Multiple serial port not working
This is working for me. I get data when I upload sketch https://electrosome.com/em-18-rfid-reader-arduino-uno/
int count = 0;                                          // count = 0
char input[12];                                         // character array of size 12
boolean flag = 0;                                       // flag =0
   Serial.begin(9600);                                  // begin serial port with baud rate 9600bps
   if(Serial.available())
      count = 0;
      while(Serial.available() && count < 12)          // Read 12 characters and store them in input array
         input[count] = Serial.read();
         count++;
         delay(5);
      Serial.print(input);                             // Print RFID tag number
      if((input[0] ^ input[2] ^ input[4] ^ input[6] ^ input[8] == input[10]) &&
         (input[1] ^ input[3] ^ input[5] ^ input[7] ^ input[9] == input[11]))
            Serial.println("No Error");
            Serial.println("Error");
Above code only work for hardware serial but I need to read multiple port to read many RFIDS
I found this link https://docs.arduino.cc/tutorials/communication/TwoPortReceive
I don't get reader data when I upload below sketch
#include <SoftwareSerial.h>
// software serial #1: RX = digital pin 10, TX = digital pin 11
SoftwareSerial portOne(10, 11);
// software serial #2: RX = digital pin 8, TX = digital pin 9
// on the Mega, use other pins instead, since 8 and 9 don't work on the Mega
SoftwareSerial portTwo(8, 9);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // Start each software serial port
  portOne.begin(9600);
  portTwo.begin(9600);
  // By default, the last initialized port is listening.
  // when you want to listen on a port, explicitly select it:
  portOne.listen();
  Serial.println("Data from port one:");
  // while there is data coming in, read it
  // and send to the hardware serial port:
  while (portOne.available() > 0) {
    char inByte = portOne.read();
    Serial.write(inByte);
  // blank line to separate data from the two ports:
  // Now listen on the second port
  portTwo.listen();
  Serial.println("Data from port two:");
  while (portTwo.available() > 0) {
    char inByte = portTwo.read();
  Serial.println()
Did you read this?
Limitations of This Library
SoftwareSerial library has the following known limitations:
If using multiple software serial ports, only one can receive data at a time.
Change your hardware. A Mega2560 has 4 hardware serial interfaces.
i know but why my code is not working. I have written program for two port but i am testing only one rfid so i was expecting it should be work
Perhaps your device does not know it is connected. Are you using the actual pins associated with that particular software serial set up?
You didn't upload a complete sketch.
Yes
I have uploaded the complete sketch given in link and after compiling I saw there was no error.
Sketch is posted on the forum from mobile, so there may be some mistakes
I have uploaded below sketch but it doesn't display data on serial monitor. Do I have to use array to store 12 bit data in code ?
// Set up a new SoftwareSerial object with RX in digital pin 10 and TX in digital pin 11
SoftwareSerial mySerial(10, 11);
    // Set the baud rate for the SerialSoftware object
    mySerial.begin(9600);
    char c = mySerial.read();
There are no serial print() or write() calls, so that isn't a surprise.
Done but still not getting data on serial monitor
#define rxPin 10
#define txPin 11
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
void setup()  {
    // Define pin modes for TX and RX
    pinMode(rxPin, INPUT);
    pinMode(txPin, OUTPUT);
    // Set the baud rate for the SoftwareSerial object
    if (mySerial.available() > 0) {
        mySerial.read();
        Serial.write(c);
        mySerial.print(c);
This could print a strange char for each character received, if there were a Serial.begin.
