Multiple Software Serial
hi there, please help ..
I want to make a finger print with selenoid when entering the room and when leaving the room.
I use Arduino Uno V3 by making parallel finger print sensors.
How to combine two SoftwareSerial ?
and when i upload :
Found fingerprint 2 sensor!
Sensor contains 1 templates
Fingerprint 2 is ready to use,
Type 98 to register new fingerprint template
Did not find fingerprint sensor :frowning:
//this is finger print lock door
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
// consts
const int USERCMD_REGISTER_FINGER_1 = 99;
const int USERCMD_REGISTER_FINGER_2 = 98;
const int PIN_SOLENOID_LOCK = 5;
SoftwareSerial mySerial1(2, 3);
Adafruit_Fingerprint finger1 = Adafruit_Fingerprint(&mySerial1);
SoftwareSerial mySerial2(8, 9);
Adafruit_Fingerprint finger2 = Adafruit_Fingerprint(&mySerial2);
int userCmd;
int scannedFingerId = -1;
delay(100);
// set pin for solenoid lock
pinMode(PIN_SOLENOID_LOCK, OUTPUT);
// set the data rate for the sensor serial port
finger1.begin(57600);
finger2.begin(57600);
bool finger1Exist = finger1.verifyPassword();
bool finger2Exist = finger2.verifyPassword();
// check finger sensor 1
if (finger1Exist) {
Serial.println("Found fingerprint 1 sensor!");
finger1.getTemplateCount();
Serial.print("Sensor contains "); Serial.print(finger1.templateCount); Serial.println(" templates");
Serial.println(F("\nFingerprint 1 is ready to use, \nType 99 to register new fingerprint template"));
// check finger sensor 2
if (finger2Exist) {
Serial.println("Found fingerprint 2 sensor!");
finger2.getTemplateCount();
Serial.print("Sensor contains "); Serial.print(finger2.templateCount); Serial.println(" templates");
Serial.println(F("\nFingerprint 2 is ready to use, \nType 98 to register new fingerprint template"));
// halt when one of finger sensor !exist
if(!finger1Exist || !finger2Exist){
Serial.println("Did not find fingerprint sensor :(");
while (1) {
delay(1);
delay(50);
// user input branch
userCmd = Serial.parseInt();
if (userCmd == USERCMD_REGISTER_FINGER_1) {
while(!getFingerprintEnroll(finger1));
if (userCmd == USERCMD_REGISTER_FINGER_2) {
while(!getFingerprintEnroll(finger2));
// continuous scan for fingerprint
checkScannedFinger(getFingerprintID(finger1));
checkScannedFinger(getFingerprintID(finger2));
void checkScannedFinger(int fingerId) {
if(fingerId > 0) {
Serial.print("Finger matched with ID #"); Serial.println(scannedFingerId);
Serial.println("Unlocking for 5 secs");
digitalWrite(PIN_SOLENOID_LOCK, HIGH);
delay(5000);
digitalWrite(PIN_SOLENOID_LOCK, LOW);
Serial.println("Locked");
int readUserInput() {
int input = 0;
while (input == 0) {
while (!Serial.available());
input = Serial.parseInt();
return input;
int getFingerprintEnroll(Adafruit_Fingerprint finger) {
int id = 0;
Serial.println("Ready to enroll a fingerprint!");
Serial.println("Please type in the ID # (from 1 to 127) you want to save this finger as...");
// read finger id input
id = readUserInput();
// ID should in range of 1 to 127
if (id == 0) {
return;
Serial.print("Enrolling ID #");
Serial.println(id);
int p = -1;
Serial.print("Waiting for valid finger to enroll as #");
Serial.println(id);
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println(".");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
default:
Serial.println("Unknown error");
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID "); Serial.println(id);
p = -1;
Serial.println("Place same finger again");
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #"); Serial.println(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
return p;
int getFingerprintID(Adafruit_Fingerprint finger) {
byte p = finger.getImage();
if (p != FINGERPRINT_OK) return -1;
p = finger.image2Tz();
p = finger.fingerFastSearch();
// found a match!
Serial.print("Found ID #");
Serial.print(finger.fingerID);
Serial.print(" with confidence of ");
Serial.println(finger.confidence);
return finger.fingerID;
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
