Music maker shield from Adafruit and RGB Led Strip
Hello guys,
I have one big problem. I try to make some sort of light interactive music player using Arduino UNO, Music Maker MP3 shield from Adafruit and a LPD6803 rgb led strip.
Here you have some links for of the products:
Music Maker -> Adafruit Music Maker MP3 Shield for Arduino w/3W Stereo Amp [v1.0] : ID 1788 : $34.95 : Adafruit Industries, Unique & fun DIY electronics and kits
RGB LED STRIP ->
So, this setup is like that : when the light sensor senses that the light droped below a certain value, it should do some random effect on the rgb led strip and alos, to make a sound from an SD card. When i upload the program without the sound it works just fine but the problem is when i play the sound. It simply stops. The .mp3 file from the SD card it's a harp sound of 1 and a half second.
From what i found from other forums, it might be a problem with communication but, i don't know how to solve it.
Down below you have the code :
#include <FastSPI_LED.h>
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
#define NUM_LEDS 29
// Sometimes chipsets wire in a backwards sort of way
struct CRGB { unsigned char r; unsigned char g; unsigned char b; };
struct CRGB *leds;
#define dataPin 5
unsigned int Display[NUM_LEDS];
int random_effect = 0;
int contor_break = 0;
int idx_offset = 0;
#define PRAG 50
#define BREAKOUT_RESET  9
#define BREAKOUT_CS     10
#define BREAKOUT_DCS    8
#define SHIELD_RESET  -1
#define SHIELD_CS     7
#define SHIELD_DCS    6
#define CARDCS 4
#define DREQ 3
Adafruit_VS1053_FilePlayer musicPlayer =  Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
void setup(){
  uint32_t seed = 0;                    // Generate random seed
  for ( uint8_t i = 10 ; i ; i-- )
    seed = ( seed << 5 ) + ( analogRead( 3 ) * 3 );
  randomSeed( seed );
  musicPlayer.begin();
  SD.begin(CARDCS);
  musicPlayer.setVolume(1,1);
  FastSPI_LED.setLeds(NUM_LEDS);
  FastSPI_LED.setChipset(CFastSPI_LED::SPI_LPD6803);
  FastSPI_LED.setPin(dataPin);
  FastSPI_LED.init();
  FastSPI_LED.start();
  leds = (struct CRGB*)FastSPI_LED.getRGBData();
  off();
   musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);
void loop(){
  int valoare_senzor = analogRead(0);
  albastru();
  int test = 4;
  if(valoare_senzor < PRAG){
    musicPlayer.playFullFile("track001.mp3");
    random_effect = random(1,6);
  Serial.println(valoare_senzor);
  switch(random_effect){
    case 0 :
      albastru();
      Serial.println("A intrat pe case 0");
    case 1 :
      rainbow();
      if(contor_break == 1){
      else if(contor_break == 0){
        random_effect = 0;
        off();
        delay(10);
        fade_up();
    case 2 :
      fade_down_roz();
        random_effect = 0;
        off();
        delay(10);
        fade_up();
    case 3 :
      fade_down_verde();
        random_effect = 0;
        off();
        delay(10);
        fade_up();
    case 4 :
       fade_down_galben();
        random_effect = 0;
        off();
        delay(10);
        fade_up();
     case 5 :
      rainbow2();
        random_effect = 0;
        off();
        delay(10);
        fade_up();
    case 6 :
      color_chase();
        random_effect = 0;
        off();
        delay(10);
        fade_up();
The hole code works if i comment this line but it makes no sound.
Can you help me ? What have i done wrong and what should i change ?
And also, i have a problem, how can i change the dataPin for the led strip ? Even if i try to redefine it, it's always on pin 11. Do you have a clue about this ?
