My Code
Can anybody help me with my code!
Does it need work or can you give me tips!
Tell Me What You Think Of This Code Put The Leds in the right PLACE! By D.J.B
03:00 22/August/09
*/ int a = 7; int b = 8; int c = 9; int d = 10; int e = 11; int f = 12; int g = 13; void setup () { pinMode (a, OUTPUT); pinMode (b, OUTPUT); pinMode (c, OUTPUT); pinMode (d, OUTPUT); pinMode (e, OUTPUT); pinMode (f, OUTPUT); pinMode (g, OUTPUT); } void loop () { digitalWrite(a,HIGH); delay(500); digitalWrite(a,LOW); digitalWrite(b,HIGH); delay(500); digitalWrite(b,LOW); digitalWrite(c,HIGH); delay(500); digitalWrite(c,LOW); digitalWrite(d,HIGH); delay(500); digitalWrite(d,LOW); digitalWrite(e,HIGH); delay(500); digitalWrite(e,LOW); digitalWrite(f,HIGH); delay(500); digitalWrite(f,LOW); digitalWrite(g,HIGH); delay(500); digitalWrite(g,LOW); digitalWrite(f,HIGH); delay(500); digitalWrite(f,LOW); digitalWrite(e,HIGH); delay(500); digitalWrite(e,LOW); digitalWrite(d,HIGH); delay(500); digitalWrite(d,LOW); digitalWrite(c,HIGH); delay(500); digitalWrite(c,LOW); digitalWrite(b,HIGH); delay(500); digitalWrite(b,LOW); digitalWrite(a,HIGH); delay(500); digitalWrite(a,LOW); }
Learn to use arrays! Learn to use loops! Let the computer do the work for you and save yourself a ton of typing. Haven’t tested it but the following code is probably equivalent, is certainly more compact, and would be easier to maintain going forward.
#define PINCOUNT 6
const int pins[] = {7,8,9,10,11,12};
void setup ()   {
    for(int i=0;i<PINCOUNT;i++)
        pinMode( pins[i], OUTPUT);
void loop ()
        digitalWrite(pins[i], HIGH);
        if( (i-1>0) )
           digitalWrite(pins[i-1], LOW);
          digitalWrite(pins[PINCOUNT-1], LOW);
Good first effort though, you’re on the right track!
PS: There’s a # sign button in the toolbar. Click it and then paste inside the tags it makes for you.
