I found that PN532 connected to UNO R4 WiFi I2C requires pullups on SCL and SDA
connected PN532 plus 4.7Kohm pullups and I2C scanner reports a device at 0x24
Wire - Wire scanner
---------- Scanning Wire -------------
Scanning...
I2C device found at address 0x24 !
done
---------- Scanning Wire1 ------------
Scanning...
No I2C devices found
the following code
// UNO R4 WiFi I2C PN532 NFC RFID V3 Module
// NOTE: pullups required on SCL and SDA
// Adafruit_PN532 library
// example File>Examples/Adafruit_PN532/readMifareClassic
@file readMifareClassic.pde
@author Adafruit Industries
@license BSD (see license.txt)
This example will wait for any ISO14443A card or tag, and
depending on the size of the UID will attempt to read from it.
If the card has a 4-byte UID it is probably a Mifare
Classic card, and the following steps are taken:
Reads the 4 byte (32 bit) ID of a MiFare Classic card.
Since the classic cards have only 32 bit identifiers you can stick
them in a single variable and use that to compare card ID's as a
number. This doesn't work for ultralight cards that have longer 7
byte IDs!
Note that you need the baud rate to be 115200 because we need to
print out the data and read from the card at the same time!
This is an example sketch for the Adafruit PN532 NFC/RFID breakout boards
This library works with the Adafruit NFC breakout
----> https://www.adafruit.com/products/364
Check out the links above for our tutorials and wiring diagrams
These chips use SPI to communicate, 4 required to interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
// If using the breakout with SPI, define the pins for SPI communication.
#define PN532_SCK (2)
#define PN532_MOSI (3)
#define PN532_SS (4)
#define PN532_MISO (5)
// If using the breakout or shield with I2C, define just the pins connected
// to the IRQ and reset lines. Use the values below (2, 3) for the shield!
#define PN532_IRQ (2)
#define PN532_RESET (3) // Not connected by default on the NFC Shield
// Uncomment just _one_ line below depending on how your breakout or shield
// is connected to the Arduino:
// Use this line for a breakout with a SPI connection:
//Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
// Use this line for a breakout with a hardware SPI connection. Note that
// the PN532 SCK, MOSI, and MISO pins need to be connected to the Arduino's
// hardware SPI SCK, MOSI, and MISO pins. On an Arduino Uno these are
// SCK = 13, MOSI = 11, MISO = 12. The SS line can be any digital IO pin.
//Adafruit_PN532 nfc(PN532_SS);
// Or use this line for a breakout or shield with an I2C connection:
// using UNO R4 WiFi GPIO22 SCL and GPIO21 SDA
Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);//, &Wire1);
void setup(void) {
while (!Serial) delay(10); // for Leonardo/Micro/Zero
Serial.println("Hello I2C!");
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
// Got ok data, print it out!
Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
uint8_t success;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// 'uid' will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
if (success) {
// Display some basic information about the card
Serial.println("Found an ISO14443A card");
Serial.print(" UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
Serial.print(" UID Value: ");
nfc.PrintHex(uid, uidLength);
if (uidLength == 4)
// We probably have a Mifare Classic card ...
uint32_t cardid = uid[0];
cardid <<= 8;
cardid |= uid[1];
cardid <<= 8;
cardid |= uid[2];
cardid <<= 8;
cardid |= uid[3];
Serial.print("Seems to be a Mifare Classic card #");
Serial.println(cardid);
Serial.println("");
delay(2000);
reads RFID tags and serial monitor displays
Hello I2C!
Found chip PN532
Firmware ver. 1.6
UID Length: 4 bytes
UID Value: 0x4E 0x06 0x0C 0x04
Seems to be a Mifare Classic card #1309019140
UID Length: 4 bytes
UID Value: 0xBF 0xEC 0x0C 0x04
Seems to be a Mifare Classic card #3219917828
UID Length: 4 bytes
UID Value: 0xC0 0xFF 0x62 0x1A
Seems to be a Mifare Classic card #3237962266
UID Length: 4 bytes
UID Value: 0xC6 0x47 0xD1 0x05
Seems to be a Mifare Classic card #3326595333
UID Length: 4 bytes
UID Value: 0x15 0x64 0xFD 0xC2
Seems to be a Mifare Classic card #358940098
I connected pullup resistors from 3.3V to A4 SDA and A5 SCL
from arduino-uno-r4-wifi-pinout-reference
It is important to know that the UNO R4 WiFi does not include built-in pull-up resistors on the I2C lines by default. However, there are solder pads available on the board if you want to add them yourself.
EDIT: using a small soldering iron attempted to link the solder pads and failed - they are too small and too far apart
