I have code working for my custom game controller, but I want to modify the controller which means adding 2 potentiometers. The code is made for a button matrix and an arduino joystick module. (picture below). The module consists of a potentiometer for each axis so in theory I should be able to remove the current arduino joystick and plug in a potentiometer (linked below) and it should work... Good news is the PC recognizes it without a problem, but the game does not. Does anyone have an idea why this is happening? Both are 10K pots and I know everything is wired correctly because the pot works on the PC, just not in the game.
I have my code posted in case there might be an issue with that, but I don't think that is the culprit. Any guidance would be appreciated. Thanks
#include <Joystick.h>
#define joyButton1 14
#define NUMROWS 3
#define NUMCOLS 2
char buttons[NUMROWS][NUMCOLS] = {
{1,2},
{3,4},
{5,6}
byte rowPins[NUMROWS] = {A0,A1,A2};
byte colPins[NUMCOLS] = {2,3};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(0x03, JOYSTICK_TYPE_JOYSTICK, 7, 0, true, true, false, false, false, false, false, false, false, false, false);
void joylights(int x){
for (int c=0;c<x+1;c++)
Joystick.setButton(1, true);
Joystick.sendState();
Joystick.setButton(1, false);
pinMode(joyButton1, INPUT_PULLUP);
Joystick.begin(false);
delay(5000);
joylights(4);
int thebuttonnumber=0;
Joystick.setXAxis(analogRead(A9));
Joystick.setYAxis(1024 - analogRead(A10));
Joystick.setButton(0, !digitalRead(joyButton1));
if (buttbx.getKeys())
for (int i = 0; i < LIST_MAX; i++) // Scan the whole key list.
if ( buttbx.key[i].stateChanged ) // Only find keys that have changed state.
switch (buttbx.key[i].kstate) {
case PRESSED:
Joystick.setButton(buttbx.key[i].kcode+1, true);
case RELEASED:
Joystick.setButton(buttbx.key[i].kcode+1, false);
