Hi there,
I have a quick,and I think pretty simple question, but I haven't had any luck with it myself. Suffice to say, I am not super experienced.
I am measuring water volume passing through a flow sensor. I am using the flowmeter library from here (GitHub - sekdiy/FlowMeter: Arduino flow meter library that provides calibrated liquid flow and volume measurement with flow sensors.). Working like a charm, but I would like to be able to serial.print litres per hour instead of litres per minute, as it is currently doing. In previous flow sensor codes that I had tried, I was able to multiply the flow rate by 60 to obtain the litres per hour and then print that, but I am not having any luck amending this code to do that.
I am pretty sure I have just overlooked something and would appreciate a more knowledgable person's eyes on the question.
Thank you for your time.
#include <FlowMeter.h> // https://github.com/sekdiy/FlowMeter
// connect a flow meter to an interrupt pin (see notes on your Arduino model for pin numbers)
FlowMeter Meter = FlowMeter(2);
// set the measurement update period to 1s (1000 ms)
const unsigned long period = 1000;
// define an 'interrupt service handler' (ISR) for every interrupt pin you use
void MeterISR() {
// let our flow meter count the pulses
Meter.count();
// prepare serial communication
// enable a call to the 'interrupt service handler' (ISR) on every rising edge at the interrupt pin
// do this setup step for every ISR you have defined, depending on how many interrupts you use
attachInterrupt(INT0, MeterISR, RISING);
// sometimes initializing the gear generates some pulses that we should ignore
Meter.reset();
// wait between output updates
delay(period);
// process the (possibly) counted ticks
Meter.tick(period);
// output some measurement result
Serial.println("Currently " + String(Meter.getCurrentFlowrate()) + " l/min, " + String(Meter.getTotalVolume())+ " l total.");
// any other code can go here
