My own library
I would like to create my own library. Since I have used java programming so far, I do not know exactly how the header in C++ works. I tried to google it but it's a big topic.
Can someone advise me why I have a bug "error: expected unqualified-id before 'int'" in the LcdMenu.h???
And what's the problem with the String declaration???
I created it according to this example (https://www.arduino.cc/en/Hacking/LibraryTutorial)
If anyone knew about a tutorial that would be about creating a library, but without wide C++ knowledge
feel free to throw him into the comment.
My heder file
#ifndef LcdMenu
#define LcdMenu
#include <Arduino.h>
class LcdMenu
	public:
		LcdMenu(int _scrNr);
		void addTextLine1(int _scrNr, String _line);
		void addTextLine2(int _scrNr, String _line);
		void addTextLine3(int _scrNr, String _line);
		void addTextLine4(int _scrNr, String _line);
		void setOnOff(int _scrNr, bool _onOff, String _ifTrue, String _ifFalse);
		void setOnOff(int _scrNr, bool _onOff);
		void setValue(int _scrNr, String _text, int _hodnotaI);
		void setValue(int _scrNr, String _text, float _hodnotaF);
		String getLine1(int _scrNr);
		String getLine2(int _scrNr);
		String getLine3(int _scrNr);
		String getLine4(int _scrNr);
		float getValue(int _scrNr);
		float getLastValue(int _scrNr);
	private:
		int scrNr, arrayLenght;
		float value, lastValue;
		bool onOff;
		String line1, line2, line3, line4, ifTrue, ifFalse;
#endif
My cpp file
#include "LcdMenu.h" //include deklaraciu tejto triedy
bool onOff;
String myMenu[][];
//constructor
LcdMenu::LcdMenu(int _scrNr){
	arrayLenght = _scrNr;
	myMenu = new myMenu[arrayLenght][9]; //screen count // 9 = values
	* 0 - onOff
	* 1 - line1
	* 2 - line2
	* 3 - line3
	* 4 - line4
	* 5 - ifTrue
	* 6 - ifFalse
	* 7 - value
	* 8 - lastValue
//destructor
LcdMenu::LcdMenu(int _scrNr){}
void LcdMenu::addTextLine1(int _scrNr, String _line){
	myMenu[scrNr][1] = _line.substring(0,19);
void LcdMenu::addTextLine2(int _scrNr, String _line){
	myMenu[scrNr][2] = _line.substring(0,19);
void LcdMenu::addTextLine3(int _scrNr, String _line){
	myMenu[scrNr][3] = _line.substring(0,19);
void LcdMenu::addTextLine4(int _scrNr, String _line){
	myMenu[scrNr][4] = _line.substring(0,19);
void LcdMenu::setOnOff(int _scrNr, bool _onOff, String _ifTrue, String _ifFalse){
	myMenu[scrNr][0] = _onOff;
	myMenu[scrNr][5] = _ifTrue;
	myMenu[scrNr][6] = _ifFalse;
void LcdMenu::setOnOff(int _scrNr, bool _onOff){
void LcdMenu::setValue(int _scrNr, String _line, int _valueI){
	myMenu[scrNr][3] = _line;
	myMenu[scrNr][8] = myMenu[scrNr][7];
	myMenu[scrNr][7] = _valueI;
void LcdMenu::setValue(int _scrNr, String _line, float _valueF){
	myMenu[scrNr][7] = _valueF;
String LcdMenu::getLine1(int _scrNr){
	return myMenu[scrNr][1];
String LcdMenu::getLine2(int _scrNr){
	return myMenu[scrNr][2];
String LcdMenu::getLine3(int _scrNr){
	return myMenu[scrNr][3];
String LcdMenu::getLine4(int _scrNr){
	return myMenu[scrNr][4];
float LcdMenu::getValue(_scrNr){
	return myMenu[scrNr][7].toFloat();
float LcdMenu::getLasValue(_scrNr){
	return myMenu[scrNr][8].toFloat();
Thank you for your time and help...
#ifndef LcdMenu
#define LcdMenu
Include guards do NOT #define a name that is the same as the class name.
Without knowing which line caused the error? No me. I'm too lazy to recreate the error message you should have posted EXACTLY as the compiler spit it out.
Which one? And why so f**king many question marks. The proper number is ONE!
You should NOT be using Strings AT ALL.
String myMenu[][];
A two dimensional array with zero elements in each dimension ?
Ralph Bacon's library tutorial.
Ok, so I made changes to your suggestions.
PaulS
and Delta_G
preprocessor sees this and says, ok replace every "LcdMenu" with an empty string.
I did not realize it. Thanks
Delta_G i deleted the .cpp declarations and reduced my functions (Good idea with the functions i did not think)
UKHeliBob
I tried to declare the String in a different way because I was getting error with String declaration. It was foolish.
.cpp after change:
//constructor
 String myMenu[arrayLenght][9]; //screen count // 9 = values
 * 0 - onOff
 * 1 - line1
 * 2 - line2
 * 3 - line3
 * 4 - line4
 * 5 - ifTrue
 * 6 - ifFalse
 * 7 - value
 * 8 - lastValue
void LcdMenu::addTextLine(int _scrNr, int lineNr, String _line){
 myMenu[scrNr][lineNr] = _line.substring(0,19);
String LcdMenu::getLine(int _scrNr, int lineNr){
 return myMenu[scrNr][lineNr];
float LcdMenu::getValue(int _scrNr)
	return myMenu[_scrNr][7].toFloat();
float LcdMenu::getLastValue(int _scrNr)
	return myMenu[_scrNr][8].toFloat();
.h after change:
#ifndef Lcd_MenuLib
#define Lcd_MenuLib
#if (ARDUINO >=100)
 #include "Arduino.h"
#else
 #include "WProgram.h"
#endif
class LcdMenu
 public:
 void addTextLine(int _scrNr, int lineNr, String _line);
 String getLine(int _scrNr, int lineNr);
 private:
 bool onOff;
#endif
New error msg:
Arduino: 1.8.4 (Windows 7), Vývojová doska:"Arduino Nano, ATmega328P"
Voľby pre zostavenie sa zmenili, zostavujem všetko znova
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp: In member function 'void LcdMenu::addTextLine(int, int, String)':
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:22:2: error: 'myMenu' was not declared in this scope
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp: In member function 'void LcdMenu::setOnOff(int, bool, String, String)':
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:27:2: error: 'myMenu' was not declared in this scope
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp: In member function 'void LcdMenu::setOnOff(int, bool)':
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:33:2: error: 'myMenu' was not declared in this scope
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp: In member function 'void LcdMenu::setValue(int, String, int)':
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:37:2: error: 'myMenu' was not declared in this scope
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp: In member function 'void LcdMenu::setValue(int, String, float)':
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:43:2: error: 'myMenu' was not declared in this scope
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp: In member function 'String LcdMenu::getLine(int, int)':
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:49:9: error: 'myMenu' was not declared in this scope
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp: At global scope:
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:52:31: error: 'float LcdMenu::getValue' is not a static member of 'class LcdMenu'
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:52:25: error: '_scrNr' was not declared in this scope
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:52:32: error: expected ',' or ';' before '{' token
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:56:34: error: 'float LcdMenu::getLasValue' is not a static member of 'class LcdMenu'
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:56:28: error: '_scrNr' was not declared in this scope
C:\Users\SKHC2629\Documents\Arduino\libraries\LcdMenu\LcdMenu.cpp:56:35: error: expected ',' or ';' before '{' token
exit status 1
Nastala chyba pri kompilácii pre dosku Arduino Nano.
Táto správa by mala mať viac informácií v
"Zobrazenie podrobného výstupu pri kompilácii"
podľa zapnutá voľba v Súbor -> Nastavenia.
PaulS why?
Could you guys even once to look at the current problem please?
Why he does not recognize myMenu?
Thank you so mutch
Tomas309:
PaulS why? Could you guys even once to look at the current problem please?
The problems with the String function are well documented in this forum. Do a little searching
I imagine because you declare / define it as a local variable within the constructor rather than a class member variable.
It is unlikely that the array myMenu should be local to the constructor.
#ifndef Lcd_MenuLib
#define Lcd_MenuLib
The usual convention is className_H.
The addTextLine() method does not recognize myMenu because it is local the constructor. It no longer exists when addTextLine() is called.
PaulS:
0 != 1
But how do I declare myMenu outside of the constructor? When I do not know the arrayLenght until i want to create the class?
I found this example on StackExchange but is it the way to go?
// Declaration
int* myArray = 0;
int myArraySize = 0;
// Allocation (let's suppose size contains some value discovered at runtime,
// e.g. obtained from some external source or through other program logic)
if (myArray != 0) {
    delete [] myArray;
myArray = new int [size];
Thank you
I kind of like dynamic allocation, if used carefully. Others will (properly) warn you about the limited memory available on the basic AVR Arduino boards and the danger of memory fragmentation with repeated new(ing) and delet(ing) -- or malloc(ing) and free(ing).
With the various 32-bit processors in the Arduino ecosystem you have more than 10x the RAM of an UNO, so it’s not quite as bad. But, I’d still avoid excessive allocating and de-allocating.
Caveat: the above is simply my opinion and personal preference. You could also just assign the size statically based on the largest array you think you're going to need.
Why does your LcdMenu constructor take an argument that it doesn't use?
Array indices start at 0, not 1. You are writing outside the bounds of your array. Epic FAIL!
You are STILL using Strings. Epic FAIL!
PaulS:
When I have a constructor without an argument, the compiler throws a error.
I want to write only to array 1-4 if you mean "i" in for loop.
I start to read about the Strings.
I deleted my previous post because I found a mistake in my code... I'll get back to it soon.
Hello again, :slight_smile:
it's done, I used a char[] instead of String with a fixed size of the array(30). But it still does not work for me.
The actual program looks like this:
LcdMenu.cpp
//constructor
LcdMenu::LcdMenu(bool Nothing){
	//arrayLenght = _scrNr;
void LcdMenu::addTextLine(int _scrNr, int _lineNr, char _line[]){
	myMenu[_lineNr][scrNr] = _line;
void LcdMenu::setOnOff(int _scrNr, bool _onOff, char _ifTrue[], char _ifFalse[]){
	myMenu[0][scrNr] = _onOff;
	myMenu[5][scrNr] = _ifTrue;
	myMenu[6][scrNr] = _ifFalse;
void LcdMenu::setValue(int _scrNr, char _line[], int _valueI){
	myMenu[3][scrNr] = _line;
	myMenu[8][scrNr] = myMenu[scrNr][7];
	myMenu[7][scrNr] = _valueI;
void LcdMenu::setValue(int _scrNr, char _line[], float _valueF){
	myMenu[7][scrNr] = _valueF;
char LcdMenu::getLine(int _scrNr, int _lineNr){
	return myMenu[_lineNr][_scrNr];
float LcdMenu::getValue(int _scrNr){
	return atof(myMenu[7][_scrNr]);
float LcdMenu::getLastValue(int _scrNr){
	return atof(myMenu[8][_scrNr]);
LcdMenu.h
#ifndef Lcd_MenuLib
#define Lcd_MenuLib
#if (ARDUINO >=100)
#else
#endif
#define maxMenuCount 30
class LcdMenu
	public:
		//LcdMenu(int _scrNr = 18);
		LcdMenu(bool Nothing=false);
		void addTextLine(int _scrNr, int _lineNr, char _line[]);
		void setOnOff(int _scrNr, bool _onOff, char _ifTrue[], char _ifFalse[]);
		void setValue(int _scrNr, char _text[], int _hodnotaI);
		void setValue(int _scrNr, char _text[], float _hodnotaF);
		char getLine(int _scrNr, int _lineNr);
	private:
		bool onOff;
		char line1[20], line2[20], line3[20], line4[20], ifTrue[20], ifFalse[20];
		char myMenu[9][maxMenuCount]; // 9 = values  //screen count
		* 0 - onOff
		* 1 - line1
		* 2 - line2
		* 3 - line3
		* 4 - line4
		* 5 - ifTrue
		* 6 - ifFalse
		* 7 - value
		* 8 - lastValue
#endif
Testcode
#include <LcdMenu.h>
LcdMenu menu(false);
  delay(200);
  Serial.println("***");
  menu.addTextLine(1,1, "test");
  Serial.println(menu.getLine(1,1));
  delay(5000);
Why the menu.getLine(1,1); does not print something??
That is NOT how to copy data from one array to another. myMenu[_lineNr][scrNr] is a char.
_line[] is an array. You can NOT store an array of chars in a char variable.
OP - For info on manipulating c-strings, take a look at:
http://www.cplusplus.com/reference/cstring/
Ok guys,
Now the code looks like this:
the cpp file
//constructor
LcdMenu::LcdMenu(){
void LcdMenu::addTextLine(int _lineNr, char _line[]){
 //strcpy(myMenu[_lineNr], _line);
 memcpy(myMenu[_lineNr], &_line[0], 19);
void LcdMenu::setOnOff(bool _onOff, char _ifTrue[], char _ifFalse[]){
 onOff = _onOff;
 strcpy(myMenu[5], _ifTrue);
 strcpy(myMenu[6], _ifFalse);
void LcdMenu::setOnOff(bool _onOff){
 onOff = _onOff;
void LcdMenu::setValue(char _line3[], int _valueI){
 strcpy(myMenu[3], _line3);
 lastValueI = valueI;
 valueI = _valueI;
 valueIset = true;
 valueFset = false;
void LcdMenu::setValue(char _line3[], float _valueF){
 lastValueF = valueF;
 valueF = _valueF;
 valueFset = true;
 valueIset = false;
const char* LcdMenu::getLine(int _lineNr){
 if (_lineNr == 4)
 if(strlen(myMenu[5]) > 0 && strlen(myMenu[6]) > 0)
 if(onOff)
 { strcpy(myMenu[4], myMenu[5]); }
 { strcpy(myMenu[4], myMenu[6]); }
 else if(strlen(myMenu[4]) <= 0)
 { //4=min width, 3= precision
 if (valueFset){return dtostrf(valueF,4,2, myMenu[0]);}
 if (valueIset){return dtostrf(valueI,4,0, myMenu[0]);}
 return myMenu[_lineNr];
float LcdMenu::getValueF(){ return valueF;}
float LcdMenu::getLastValueF(){ return valueF;}
int LcdMenu::getValueI(){ return valueI;}
int LcdMenu::getLastValueI(){ return valueI;}
In .h file "define maxMenuCount 21" should I also consider a place for a null character? Or I only have to enter 20
the .h file
#ifndef Lcd_MenuLib
#define Lcd_MenuLib
#if (ARDUINO >=100)
#else
#endif
#define maxMenuCount 21 //+nulcharakter?
class LcdMenu
 public:
 LcdMenu();
 void addTextLine(int _lineNr, char _line[]);
 void setOnOff(bool _onOff, char _ifTrue[], char _ifFalse[]);
 void setOnOff(bool _onOff);
 void setValue(char _line3[], int _hodnotaI);
 void setValue(char _line3[], float _hodnotaF);
 const char* getLine(int _lineNr);
 float getValueF();
 int getValueI();
 float getLastValueF();
 int getLastValueI();
 private:
 float valueI, valueF, lastValueI, lastValueF;
 bool onOff, valueFset, valueIset;
 * 0 - temp
 * 1 - line1
 * 2 - line2
 * 3 - line3
 * 4 - line4
 * 5 - ifTrue
 * 6 - ifFalse
 * 7 -
 * 8 -
#endif
the test sketch
LcdMenu menu();
  delay(200);
  menu.addTextLine(1, "test1 too large text line");
  menu.addTextLine(2, "test2");
  menu.addTextLine(3, "test3");
  //menu.addTextLine(4, "test4");
  //menu.setOnOff(false, "It is true", "It is false");
  menu.setValue("Value :", 10.5f);
  for(int i=1; i<=4;i++)
    Serial.print(i);
    Serial.print(": ");
    Serial.println(menu.getLine(i));
  delay(5000);
See if you can find any improvements. I have only one problem now.
I removed the argument from the constructor of LcdMenu(), the compiler throws out an error:
Arduino: 1.8.4 (Windows 7), Vývojová doska:"Arduino/Genuino Uno"
C:\Users\SKHC2629\Documents\Arduino\HomeAutomationTest\HomeAutomationTest.ino: In function 'void loop()':
HomeAutomationTest:14: error: request for member 'addTextLine' in 'menu', which is of non-class type 'LcdMenu()'
HomeAutomationTest:15: error: request for member 'addTextLine' in 'menu', which is of non-class type 'LcdMenu()'
HomeAutomationTest:16: error: request for member 'addTextLine' in 'menu', which is of non-class type 'LcdMenu()'
HomeAutomationTest:19: error: request for member 'setValue' in 'menu', which is of non-class type 'LcdMenu()'
HomeAutomationTest:25: error: request for member 'getLine' in 'menu', which is of non-class type 'LcdMenu()'
exit status 1
Why? And thanks to all of you for your help...
When I remove the argument from the constructor of LcdMenu(), the compiler throws out an error:
You need to show us THAT code, NOT just try (poorly) to explain what you did.
PaulS:
I edited it.
LcdMenu menu();
Wrong.
LcdMenu menu;
Right.
You were defining a function, menu(), that returned an LcdMenu object, NOT creating an instance of the LcdMenu class.
Thank you, everything is working now.
