Hello,
I want an if statement with multiple values,
Will it work like this? It doesn't give an error
if (x == 12 || x == 16 || x == 19 || ...)
or like this
if ((17,18,19,20 == val))
Hello,
or like this
The first one is correct. The second one - I have never seen this in C++.
thehardwareman:
Okay thank you!
rico459:
or like thisif ((17,18,19,20 == val))
This is equivalent to:
if (17) // This 'if' will always be 'true' since 17 is not zero
The 'comma operator' (using a comma in an expression) evaluates both sides and returns the left side.
Are your values arbitrary, or do they follow a pattern? You can make expressions to test a pattern, for example your second one could be:
if (val >= 17 and val <=20)
If you had a regular series:
12, 16, 20, 24, 28, 32
you could test like:
if (val/4 >= 3 and val/4 <= 8)
johnwasser:
This is equivalent to:if (17) // This 'if' will always be 'true' since 17 is not zeroThe 'comma operator' (using a comma in an expression) evaluates both sides and returns the left side.
No, the last value is used, so it is equivalent to
if (val == 20)
rico459:
A useful exercise here would be to design an experiment to find out
oqibidipo:
No, the last value is used, so it is equivalent toif (val == 20)
Oops, you're right. My mistake.
