Mystery Code
#include <Servo.h>
Servo myservo1, myservo2, myservo3;
unsigned long trun1=1350;
unsigned long trun2=425;
unsigned long tback1=1350;
unsigned long tback2=425;
unsigned long tturn1=900;
unsigned long tturn2=735;
unsigned long trest=100;
unsigned long tclose=100;
unsigned long topen=100;
unsigned long treset=100;
int leftwheel=11;
int rightwheel=10;
int claw=9;
myservo1.attach(leftwheel);
myservo2.attach(rightwheel);
pinMode(leftwheel, OUTPUT);
pinMode(rightwheel, OUTPUT);
myservo3.attach(claw);
pinMode(claw,OUTPUT);
void armreset(unsigned long tym)
unsigned long tnow=millis();
while (millis()-tnow <= tym)
myservo3.write(0);
void armclose(unsigned long tym)
myservo3.write(180);
delay(750);
void armopen(unsigned long tym)
myservo3.write(0);
void forward(unsigned long tym)
myservo1.writeMicroseconds(1700);
myservo2.writeMicroseconds(1300);
void turn1(unsigned long tturn)
unsigned long next=millis();
while (millis()-next <=tturn1)
void turn2(unsigned long tturn)
while (millis()-next <=tturn2)
myservo2.writeMicroseconds(1700);
void rest(unsigned long tym)
unsigned long tnow;
tnow=millis();
while (millis() - tnow <= tym)
myservo1.writeMicroseconds(1500);
myservo2.writeMicroseconds(1500);
void back(unsigned long tym)
myservo1.writeMicroseconds(1300);
void block()
while(millis() > 1)
armreset(treset);
rest(trest);
forward(trun1);
rest(trest);
armclose(tclose);
rest(trest);
turn1(tturn1);
rest(trest);
forward(trun2);
rest(trest);
armopen(topen);
rest(trest);
back(tback2);
rest(trest);
turn2(tturn2);
rest(trest);
back(tback1);
rest(trest);
block();
///Basic line tracker.
#include <Servo.h> // call the Arduino servo library
Servo leftWheel; //Create an object for the left motor of type "servo"
Servo rightWheel; //Create an object for the right motor of type "servo"
Servo gripper; //Create an object for the standard servo
int leftlite = A2;  //Pin used for the left phototransistor
int rightlite = A1; //Pin used for the right phototransistor
int bumppin = 6;  //pin used to light up the big LED
int led=8; // pin used for the LED that flashes at 18 inches
float sa=0; //storage variable a
float sb=0; //storage variable b
float litediff=0; //a variable for light difference
float leftliteval; //a variable for the left light phototransistor
float rightliteval; //a variable for the right phototransistor
int sensorPin = A3;
float dist = 0;
float s = 0;
  leftWheel.attach(12); //syntax for assigning object "leftWheel" to pin 7
  rightWheel.attach(11); //Syntax for assigning object "rightWheel" to pin 4
  gripper.attach(9); //Syntax for assigning the standard servo to pin 8
  pinMode(bumppin,INPUT); // Assigning the biglight to be a digital output
  //gripper.attach(9);
  Serial.begin(9600); // COM speed setup for serial monitor
  pinMode(led,OUTPUT);
  float flipflopL()
  sa = 0;
  for(int i = 1; i <= 25; i++)
    leftliteval = analogRead(leftlite);
   sa = sa + leftliteval;
  leftliteval  = (sa/(1023*5));
return leftliteval;
  float flipflopR()
  sb = 0;
    rightliteval = analogRead(rightlite);
    sb = sb + rightliteval;
  rightliteval = (sb/(1023*5));
return   rightliteval;
void Blink()
 digitalWrite(led,HIGH);
 digitalWrite(led,LOW);
 delay(1);
void Linetrack()
  leftliteval  = flipflopL();//convert to voltage
  rightliteval = flipflopR();  // compute equivalent voltage
  litediff=leftliteval-rightliteval; // Take the difference of the left and right phototransistors
  Serial.print(leftliteval,4); //print the value of the left PT to the serial monitor
  Serial.print("  "); //add a space
  Serial.print(rightliteval,4);  //Print value of right PT
  Serial.println(litediff,4); // display the difference between the two PT
  if (litediff >= 1)//for my set up when the right PT was on black I got a difference of about .080 volts so I picked .06 to be safe will need to tweak in the future
    turnRight(1); //turn right if the right PT is on black
  else if (litediff <=  -2) //I got a value of 0.030 when the left PT was on black so I picked 0.04 this can be tweaked
    turnLeft(1); //turn left if the left PT is on black
  else //otherwise....
    driveForward(1); //go forward
void driveForward(float delta)
    leftWheel.writeMicroseconds(1700);
    rightWheel.writeMicroseconds(1425);
    delay (delta);
void driveBackward(float delta)
 leftWheel.writeMicroseconds(1425);
 rightWheel.writeMicroseconds(1700);
 delay(delta);
void turnLeft(float delta)
    rightWheel.writeMicroseconds(1300);
    leftWheel.writeMicroseconds(1500);
    delay(delta);
void turnRight(float delta)
     rightWheel.writeMicroseconds(1500);
    delay(delta);
void halt(float delta)  //
   delay(delta);
boolean bumpstate()
 return digitalRead(bumppin);
float getdist()
{                                // repeatedly do the following:
  s = 0;  // initialize accumulator
  for(int i = 1; i <= 200; i++)  // get the sum of 50 samples
  s = s + analogRead(sensorPin);  //get bit-equivalent voltage value from input pin
  s=s/200;
  s = (s/1023)*5;          // compute equivalent voltage
  dist = pow(s, -1.154) * 11.44;
Serial.println(dist);
return dist;
void block()
  while(1)
    halt(1);
void start()
  gripper.write(60);
 void END()
  while(millis() > 1)
void grasp()
 gripper.write(0);
void relinquish()
 gripper.write(60);
 grasp();
void forwardTrackDist(int delta)
  while(bumpstate()==LOW  && getdist() > delta)
    Linetrack();
  halt(1);
void forwardBump()
  while(bumpstate()==LOW)
    driveForward(1);
  halt(1);
  start();
  forwardBump();
  grasp();
  driveBackward(900);
  turnLeft(600);// about 85 degrees
  forwardTrackDist(4.2);    //is this distance right?
  relinquish();
  driveBackward(550);       //dont like hard numbers
  turnLeft(1500);            //dont like hard numbers
  driveForward(600);
  forwardTrackDist(6.2);//4.2 set as distance
  Blink();
  driveBackward(1500);  // change time
  turnLeft(2300);  //90 degrees
  driveForward(2500);
  halt(99999);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
int sensorPin = A3;
float dist = 0;
float s = 0;
float flipflopL()
sa = 0;
return leftliteval;
float flipflopR()
sb = 0;
void Blink()
delay(1);
void Linetrack()
delay (delta);
delay(delta);
delay(delta);
delay(delta);
delay(delta);
boolean bumpstate()
float getdist()
s=s/200;
return dist;
void block()
while(1)
halt(1);
void start()
gripper.write(60);
void END()
while(millis() > 1)
void grasp()
gripper.write(0);
void relinquish()
gripper.write(60);
grasp();
Linetrack();
halt(1);
void forwardBump()
driveForward(1);
halt(1);
start();
forwardBump();
grasp();
driveBackward(900);
relinquish();
driveForward(600);
Blink();
driveForward(2500);
halt(99999);
@dougcastellano...
Do not cross-post again.
Please do not use copy-for-forum.
Please use
tags when posting code.
