My dfplayer doesn't work
Hi everyone, I've tried everything to get it working, but my Arduino Nano setup with the DFPlayer simply doesn't work. I don't know what I did wrong. I'm attaching a picture and the code. Please, someone help.
(Problem:1. Please recheck the connection!,2. Please insert the SD card!)
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
SoftwareSerial mySerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
  mySerial.begin(9600);
  Serial.println(F("DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ..."));
  if (!myDFPlayer.begin(mySerial)) {  // Use softwareSerial to communicate with DFPlayer Mini
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1. Please recheck the connection!"));
    Serial.println(F("2. Please insert the SD card!"));
    while (true);
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.volume(30);  // Set volume to maximum (0-30)
  myDFPlayer.play(1);     // Play the first MP3 file
  // No need for code here in this simple test
Welcome to the forum
What does it do ? Are there any messages in the serial monitor ?
Hello!
it says:
"DFPlayer Mini Demo
Unable to begin:
    and A dfplayer LED doesn't light up
It looks like you have 10 and 11 swapped.
Rx should go to TX
Tx should go to RX
If you want to run your DF Player Mini without an Arduino, all you need is VCC, GND and a shorting pin... See "I/O MODE" on this web page...
Watch DFPlayer working!! | Streamable Thank you so much!
That looks like a piece of iron, maybe a vice?
Never rest live circuits on metal surfaces! A short circuit could destroy the DFplayer module in the blink of an eye.
Hello, I just put it there for the picture so that everything would be visible, I was careful about that! (It was turned off when the picture was taken)
Hi! Thanks for the hint. That helped me to make DFPlayer work after 2 hours of debugging. How did you figure out? OP did everything in accordance with the schematics, I believe. I mean RX was connected to D10, which is initialized as RX, and TX to D11, initialized as TX.
It was explained
One sends stuff the other receives.
The other sends stuff the first receives.
a7
