Hi there,
Currently I am trying to MUX an 8x8 one color LED array to demo the code to be used for a 10x16 array of RGB LED's. With the demo circuit I get a lot of flicker happening in my LED matrix. What i've noticed is that if i DISCONNECT more cathodes from the TLC leaving 1 or 2 the flicker disappears, with the exact same code uploaded! But if I have over 2 connections to my TLC, complex code like this, causes flicker.
The flicker also does not appear if there is some delay between row switching in the code.
My thinking is that either:
- Circuit setup causes some kind of weird drain issue that is coupling between rows
- Software setup is causing latching to not synchronize properly, causing flickering unless no other rows have been hooked up (which would allow for current leakage).
I have located other code such as:
Google Code Archive - Long-term storage for Google Code Project Hosting.
but I can't make sense of any of the code.
Can anyone point me in the right direction onto how to solve this issue??
The final circuit will look as follows:
This doesn't include the coupling capacitor connected between the TLC ground and VCC pins. They are a .1pF and a 10pF capacitor in parallel configuration.
I have the shift register hooked up to an Uno and the TLC in my DEMO circuit hooked up according to the tlc5940_config.h file.
Here is a guess of my code, as the actual code is at home and I am at school:
#include "tlc_config.h"
#include "Tlc5940.h"
int dataPin = 7;
int latchPin = 5;
int clockPin = 6;
byte leds = 0;
int shiftSelect[8] = {1,2,4,8,16,32,64,128};
// set the shift register pins to output
pinMode(dataPin,OUTPUT);
pinMode(latchPin,OUTPUT);
pinMode(clockPin,OUTPUT);
Tlc.init();
// 1. Start of display cycle
// 2. Switch anode to next row
next_row();
// 3. Calculate/load data for the next next row (not the one we just switched to, but the next one)
// let's display two circles
// I'm assuming that outputs 0-7 are red, 8-15 are green
Tlc.clear();
Tlc.set(2, 4095);
Tlc.set(3, 4095);
Tlc.set(4, 4095);
Tlc.set(5, 4095);
// 4. Send the data to the tlc's
Tlc.update();
leds = shiftSelect[count];
updateShiftRegister();
// 5. Wait till the end of display cycle
while (tlc_needXLAT);
count++;
if(count > 7) {
count = 0;
void updateShiftRegister()
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, LSBFIRST, leds);
digitalWrite(latchPin, HIGH);
EDIT:
I should have previously stated, the final project will be using a teensy, so it needs to be a teensy compatible solution.
Regards,
-Mat
