Hi, im new with arduino. My project is about RFID lock, component that I use is Arduino uno, 12V solenoid lock, and RFID-RC522. Here is my problem when doing this mini project, my RFID only work once and if I do it again the RFID did not detect my card and cannot unlock the solenoid lock. Please help me out from this problem, once I fix this problem I can complete this project.
Could be a programming error. Would you like us to look at your sketch to see if we can spot a problem?
In the meantime, in Preferences, set "Compiler warnings:" to "All" and verify your sketch. Carefully check every line the compiler warns you about.
I bet the problem is either in the software or in the hardware/wiring.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
#define LED_G 5 //define green LED pin
#define LED_R 4 //define red LED
#define RELAY 3 //relay pin
#define BUZZER 2 //buzzer pin
#define ACCESS_DELAY 2000
#define DENIED_DELAY 1000
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
pinMode(LED_G, OUTPUT);
pinMode(LED_R, OUTPUT);
pinMode(RELAY, OUTPUT);
pinMode(BUZZER, OUTPUT);
noTone(BUZZER);
digitalWrite(RELAY, HIGH);
Serial.println("Put your card to the reader...");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == "03 1B 53 1A") //change here the UID of the card/cards that you want to give access
Serial.println("Authorized access");
digitalWrite(RELAY, LOW);
digitalWrite(LED_G, HIGH);
delay(ACCESS_DELAY);
digitalWrite(LED_G, LOW);
else {
Serial.println(" Access denied");
digitalWrite(LED_R, HIGH);
tone(BUZZER, 300);
delay(DENIED_DELAY);
digitalWrite(LED_R, LOW);
noTone(BUZZER);
Preformatted text
this is code that I use
looks like you repeatedly process your "content" message each iteration of loop().
shouldn't this processing only be done when a complete message has been received? and shouldn't the message buffer be cleared during the processing?
If you use the same card twice in a row, is it reported as a 'new card'? In other words, do you get the message "Message : " each time you present the card or only the first time?
only the first time and than the card cannot detect anymore
What happens if you comment this part out?
return;
