I was sitting on my computer when a strange whim struck me, and I took out some batteries, my (crappy) DMM, and the Single Sided Arduino PCB I have printed out on regular paper (with my injet) for fun. I attached the wires and touched a trace with my DMM, and to my surprise, it showed voltage!
This led to the printing of an accurately labeled line and more testing.
Using a combined total of 14.88 combined battery power (one 9V is dying :P), I discovered:
By placing the + end of the batteries at the 0" mark, and attaching my - DMM lead to the - Battery lead, and the + lead to the 1" spot on the line, the voltage dropped to 2.68 volts (about a 82% drop :O).
But after that initial drop, the voltage only decreases at about 40% each inch.
I know that sounds like a LOT of resistance, but I wasn't expecting this to do anything at all :P. Any clue what in the Ink is causing this phenomenon?
Well there is probably some carbon in the toner/ink that your printer is using. Some resistor pots are still made using carbon for the conductive track. I know that SparkFun sells some linear resistor potentiometers strips that work similar to what you are seeing. Not sure if every brand/model of printer ink could replicate your results, but it could be used in some useful or innovative project.
PS: Before you buy another Arduino board, get a better DMM ;D
Not related to the observed phenomena but maybe interesting for Pracas the paperduino:
I can't really tell what they did. Did they just print out the boards as templates, and then use wires to connect everything (inside the Cardboard)? I feel a "Carduino" coming on...
You may get conductive ink if you mix it (worth a try) with the content of this
The "circuit pen" type conductive ink things tend to be based on powdered silver. Thus the high price
You can make moderately a conductive "paint" with powdered graphite and a variety of paint-like bases, including water-based white glue. There are a couple of "Instructables" on the subject...
