would I be able to write a sketch where I can choose which function I will be using depending on unique situations
indasingh:
You evaluate the situations and code in an appropriate way.
Your question is so broad it is hard to answer it.
You might want
https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
This shows you how to make events happen based on timing.
The demo several things at a time illustrates what it says. It is the nearest thing you get to multiple loops.
...R
