Multiple Water flow sensors with Temperature sensor
i'm currently building a project to just monitor how much water is flowing through 4 sensors and a temperature sensor to top it off.
Mostly what im looking for advice on is the programming, i have 1 flow sensor and the temperature sensor working together i just need to get the other 3 water flow sensors in the code, i know i can copy and paste most of the code for the first flow sensor and change the defines and it should work but im wondering if there is an easier way
Any help is greatly appreciated
Thanks in advance
Josh
If I understand you correctly, then absolutely.
What you can do is from your main loop, call a function to read analogue inputs with some parameters that specify which input.
In that function, I would suggest do a little smoothing of the analogue input readings, by doing a moving average.
That way, you only have one bock of code to read any desired analogue input with all the necessary functionality you need.
You can call this function based on a timed event from the main loop().
If you like I can dig up my code as an example.
Just bearing in mind that the Arduino server is about to go down for a while for maintenance.
Paul
Sure, i'm kinda getting close to getting something to work but im not sure if what im doing is the exact right way to do it
Would you like to share your code with us, if you are unsure about if it is correct?
Paul
actually got 3 of the 4 water flow sensors working
This seems to be my problem at the moment TIMSK0-2 used up
void useInterrupt4(boolean y) {
  if (y) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK2 |= _BV(OCIE0A);
    // do not call the interrupt function COMPA anymore
    TIMSK2 &= ~_BV(OCIE0A);
#include <OneWire.h>
#include <DallasTemperature.h>
// which pin to use for reading the sensor? can use any pin!
#define FLOWSENSORPIN1 3
#define FLOWSENSORPIN2 4
#define FLOWSENSORPIN3 5
#define FLOWSENSORPIN4 6
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer;
// count how many pulses!
volatile uint16_t pulses = 0;
volatile uint16_t pulses2 = 0;
volatile uint16_t pulses3 = 0;
volatile uint16_t pulses4 = 0;
// track the state of the pulse pin
volatile uint8_t lastflowpinstate;
volatile uint8_t lastflowpinstate2;
volatile uint8_t lastflowpinstate3;
volatile uint8_t lastflowpinstate4;
// you can try to keep time of how long it is between pulses
volatile uint32_t lastflowratetimer = 0;
volatile uint32_t lastflowratetimer2 = 0;
volatile uint32_t lastflowratetimer3 = 0;
volatile uint32_t lastflowratetimer4 = 0;
// and use that to calculate a flow rate
volatile float flowrate;
volatile float flowrate2;
volatile float flowrate3;
volatile float flowrate4;
// Interrupt is called once a millisecond, looks for any pulses from the sensor!
SIGNAL(TIMER0_COMPA_vect) {
  uint8_t x = digitalRead(FLOWSENSORPIN1);
  if (x == lastflowpinstate) {
    lastflowratetimer++;
    return; // nothing changed!
  if (x == HIGH) {
    //low to high transition!
    pulses++;
  lastflowpinstate = x;
  flowrate = 1000.0;
  flowrate /= lastflowratetimer;  // in hertz
SIGNAL(TIMER1_COMPA_vect) {
  uint8_t x = digitalRead(FLOWSENSORPIN2);
  if (x == lastflowpinstate2) {
    lastflowratetimer2++;
  if (x == HIGH) {
    pulses2++;
  lastflowpinstate2 = x;
  flowrate2 = 1000.0;
  flowrate2 /= lastflowratetimer2;  // in hertz
SIGNAL(TIMER2_COMPA_vect) {
  uint8_t x = digitalRead(FLOWSENSORPIN3);
  if (x == lastflowpinstate3) {
    lastflowratetimer3++;
  if (x == HIGH) {
    pulses3++;
  lastflowpinstate3 = x;
  flowrate3 = 1000.0;
  flowrate3 /= lastflowratetimer3;  // in hertz
SIGNAL(TIMER3_COMPA_vect) {
  uint8_t x = digitalRead(FLOWSENSORPIN4);
  if (x == lastflowpinstate4) {
    lastflowratetimer4++;
  if (x == HIGH) {
    pulses4++;
  lastflowpinstate4 = x;
  flowrate4 = 1000.0;
  flowrate4 /= lastflowratetimer4;  // in hertz
void useInterrupt(boolean v) {
  if (v) {
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    TIMSK0 &= ~_BV(OCIE0A);
void useInterrupt2(boolean w) {
  if (w) {
    OCR0A = 0xAF;
    TIMSK1 |= _BV(OCIE0A);
    TIMSK1 &= ~_BV(OCIE0A);
void useInterrupt3(boolean x) {
  if (x) {
    OCR0A = 0xAF;
  if (y) {
    OCR0A = 0xAF;
   pinMode(FLOWSENSORPIN1, INPUT);
   digitalWrite(FLOWSENSORPIN1, HIGH);
   lastflowpinstate = digitalRead(FLOWSENSORPIN1);
   useInterrupt(true);
   pinMode(FLOWSENSORPIN2, INPUT);
   digitalWrite(FLOWSENSORPIN2, HIGH);
   lastflowpinstate = digitalRead(FLOWSENSORPIN2);
   useInterrupt2(true);
   pinMode(FLOWSENSORPIN3, INPUT);
   digitalWrite(FLOWSENSORPIN3, HIGH);
   lastflowpinstate = digitalRead(FLOWSENSORPIN3);
   useInterrupt3(true);
   pinMode(FLOWSENSORPIN4, INPUT);
   digitalWrite(FLOWSENSORPIN4, HIGH);
   lastflowpinstate = digitalRead(FLOWSENSORPIN4);
   useInterrupt4(true);
   Serial.print("Locating devices...");
   sensors.begin();
   Serial.print("Found ");
   Serial.print(sensors.getDeviceCount(), DEC);
   Serial.println(" devices.");
   // report parasite power requirements
   Serial.print("Parasite power is: ");
   if (sensors.isParasitePowerMode()) Serial.println("ON");
   else Serial.println("OFF");
  // assign address manually.  the addresses below will beed to be changed
  // to valid device addresses on your bus.  device address can be retrieved
  // by using either oneWire.search(deviceAddress) or individually via
  // sensors.getAddress(deviceAddress, index)
  //insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
  // Method 1:
  // search for devices on the bus and assign based on an index.  ideally,
  // you would do this to initially discover addresses on the bus and then
  // use those addresses and manually assign them (see above) once you know
  // the devices on your bus (and assuming they don't change).
  if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
  // method 2: search()
  // search() looks for the next device. Returns 1 if a new address has been
  // returned. A zero might mean that the bus is shorted, there are no devices,
  // or you have already retrieved all of them.  It might be a good idea to
  // check the CRC to make sure you didn't get garbage.  The order is
  // deterministic. You will always get the same devices in the same order
  // Must be called before search()
  //oneWire.reset_search();
  // assigns the first address found to insideThermometer
  //if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
  // show the addresses we found on the bus
  Serial.print("Device 0 Address: ");
  printAddress(insideThermometer);
  // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
  sensors.setResolution(insideThermometer, 9);
  Serial.print("Device 0 Resolution: ");
  Serial.print(sensors.getResolution(insideThermometer), DEC);
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  Serial.print("Fish Tank Temperature F: ");
  Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
void loop()                     // run over and over again
//  Serial.print("Freq: "); Serial.println(flowrate);
//  Serial.print("Pulses: "); Serial.println(pulses, DEC);
  // if a plastic sensor use the following calculation
  // Sensor Frequency (Hz) = 7.5 * Q (Liters/min)
  // Liters = Q * time elapsed (seconds) / 60 (seconds/minute)
  // Liters = (Frequency (Pulses/second) / 7.5) * time elapsed (seconds) / 60
  // Liters = Pulses / (7.5 * 60)
  float liters = pulses;
  liters /= 7.5;
  liters /= 60.0;
  float liters2 = pulses2;
  liters2 /= 7.5;
  liters2 /= 60.0;
  float liters3 = pulses3;
  liters3 /= 7.5;
  liters3 /= 60.0;
  float liters4 = pulses4;
  liters4 /= 7.5;
  liters4 /= 60.0;
  Serial.print(liters); Serial.println("L Water Flow Sensor 1");
  Serial.print(liters2); Serial.println("L Water Flow Sensor 2");
  Serial.print(liters3); Serial.println("L Water Flow Sensor 3");
  Serial.print(liters4); Serial.println("L Water Flow Sensor 4");
 // call sensors.requestTemperatures() to issue a global temperature
  // request to all devices on the bus
  sensors.requestTemperatures(); // Send the command to get temperatures
  // It responds almost immediately. Let's print out the data
  printTemperature(insideThermometer); // Use a simple function to print out the data
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
  for (uint8_t i = 0; i < 8; i++)
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
OK, I understand better what you are doing now, you are using digital input pulses for sensing your water flow.
And that you are using a timer compare interrupt to call the funtion to read the digital input of the flow sensor.
Now, it appears that all the timer compare routines are the same, so why not just use one of these routines for all your flow senors?
If my thinking is correct, you should be able to check all four flow sensors in the one routine called by the one interrupt.
Well to be honest this is kind of a copy and paste job at the moment, i wanted to see what i could get done tonight having just received the Arduino Uno in the mail today, i know a little about C which is why i'm able to at least make some of it work but probably not enough to do exactly what your saying but ill try
I'm probably just tired but i cant seem to figure it out tonight, might be also due to timer3 not being available but who knows
Yes, I can understand being tired, best have a breather for a while.
You have it basically there, just some shuffling about I am thinking.
What hardware did you have, a UNO or a Mega?
I have your code in another editor and I'll take a further look at it and see what I can propose.
Will possibly be tomorrow.
Uno R3
Tried putting it all on one timer and it didn't work other than the first one so i'm still stumped on this project
