My Code doesnt have issues, but it doesn't work
Hi, I am super new to ardiuno. I have LEDs and a dip switch. I am trying to make the dip switch work as a binary thing. i.e. if switch one is on and switch two and three are off the turn on a light. I obviously also need it to turn the light off if this condition is not met. I have been playing around with the code and this is what I found as a sollution
const byte LIGHT_13 = 13;
const byte LIGHT_12 = 12;
const byte LIGHT_11 = 11;
const byte LIGHT_10 = 10;
const byte LIGHT_9 = 9;
const byte LIGHT_8 = 8;
const byte LIGHT_7 = 7;
const byte SWITCH_1_ = 2;
const byte SWITCH_2_ = 3;
const byte SWITCH_3_ = 4;
pinMode (LIGHT_13, OUTPUT);
pinMode (LIGHT_12, OUTPUT);
pinMode (LIGHT_11, OUTPUT);
pinMode (LIGHT_10, OUTPUT);
pinMode (LIGHT_9, OUTPUT);
pinMode (LIGHT_8, OUTPUT);
pinMode (LIGHT_7, OUTPUT);
pinMode (SWITCH_1_, INPUT);
pinMode (SWITCH_2_, INPUT);
pinMode (SWITCH_3_, INPUT);
 if (digitalRead(((SWITCH_1_ == HIGH) && (SWITCH_2_ == LOW) && (SWITCH_3_ == LOW)))) {
  digitalWrite(LIGHT_13, HIGH);
  digitalWrite(LIGHT_13, LOW);
This code verifies, but when I upload it the LED is constanly on.
If what I am saying does not make sense I am happy to answer clarifying questions.
Your code isn't complete, so anything could be wrong, or not.
Please post the whole code.
At a guess I'd think it would be something with how the switches and LED are wired and whether or not there is a pullup.
You can test those sorts of problems by making sure you can run the built-in examples on your hardware and making Blink work on your current LED connection and making Button work on your current dip switch connections.
If you don't have actual pull-up/pull-down resistors on the DIP switch, consider using INPUT_PULLUP per https://docs.arduino.cc/learn/microcontrollers/digital-pins/
pinMode(pinNum,INPUT_PULLUP);
That and all the others are wrong. The evaluation of that is either false (0) or true (1) so e.g. digitalRead(SWITCH_1_ == HIGH) will either read pin 0 or pin 1.
You need three digitalReads, one for each pin and combine those.
As mentioned above, post you full code
Sorry about that, just did
What do you mean by combining them. As far as I understand, thats what I did. I posted the full code, sorry about that.
You need a separate digitalRead for each pin
That means only that the C/C++ language syntax is correct, not that the program will do anything useful.
You need to learn how to use digitalRead(), e.g.
if (digitalRead(pin) == HIGH) do_something();
There are a bunch of getting started examples in the Arduino IDE, File>Examples> etc.
if it not work - it is not a solution
This is one digitalRead() on what essentially translates into 0 if you work out the math on the constants inside the parentheses:
Your code does not what you think.
You have at mimium three wrong assumptions how this code works
SWITCH_1_ == HIGH:
SWITCH_1_ has value 2 so all in all this part is doing
2 == HIGH:
HIGH isvalue1
so all in all you are executing
2 == 1 which results in "false" where "false" is value 0
So the result of "2 == 1" is 0
This part
(SWITCH_1_ == HIGH) results in 0
same thing for
(SWITCH_2_ == LOW) results in 0
(SWITCH_3_ == LOW) results in 0
0 && 0 && 0 which finally results in 0
so what you line of code
is really doing is
if( digitalRead(0) )
which means you are reading IO-pin number 0
and depending on IO-pin beeing HIGH the condition would result in true
on IO-pin beeing LOW the condition would result in false
again:
you should really learn how to use digitalRead with a much simpler example
and work up from there
nobody here should make you stumble forward faster by presenting a working solution
You should do some more basic exercises before you work on this combining
const byte LEDs = 7;
const byte LIGHT[LEDs] = {13, 12, 11, 10, 9, 8, 7};
const byte SWITCHes = 3;
const byte SW[SWITCHes] = {2, 3, 4};
  for (int i = 0; i < LEDs; i++)    pinMode (LIGHT[i], OUTPUT);
  for (int i = 0; i < SWITCHes; i++)pinMode (SW[i], INPUT_PULLUP);
  byte state = 0;
  for (int i = 0; i < SWITCHes; i++)state |= (digitalRead(SW[i])==LOW)&(1<< i);
  state--;
  for (int i = 0; i < LEDs; i++)    digitalWrite(LIGHT[i], state == i);
@kolaha: I guess your code makes user @burtus_g stumble forward high speed
but I guess from his very basic knowledge he does not understand a single detail of your code
And you think this is a good way of learning? I don't think this is a good way to learn
To follow the API (I know, I don't either) this should be
  for (int i = 0; i < SWITCHes; i++) state |= (digitalRead(SW[i]) == HIGH) ? (1 << i) : 0;
or LOW for pulled up inputs.
@burtus_g may see this a bit (see what I did there?) faster:
   state = digitalRead(SWITCH1) * 4 + digitalRead(SWITCH2) * 2 + digitalRead(SWITCH3);
Yeah, I know. Bad meeting of the API. So sue me.
a7
you are right, but it inverting only dip-switch position
With a little editing on the if() conditions, it works.
A DIP switch is only SPST, and could have unreliable pull-up/pull-down issues if not carefully wired.
  DDRB |= 0x3f;
  DDRD |= 0x80;
  PORTD |= 0x1c;
  uint8_t state = PIND >> 2 & 0x7;
  for (int i = 0; i < 7; i++)digitalWrite( i+7, state == i);
