My circuit project for my Harley Davidson Probeam Fog Lights
Hello All,
I would like to share my project. Any bikers out there? :grin:
I purchased Probeam fog lights to mount on my 2003 Harley Davidson Softail Springer FXSTSI. The two fog lights are 20w, 1.6a each total of 3.2a.
The fog lights have a low beam and a high beam, the default fog light is the low beam, "halo" it is on all the time, like "running lights on a car", I wanted to have the fog lights "blink" at 100ms, on-demand, to give a heads up to cagers, "people in cars", like a car driver that may make a left turn in front of me. "I never saw him officer", you hear it all the time.
So I will have two momentary-on switches, mounted verticle, on the handlebar, they will have 12v led indicators built-in. They are both momentary-on but one of them, the "top one with a red LED indicator, that turns on the high beam, will act like a "latched switch",
"in code", you press it once and the high beam fog lights come on, and will stay on until you press it again. The bottom switch, a momentary-on, will blink the fog lights, either the low beam alone or both the low beam and the high beam, "if the high beams are on", also the switch that turns on the high beams, will also turn off all the fog lights if it is given a "long press", 2.5 seconds
and it will turn them back on with another "long press" 2.5 seconds, but just the low beams will come on, the high beams will be off, since the default mode is low beams always on.
Here is my working schematic, and my script which runs on the ATEMEGA328 tested on a breadboard. I will be soldering it on a proto board that will live under the seat of my Harley.
I hope this helps you. This is the stuff I always look for, and I swore I would share it if, when, I ever figured it out.
It was a big learning curve for me, I am new to electronics and rusty in Arduino code. My code is crude compared to coders I see on this forum, but it works.
If anyone wants to streamline my script with arrays or a state machine please do, and share it. Thanks, and I hope this helps some of you. I give credit to Blackfin in my script, I saw his post for how to execute a "Long Press" with a switch.
//I edited code from Blackfin "Hold button for 5 seconds for an LED to turn and stay on"  https://forum.arduino.cc/t/hold-button-for-5-seconds-for-an-led-to-turn-and-stay-on/574197/3
//John Guarnieri script 01_17_2022 Harley Davidson Probeam Fog Lights blink at 100ms and also poer off all fog lights with long button press
#define LEDon  HIGH
#define LEDoff  LOW
#define DISABLED  false
#define ENABLED  true
//int
int blinkInterval = 100; //100ms
int short_key_press_time = 30;
int Long_Switch_Press_Time = 2500; //2.5 seconds
//unsigned long
unsigned long previousBlink;
unsigned long currentMillis;
unsigned long previousMillis;
unsigned long
timeStart_1; //long press time check
unsigned long
timeStart_2;  //short press time check
//buttons
const byte button_blink_the_fog_lights = 4;
const byte switch_turn_on_the_high_beam_fog_lights = 5;
//LED's
const int fog_light_low_beam = 6;
const int fog_light_low_beam_indicator = 7;
const int fog_light_high_beam = 8;
const int fog_light_high_beam_indicator = 9;
//long
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
//bool
bool blinkState = DISABLED;
bool First_Long_Press = ENABLED;
bool First_Short_Press = ENABLED;
bool Do_Not_Run_First_Short_Press_Flag = DISABLED;
bool the_high_beam_fog_lights_are_on = DISABLED;
bool All_The_Fog_Lights_Are_Off = DISABLED;
bool high_beam_pin_flag = DISABLED;
bool second_long_press_dont_turn_on_the_high_beam_fog_lights = DISABLED;
bool
bCheckingSwitch_1; //long press check switch_turn_on_the_high_beam_fog_lights
bool
bCheckingSwitch_2;  //short press check switch_turn_on_the_high_beam_fog_lights
byte
    currSwitch, //high beam fog light button state changes
    lastSwitch;
   pinMode(fog_light_low_beam,OUTPUT);
   pinMode(fog_light_low_beam_indicator,OUTPUT);
   pinMode(fog_light_high_beam,OUTPUT);
   pinMode(fog_light_high_beam_indicator,OUTPUT);
   pinMode(button_blink_the_fog_lights,INPUT_PULLUP);
  pinMode( switch_turn_on_the_high_beam_fog_lights,INPUT_PULLUP );
  lastSwitch = digitalRead( switch_turn_on_the_high_beam_fog_lights );
  bCheckingSwitch_1 = DISABLED;
  bCheckingSwitch_2 = DISABLED;
  //turn on the led
  digitalWrite(fog_light_high_beam,LEDoff);
  digitalWrite(fog_light_high_beam_indicator,LEDoff);
  digitalWrite(fog_light_low_beam,LEDon);
  digitalWrite(fog_light_low_beam_indicator,LEDon);
  //need this for serial monitor output
} //end void setup
  if ( (millis() - lastDebounceTime) > debounceDelay) //debounce button press
     currSwitch = digitalRead(switch_turn_on_the_high_beam_fog_lights);
     lastDebounceTime = millis(); //set the current time
     //call the function check_high_beam_fog_light_switch()
     check_high_beam_fog_light_switch();
     //call the function blink_the_fog_lights()
     blink_the_fog_lights();
} //end void loop
void check_high_beam_fog_light_switch()
  //if the switch is low now and doesn't match its
  //previous reading, it means the switch has changed
  //either unpressed-to-pressed or pressed-to-unpressed
  if( currSwitch != lastSwitch )
     //if low now, the change was unpressed to pressed
     if( currSwitch == LOW )
        //in that case, get the time now to start the
        //5-sec delay...
        timeStart_1 = millis();
        timeStart_2 = millis();
        //...indicate we're now timing a press...
        bCheckingSwitch_1 = ENABLED;
        bCheckingSwitch_2 = ENABLED;
        //Serial.println("short press ");
        //Serial.println(timeStart_2);
     }  //if
        //was a rising edge (button being released)
        //cancel checking the switch timing now since
        //it's not being held hown
        //Serial.println("Short_press release");
     }//end else
     //and save the lastSwitch = currSwitch;
  }//end if
  //if we haven't seen a rising edge, keep checking the
  //timing
  if( bCheckingSwitch_1 )//long press happening here switch_turn_on_the_high_beam_fog_lights
     //Serial.println("short press happening here");
     toggle_OFF_and_ON_all_the_fog_lights_long_press();
  }//end if
  if( bCheckingSwitch_2 )//short press happening here switch_turn_on_the_high_beam_fog_lights
     //this flag happens if all the fog lights were turned off,
     //you dont want to turn on any fog lights until
     //another long press happens to turn all the fog lights back on
     if(!Do_Not_Run_First_Short_Press_Flag)
        toggle_OFF_and_ON_just_the_high_beam_fog_lights();
  }//end if
}   //end void check_high_beam_fog_light_switch()
void toggle_OFF_and_ON_all_the_fog_lights_long_press()
 //if the millis count now is 2500 or more higher
 //than it was when the press was detected (timeStart_1),
 //turn on the LED
 if( (millis() - timeStart_1 ) >= Long_Switch_Press_Time          //long press 2.5 seconds turn off all the fog lights
    if (First_Long_Press) //switch_turn_on_the_high_beam_fog_lights
       //because the low beam fog lights are always on go low first
       digitalWrite(fog_light_low_beam,LEDoff);
       digitalWrite(fog_light_low_beam_indicator,LEDoff);
       First_Long_Press = DISABLED;
       //latest add seems to work
       currSwitch = 1;
       All_The_Fog_Lights_Are_Off = ENABLED;
       Do_Not_Run_First_Short_Press_Flag = ENABLED;
       Serial.println("Long press high beam fog lights are OFF");
       //Serial.println("high_beam_pin_flag");
       //Serial.println(high_beam_pin_flag);
    else //second long press here switch_turn_on_the_high_beam_fog_lights
       digitalWrite( fog_light_low_beam,LEDon);
       digitalWrite( fog_light_low_beam_indicator,LEDon);
       //didn't need this here
       //digitalWrite( fog_light_high_beam,LEDon);
       //digitalWrite( fog_light_high_beam_indicator,LEDon);
       //fix I set lastSwitch to HIGH because after turning off all the fog lights
       //and then turning all the fog lights back on, when I pressed the turn on the high beam button it was
       //already in the LOW position so you had to press it twice to turn on the high beam fog lights, setting lastSwitch = HIGH; fixed it
       //lastSwitch was LOW screwing me up so set it to HIGH
       //this lastSwitch = HIGH; fires off a short press if currSwitch, and/or lastSwitch, "the high beam fog light button state changes", get out of sync on a button press, in some situatons.
       lastSwitch = HIGH;
       Serial.println("Long press high beam fog lights are ON");
       second_long_press_dont_turn_on_the_high_beam_fog_lights = ENABLED;
       high_beam_pin_flag = ENABLED;
       //FIX
       //this is the fix set "First_Short_Press = false;" for when First_Short_Press
       //was = to "true" "HIGH" and should have been false "LOW" if
       //it were true at the wrong time the high beams would
       //only turn off on a second short press, and not the first short press which is normal operation
       //on and off on the first short press
       First_Short_Press = DISABLED; //LOW
       currSwitch = 1;
       //turn off the flag
}// end void toggle_OFF_and_ON_all_the_fog_lights_long_press()
void toggle_OFF_and_ON_just_the_high_beam_fog_lights()  //short press
 //turn on the LED
  if( (millis() - timeStart_2 ) >= short_key_press_time          //short press time
    //Serial.println("First_Short_Press");
    //Serial.println(First_Short_Press);
    //Serial.println("Do_Not_Run_First_Short_Press_Flag");
    //Serial.println(Do_Not_Run_First_Short_Press_Flag);
    if (First_Short_Press && !Do_Not_Run_First_Short_Press_Flag )//if First_Short_Press true set the fog_light_high_beam, HIGH "ON"
       the_high_beam_fog_lights_are_on = ENABLED;
       currSwitch = 1;
       //testing here
       Serial.println("Short press high beam fog lights are ON");
    else //if First_Short_Press = false turn set the fog_light_high_beam, LOW "OFF"
       digitalWrite( fog_light_high_beam,LEDoff);
       digitalWrite( fog_light_high_beam_indicator,LEDoff);
       currSwitch = 1;
       Serial.println("Short press high beam fog lights are OFF");
} //end void toggle_OFF_and_ON_just_the_high_beam_fog_lights()
void blink_the_fog_lights()
   if (!All_The_Fog_Lights_Are_Off)//NOT all the fog lights are off so proceed, else don't proceed
      currentMillis = millis(); // better to store in variable, for less jitter
      if (currentMillis - previousMillis >= blinkInterval)
      {   // enough time passed yet?
         previousMillis = currentMillis; // sets the time we wait "from"
         if (digitalRead(button_blink_the_fog_lights)==LOW) //blink fog light switch pressed LOW
            if (high_beam_pin_flag)//YES true high beam fog lights are ON you can blink both low and high fog lights
               if (!second_long_press_dont_turn_on_the_high_beam_fog_lights)//NOT
                  Serial.println("blinking low beams and high beams");
                  digitalWrite(fog_light_low_beam,!digitalRead(fog_light_low_beam)); // shortcut to toggle the LED
                  digitalWrite(fog_light_low_beam_indicator,!digitalRead(fog_light_low_beam_indicator)); // shortcut to toggle the LED
                  digitalWrite(fog_light_high_beam,!digitalRead(fog_light_high_beam)); // shortcut to toggle the LED
                  digitalWrite(fog_light_high_beam_indicator,!digitalRead(fog_light_high_beam_indicator)); // shortcut to toggle the LED
                  Serial.println("blinking just the low beams");
            else  //false the high beam fog lights are off just blink the low beam fog lights
         else  //blink switch released not pressed HIGH
            if (!high_beam_pin_flag)//NOT means false the high beam fog lights are off
            else  //true means the high beam fog lights are ON
               if (!second_long_press_dont_turn_on_the_high_beam_fog_lights)//NOT second long press so turn on the high beam fog lights
                 digitalWrite(fog_light_high_beam,LEDon);
                 digitalWrite(fog_light_high_beam_indicator,LEDon);
              else //true second_long_press_dont_turn_on_the_high_beam_fog_lights, so do NOT turn on the high beam fog lights
         }  //end (digitalRead(button_blink_the_fog_lights)==LEDoff)
      }//end millis
   }//end all the fog lights are not off
} //end void blink_the_fog_lights()
You should add some system protection to your circuit, vehicle electronics is very nasty. On the 12V input consider adding a diode or MOSFET to protect from reverse battery. On the regulator side add some high frequency bypass capacitance. I wouold choose a different regulator, pick one designed for automotive usage, the 7805 will not survive unless you are lucky. I do not know what the dump specification is for bikes but cars were 80V then went to 60V and some are now 40V. I would add a pull down resistor at the P-MOSFET output to prevent a potential dim glow in the LED. Hopefully this helps and you stay out of the dark.
Thank you for your input, I will check that out.
I just looked up automotive voltage regulators, they are pretty big, this circuit has to live under my Harley seat, what can I do size-wise that would help.
I just installed bootloaders on some atmega328 controllers using my Arduino UNO R3 and it worked and my fog light script ran on the Arduino UNO, but when I put the microcontroller on my breadboard to test it on the circuit it didn't work. Can anyone please explain why it runs on the Arduino Uno but not on a breadboard in my circuit.
Thanks
They can be gotten in SOT3, TO220 and other semiconductor packages. You need to look for voltage regulators for the electronics not the alternator. I believe every electronic module in an automobile has an electronic regulator in it. Use this search term: automotive voltage regulator ic
Do you have an external crystal or ceramic resonator on 16 MHz for the microcontroller? There is no such thing in your scheme. Maybe you should add one or if aceptable you program the fuse bits of the microcontroller to use the built-in RC generator - maximum frequency 8 MHz.
Yes, I have 16mhz, it's not in the schematic.
Oh, really? And what else is missing from the scheme? And most of all, what's the point of this scheme since it's out of date? This is like a guessing game to me, and it's not my game.
flashko
An American Indian was telling his Grandson how he felt.
I feel as though I have two wolves fighting in my heart.
One is vengeful, angry, and violent, the other is loving and compassionate.
Which wolf will win the fight in your heart Grandfather? Asked the boy.
The one that I feed replied the Grandfather.
I know this fable but I don't see the connection to your topic. Or maybe you expect us all to be psychics (like someone old american indian shaman)!?
I understand your joy at the successful (almost) project, as well as the desire to share it with others. However, incorrect and / or incomplete information is not useful to anyone. Suppose someone is interested in what you have done and wants to do it yourself. Will he be able to do it? Maybe but for that purpose he/she must somehow guess what else you had in mind - such as missing in shem 16 MHz quartz.
Unfortunately, the internet is full of such 'guides' and I don't like it at all. I'm glad you did what you want, but you'd better give complete and accurate information on how you did it, or delete this topic so as not to deceive other people.
Good luck.
My schematic was not about how to set up an atmega328 on a breadboard, my schematic was to show what the signal pins were and what the pins were that connected to the low beams and the high beams were, and how the BJTs and MOSFETs were connected.
I have googled my butt off to learn how to set up this circuit, and if anyone is serious about using this schematic I am sure they would google how to set up an atmega328 on a breadboard.
My point of the American Indian fable was to alert you to the fact that you came off as pretty terse in your reply to me.
I have never answered any posts coming off like the poster is a jerk "Oh, really? And what else is missing from the scheme? And most of all, what's the point of this scheme since it's out of date? "
Bottom line, you are wrapped too tight. relax and remember what is was like when you didn't know anything about electronics.
By the way this circuit works 100% my problem was my bench power supply was set to 3.2a, when I set it to 5a all was happy, another thing I learned googleing.
