Hi there. I have been working with some sg90 servo motors. i noticed that some of them are quiet in their operation but some are noisy so i opened them up and found that the ones which had more 'grease' or lubricant were far more quiet. i tried moving some of the grease from one to another and it worked, dramatically reducing the noise of the gears. i have tried in vain to figure out what this grease is. i tried white lithium grease as some had said on various forums, this had no noticeable effect. i also tried this which i was more hopeful of because it looks the same but again, no noticeable effect. i think both of them are not viscous enough. so my question is as im sure it is no surprise; does anyone know what this lubricant is? its the difference between my project being noisy or quiet and so its very important. any help would b much appreciated, thanks!
It’s probably silicon grease . It needs to be compatible with the plastics , some greases will destroy them
I've used Vaseline on a toothpick to lube servo gears. I think it is fairly inert when it comes to plastics.
thanks i will try both of these although is vaseline not too thick?
Vaseline sounds like a poor choice, because it turns into a liquid when it gets warm.
(silicone) "plastic gear grease" is all over ebay.
Leo..
gonadgranny:
gonadgranny I'm currently facing a similar problem, and wondered if you ever found the right grease / another solution to the noise?
Just google servo grease, any good hobby website should stock it.
"(silicone) "plastic gear grease" is all over ebay."
You can get silicone grease at the home improvement stores in the plumbing department.
