Very nice I will study this code, Do you have anything with a pedestrian puts button? thank you
larryd:
FYI:
You can use Flags to control code execution.
// TrafficLight.ino
// Version YY/MM/DD
// 1.00 20/05/15 Running code
#define enabled true
#define disabled false
#define LEDon HIGH
#define LEDoff LOW
const byte redLED = 5; //+5V----[>|]----[220R]----GND
const byte greenLED = 6;
const byte yellowLED = 7;
const byte heartbeatLED = 13;
bool redFlag = true;
bool greenFlag = false;
bool yellowFlag = false;
unsigned long redMillis;
unsigned long greenMillis;
unsigned long yellowMillis;
unsigned long currentMillis;
unsigned long heartbeatMillis;
const unsigned long redInterval = 5 * 1000ul;
const unsigned long greenInterval = 5 * 1000ul;
const unsigned long yellowInterval = 5 * 1000ul;
// s e t u p ( )
pinMode(redLED, OUTPUT);
digitalWrite(redLED, LEDon);
pinMode(greenLED, OUTPUT);
digitalWrite(greenLED, LEDoff);
pinMode(yellowLED, OUTPUT);
digitalWrite(yellowLED, LEDoff);
pinMode(heartbeatLED, OUTPUT);
} //END of setup()
// l o o p ( )
//save current time
currentMillis = millis();
//to help show if there is any blocking code, this LED toggles every 500ms
if (currentMillis - heartbeatMillis >= 500)
//restart this TIMER
heartbeatMillis = currentMillis;
digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
checkRed();
checkGreen();
checkYellow();
// Other non blocking code goes here
} //END of loop()
// c h e c k R e d ( )
void checkRed()
if (redFlag == enabled && currentMillis - redMillis >= redInterval)
digitalWrite(redLED, LEDoff);
digitalWrite(greenLED, LEDon);
redFlag = disabled;
greenFlag = enabled;
//restart the TIMER
greenMillis = currentMillis;
} //END of checkRed()
// c h e c k G r e e n ( )
void checkGreen()
if (greenFlag == enabled && currentMillis - greenMillis >= greenInterval)
digitalWrite(yellowLED, LEDon);
greenFlag = disabled;
yellowFlag = enabled;
//restart the TIMER
yellowMillis = currentMillis;
} //END of checkGreen()
// c h e c k Y e l l o w ( )
void checkYellow()
if (yellowFlag == enabled && currentMillis - yellowMillis >= yellowInterval)
yellowFlag = disabled;
redFlag = enabled;
//restart the TIMER
redMillis = currentMillis;
} //END of checkYellow()
You can use a State Machine to control code execution:
// TrafficLightStateMachine.ino
// Version YY/MM/DD
#define LEDon HIGH
#define LEDoff LOW
enum STATES {STARTUP, RED, GREEN, YELLOW};
STATES mState = STARTUP;
// s e t u p ( )
} //END of setup()
// l o o p ( )
//save current time
checkTrafficLight();
} //END of loop()
// c h e c k T r a f f i c L i g h t ( )
void checkTrafficLight()
switch (mState)
case STARTUP:
//next State
mState = RED;
//restart the TIMER
case RED:
if (currentMillis - redMillis >= redInterval)
//next State
mState = GREEN;
//restart the TIMER
case GREEN:
if (currentMillis - greenMillis >= greenInterval)
//next State
mState = YELLOW;
//restart the TIMER
case YELLOW:
if (currentMillis - yellowMillis >= yellowInterval)
//next State
mState = RED;
//restart the TIMER
} //END of switch/case
} //END of checkTrafficLight()
