The main editor of the Arduino looks like the spacing between the line are very huge.
I have attached a photo for reference please help me out to make my Arduino IDE right again.
Does the problem persist if you close all Arduino IDE windows and the start the Arduino IDE again?
Yeah, It persist even after restarting arduino and restarting my computer
Please do this:
This will allow me to reproduce your IDE settings exactly so I can investigate the problem.
Here you go.
FYI, I deleted the whole appdata folder located at C:\Users<User name>\Appdata\Local\Arduino15
but, the problem persist.
preferences.txt (3.09 KB)
Praveen2000:
OK, that was a good troubleshooting technique. As long as you closed the Arduino IDE before doing it, that will cause the IDE to revert to its default preferences.
So that shoots down my theory that the problem could be caused by something in your preferences.
I also tried replacing my preferences.txt with yours to be sure, and I can't reproduce the problem.
Which operating system are you using?
Have you made any modifications to the Arduino IDE's theme?
I am using windows 10.
I didnt made any modifications to the theme
Unfortunately, I'm stumped. Hopefully someone else here on the forum will have an idea.
does it reset to 'normal' if you select Tools> Auto Format?
Has Win 10 had any updates?
You're using IDE 1.8.10, can you try an earlier version such as 1.8.9 and see if that clears it?
Search on this site for 'clean up instructions' and follow them to you make sure you remove all traces of 1.8.10.
Peter
Thanks,
I did all but none of them didnt solve the issue
Does it look normal when you open it in a normal editor (notepad++, vi)? You can attach your ino file as well and somebody might be willing check it.
