Multipul buttons???
im getting my self a little confused.
ive got an lcd screen and a few buttons, i want the lcd to display something different depending on the button pressed. i know how to write to the lcd and how to use the clear function to wipe it.
this is what my code currently looks like.
 * Mathew Buer - 18/05/2015 @ 12:00
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
// this constant won't change:
const int  buttonPin = 7;    // the pin that the pushbutton is attached to
const int ledPin = 8;       // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  // tell the lcd where were startubg
  lcd.begin(16, 2);
  // set the line of the lcd we wish to print to
  lcd.setCursor(0,0);
  // message were going to print.
  lcd.print("  Lessage Line 1");
  // set the lcd to line 2
  lcd.setCursor(0,1);
  // set the message
  lcd.print("Message Line 2");
  // delay for showing the message
  delay(5000);
  lcd.clear();
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT_PULLUP);
  // initialize serial communication:
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // wend from off to on:
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes:  ");
      Serial.println(buttonPushCounter);
    else {
      // if the current state is LOW then the button
      // wend from on to off:
      Serial.println("off");
  // save the current state as the last state,
  //for next time through the loop
  lastButtonState = buttonState;
  // turns on the LED every four button pushes by
  // checking the modulo of the button push counter.
  // the modulo function gives you the remainder of
  // the division of two numbers:
  if (buttonPushCounter % 2 == 0) {
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("BUTTON PRESSED");
  lcd.clear();
  lcd.print("TEST");
how in order to use button2 to print "Hello World" woudli need to set new varibles for the button state ? ie
int buttonPushCounter2 = 0;   // counter for the number of button presses
int buttonState2 = 0;         // current state of the button
int lastButtonState2 = 0;     // previous state of the button
or is there an eaiser way as this just seems long winded.
Regards
That's what you need to do. If you have more than 2 switches, arrays become useful.
at the moment im just playing around with code trying to learn it, i find i learn stuff quicker if i fiddle,
basically at the moment im playing with printing to a lcd,
the the idea was
button 1 will display (this is button 1)
button 2 will display (this is button 2)
button 3 will display (this is button 3)
button 4 will display (this is button 4)
obvs ill use the lcd.clear(); function else the lcd will fill up with crap.
i dont get arrays, would you provide a sample of an array that i could use so i can see how it works and try to understand it,
Regards
byte switchPins[] = {7, 8, 9};
byte currState[3];
byte prevState[3];
   for(byte i=0; i<3; i++)
       currState[i] = digitalRead(switchPin[i]);
       if(currState[i] != prevState[i])
          if(currState[i] == HIGH)
             // The switch attached to the ith pin just became HIGH
       prevState[i] = currState[i];
thanks for the example,
am i right in thinking that the you would give each switch a pin, ie
int switchPins[] = {7, 8, 9};
byte currState[3];
byte prevState[3];
void setup () }
// set all buttons as inputs
  pinMode(switchPins, INPUT);
             lcd.setCursor(0,1);
             lcd.print("BUTTON 1")
             lcd.print("BUTTON 2")
             lcd.print("BUTTON 3")
or am i totally wrong ? im new to coding so just trying to find my feet, ive read a few tutorials about arrays but tbh they confused the hell outta me lol..
Yes. The values in the {} are the pin numbers.
This
void setup () }
needs to be
void setup ()
   for(byte b=0; b<3; b++)
const byte switchPins[] = {7, 8, 9}; // int is way larger than byte , so use byte for your switchpins
// now you have a byte array of three pins ( pin 7, 8, and 9)
// const just means  these settings will NEVER change
// your array starts with zero (0,1,2,)  so switchPins[0] = your pin 7
byte currState[3];
byte prevState[3];
void setup () {  // open {  first
 for(byte j=0; j<3;j++)  // so if j =0 and j is less than 3, which means 0, 1,2    j = j +1 means J++
 { pinMode(switchPins[j], INPUT_PULLUP); }// now you use the byte array of switchPins
// inside the for loop       it means  you can set
//pinMode(switchPins[0], INPUT_PULLUP)   == pin7 is now set to INPUT_PULLUP
//pinMode(switchPins[1], INPUT_PULLUP)   == pin8 is  now set to INPUT_PULLUP
//pinMode(switchPins[2], INPUT_PULLUP)   == pin9 is now set to INPUT_PULLUP
} //  and then end it with }
@siutoejai
thanks a million for the breakdown of what everything dose. this has helpped me unstand what everything is doing :smiley:
  • karma for you Dude :smiley:
@PaulS
thanks for the inital replys and help, + karma for you also.
this is what really makes a forum, Dedicated members,
im a avid user of the opencart forums and i try to help as much as i can there, and ill do the same here, once ive learned C++ ill be more then happy to help others achieve what there after :smiley:
Hi, pal.
You are welcome. :slight_smile:
