Nano 33 BLE sense rev2 - Nano Motor Carrier compatibility
Hi, I'm wondering if the Nano 33 BLE sense rev2 is compatible with the aforementioned motor carrier? Or if this motor carrier is for the Nano 33 IoT only?
I want to start with some simple examples but eventually want to build a small lego car that could be controlled with very simple voice commands.
Thanks for help
I dont own the boards so approach at your own risk but depending on schematichs and pinout diagrams
Nano Motor Controller
IoT Pinout
BLE Pinout
BLE Sense Cheat Sheet This one is a little tricky it says: " Pins D2-D12 and A0-A7 supports PWM (Pulse Width Modulation)." Thus confirming it can be used as digital out pins
Pins A2 A3 A6 A7 are used for bridge control thus it must have digital out capabilities. so yes it should be compatible
my advice is just plug it in a breadboard and use a led and a resistor to make sure it can sufficiently output the required voltage.
Also seems like the pinout namings are different on those so you might need to change the library a tiny bit but shouldnt be that hard
Wish you a life away from the magic smoke
Arda
