Start here:
https://docs.arduino.cc/hardware/nano-r4/
First, let’s check the tech-specs part of that page:
https://docs.arduino.cc/hardware/nano-r4/#tech-specs
UART - 1…
Next, let’s go to page 4 of the handy “datasheet”
https://docs.arduino.cc/resources/datasheets/ABX00142-datasheet.pdf
Note, in Section 2.1, the table of features itemizes “Communication UART (1x)”
(By the way, despite internal references in section 2.8 claiming the info is presented, I could find no indication in this document detailing what pin the RGB LED is on. Another minor deficit, might need raising as a separate post).
Next, go here:
https://docs.arduino.cc/tutorials/nano-r4/user-manual/
scroll down to the multicolour pinout depiction. UART1 is depicted, but no reference for the UART associated with the USB connection…
Next, on the schematic:
you’ll find reference to TXD and RXD, and USB_D_N and USB_D_P…
Next, go back to the user manual for a minute, scroll further to the Digital Pins description, and you’ll find reference to D0 and D1, as “UART” RX and TX (NOT UART1)…
Scroll down to the section on UART communication, and you’ll get a full description of the usage of the TWO UARTs in the device.
That’s as far as I’ve dug, so far. So, yes, I do realize that there are TWO UARTs in play, and that one is dedicated to the USB interface while the other is for the user to use, which sort of clouds the issue, but there are TWO functional UARTs, no question. I would suggest that the documentation is extremely inconsistent if not downright misleading in this regard, leaving anyone with Nano experience(including me) with the impression that there is still only 1 UART, with it’s dual purposes, on the basis of the tables referenced above. It was only when I dug deeper that I found a Serial/Serial1 reference.
A pity, as I’m well on the way to an ATMEGA328PB solution to effect the same upgrade(two UARTs) on my current project; buying several R4s would have been a worthy alternative, saving me time, money, and irritation.
