Multiple Servo control with LED indicators and push button switch
I am new to Arduino and programming however I have found some code which does exactly what I require;
Move a servo with a button switch(non latching) at a defined speed to a defined position then as the servo reaches that position an LED indicator lights (2 LED's in total for the 2 positions)
I would like a single Arduino to run 2 or more independent servos with their related button switches and LED's
I have been attempting to change the code with use of an array (of which i know very little) however my programming knowledge is so low no doubt what I have entered is nonsense.
I am sure what I am trying to achieve is possible; the original code is below and attached.
Any help would be appreciated.
#include <Servo.h>
// constant variables used to set servo angles, in degrees
const int straight = 35;
const int divergent = 130;
// constant variables holding the ids of the pins we are using
const int divergent_led = 6;
const int straight_led = 7;
const int buttonpin = 8;
const int servopin = 9;
// servo movement step delay, in milliseconds
const int step_delay = 30;
// create a servo object
Servo myservo;
// global variables to store servo position
int pos = straight; // current
int old_pos = pos; // previous
// set the mode for the digital pins in use
pinMode(buttonpin, INPUT);
pinMode(straight_led, OUTPUT);
pinMode(divergent_led, OUTPUT);
// setup the servo
myservo.attach(servopin); // attach to the servo on pin 9
myservo.write(pos); // set the initial servo position
// set initial led states
digitalWrite(straight_led, HIGH);
digitalWrite(divergent_led, LOW);
// start each iteration of the loop by reading the button
// if the button is pressed (reads HIGH), move the servo
int button_state = digitalRead(buttonpin);
if(button_state == HIGH){
// turn off the lit led
if(pos == straight){
digitalWrite(straight_led, LOW);
old_pos = pos; // save the current position
// Toggle the position to the opposite value
pos = pos == straight ? divergent: straight;
// Move the servo to its new position
if(old_pos < pos){ // if the new angle is higher
// increment the servo position from oldpos to pos
for(int i = old_pos + 1; i <= pos; i++){
myservo.write(i); // write the next position to the servo
delay(step_delay); // wait
} else { // otherwise the new angle is equal or lower
// decrement the servo position from oldpos to pos
for(int i = old_pos - 1; i >= pos; i--){
// turn on the appropriate LED.
digitalWrite(divergent_led, HIGH);
}// end of loop
Servo_Control_with_LED.pdf (29.1 KB)
Here, post it in code tags or the code tag police will come and text at you.
#include <Servo.h>
Servo myservo;
  // setup the servo
}// end of loop
You will learn more if you write the code yourself.
Basically you could wrap all of the code in loop() in a 2 step for loop and use the for loop variable as the index to arrays of values. There is, however, a snag with that, because of your use of a for loop and delay() to control the speed of movement of the servo. During the delay() nothing else can happen and that is amplified by putting it inside a for loop. Is it important that the servo moves slowly or could it just snap into position ?
jimLee:
That makes it seem you think code tags are unnecessary? We've all had to contend with this:
digitalRead(8);
Not to mention this, where the [i] array index disappears and turns italics on:
// the array elements are numbered from 0 to (pinCount - 1).
// use a for loop to initialize each pin as an output:
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
pinMode(ledPins[thisPin], OUTPUT);
// loop from the lowest pin to the highest:
for (int i = 0; i < pinCount; i++) {
// turn the pin on:
digitalWrite(ledPins*, HIGH);*
  • delay(timer);*
  • // turn the pin off:*
    _ digitalWrite(ledPins*, LOW);_
    _
    }_
    _
    // loop from the highest pin to the lowest:_
    _
    for (int i = pinCount - 1; i >= 0; i--) {*_
So, where's your code tags huh?
-jim lee
