Hello
Would need some help with coding.
I have a problem with a Photometric Stereo texture scanner that I built. The problem occurred when I changed light bulbs on the lid.
Before the change the lights turned on and camera focused and took a picture then it turned off.
now the lights turns on but turns off when the camera focuses and takes a picture and then turns on again for a second and then turns off.
I think the problem is that the old light bulb has a delay when it turns on/off so when lid lights goes from on to camera focus/shutter and on again, light bulb does not have time to switch off before it has to be on again due to delay so when i made it mutitasking wasn't needed.
new bulbs doesn't have that so i need help create multitasking for the light on the lid only.
I'am not a coder and have extremly limited knowledge of coding. so iam looking for someone to just send me a fix.
Pin for lights on the lid is 11
Here is two video of my scanner in action.
Inside my scanner
Outside my scanner
Here is the code. it has five tabs.
#include <Wire.h>
#include <Stepper.h>
#include "led.h"
#include "buzzer.h"
const int stepsPerRevolution = 2048;
LiquidCrystal_I2C lcd(0x27, 16, 2);
Stepper myStepper = Stepper(stepsPerRevolution, 46, 50, 48, 52);
int DSLR_FOCUS = 38;
int DSLR_SHUTTER = 36;
int MOTOR_POWER = 34;
int BLUETOOTH_SHUTTER = 12;
int upButton = 44;
int downButton = 42;
int selectButton = 40;
int menu = 1;
lcd.init();
lcd.backlight();
lcd.setCursor(1, 0);
lcd.print("SCANNER BOX V2");
delay(5000);
lcd.clear();
myStepper.setSpeed(5);
pinMode(upButton, INPUT_PULLUP);
pinMode(downButton, INPUT_PULLUP);
pinMode(selectButton, INPUT_PULLUP);
pinMode(LED_TWO, OUTPUT);
pinMode(LED_THREE, OUTPUT);
pinMode(LED_FOUR, OUTPUT);
pinMode(LED_FIVE, OUTPUT);
pinMode(LED_SIX, OUTPUT);
pinMode(LED_SEVEN, OUTPUT);
pinMode(LED_EIGHT, OUTPUT);
pinMode(LED_NINE, OUTPUT);
pinMode(LED_TEN, OUTPUT);
pinMode(LED_ELEVEN, OUTPUT);
pinMode(DSLR_FOCUS, OUTPUT);
pinMode(DSLR_SHUTTER, OUTPUT);
pinMode(BLUETOOTH_SHUTTER, OUTPUT);
pinMode(MOTOR_POWER, OUTPUT);
updateMenu();
if (!digitalRead(downButton)) {
menu++;
updateMenu();
delay(100);
while (!digitalRead(downButton));
if (!digitalRead(upButton)) {
menu--;
updateMenu();
delay(100);
while (!digitalRead(upButton));
if (!digitalRead(selectButton)) {
executeAction();
updateMenu();
delay(100);
while (!digitalRead(selectButton));
void updateMenu() {
switch (menu) {
case 0:
menu = 1;
case 1:
lcd.clear();
lcd.print(">Textile");
lcd.setCursor(0, 1);
lcd.print(" Foliage");
case 2:
lcd.clear();
lcd.print(" Textile");
lcd.print(">Foliage");
case 3:
lcd.clear();
lcd.print(">calibrate");
case 4:
lcd.clear();
lcd.print(" calibrate");
lcd.print(">Settings");
case 5:
menu = 3;
void executeAction() {
switch (menu) {
case 1:
action1();
case 2:
action2();
case 3:
action3();
case 4:
action4();
void action1() {
lcd.clear();
lcd.print(">SCAN");
delay(2500);
lcd.clear();
lcd.setCursor(4, 0);
lcd.print("SCANNING");
blink_led(LED_TWO);
delay(200);
blink_led(LED_THREE);
delay(200);
blink_led(LED_FOUR);
delay(200);
blink_led(LED_FIVE);
delay(200);
blink_led(LED_SIX);
delay(200);
blink_led(LED_SEVEN);
delay(200);
blink_led(LED_EIGHT);
delay(200);
blink_led(LED_NINE);
delay(200);
blink_led(LED_ELEVEN);
delay(200);
digitalWrite(MOTOR_POWER, HIGH);
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
delay(5000);
delay(200);
Serial.println("counterclockwise");
myStepper.step(-stepsPerRevolution);
delay(5000);
digitalWrite(MOTOR_POWER, LOW);
lcd.clear();
lcd.setCursor(6, 0);
lcd.print("DONE");
blink_buzzer(BUZZER_PIN);
void action2() {
lcd.clear();
lcd.print(">SCAN");
delay(2500);
lcd.clear();
blink_led(LED_TWO);
delay(200);
delay(200);
delay(200);
delay(200);
blink_led(LED_SIX);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
delay(5000);
delay(200);
delay(5000);
blink_led(LED_TEN);
delay(200);
lcd.clear();
lcd.print("DONE");
void action3() {
lcd.clear();
lcd.print(">Calibrate");
delay(2500);
lcd.clear();
lcd.setCursor(2, 0);
lcd.print("CALIBRATING");
digitalWrite(LED_ELEVEN, HIGH);
delay(100000);
digitalWrite(LED_ELEVEN, LOW);
lcd.clear();
lcd.print("DONE");
void action4() {
lcd.clear();
lcd.print(">Bluetooth");
delay(2500);
digitalWrite(12, HIGH);
delay(4000);
digitalWrite(12, LOW);
lcd.clear();
lcd.print("ON/OFF");
#include "pitches.h"
const int BUZZER_PIN = 13;
int melody[] = {NOTE_C6, NOTE_D6, NOTE_E6, NOTE_G6, NOTE_B6, NOTE_G7, NOTE_B7, NOTE_C7,};
int noteDurations[] = {12, 12, 8, 8, 8, 8, 4, 4, 4,};
void blink_buzzer(int buzzer){
int size = sizeof(noteDurations) / sizeof(int);
for (int thisNote = 0; thisNote < size; thisNote++) {
int noteDuration = 1000 / noteDurations[thisNote];
tone(BUZZER_PIN, melody[thisNote], noteDuration);
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
noTone(BUZZER_PIN);
#ifndef LED_H
#define LED_H
#define LED_TWO 2
#define LED_THREE 3
#define LED_FOUR 4
#define LED_FIVE 5
#define LED_SIX 6
#define LED_SEVEN 7
#define LED_EIGHT 8
#define LED_NINE 9
#define LED_TEN 10
#define LED_ELEVEN 11
#endif
void blink_led(int led){
digitalWrite(led, HIGH);
delay(10000);
digitalWrite(DSLR_FOCUS, HIGH);
delay(2000);
digitalWrite(DSLR_SHUTTER, HIGH);
digitalWrite(BLUETOOTH_SHUTTER, HIGH);
delay(100);
digitalWrite(DSLR_SHUTTER, LOW);
digitalWrite(BLUETOOTH_SHUTTER, LOW);
digitalWrite(DSLR_FOCUS, LOW);
delay(10000);
digitalWrite(led, LOW);
Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 104
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_CS3 139
#define NOTE_D3 147
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 740
#define NOTE_G5 784
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1047
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1245
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1480
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2349
#define NOTE_DS7 2489
#define NOTE_E7 2637
#define NOTE_F7 2794
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 4186
#define NOTE_CS8 4435
#define NOTE_D8 4699
#define NOTE_DS8 4978
