I recently got the Nano BLE and very much am a beginner at all these things.
I was trying to run a DC motor with the Nano, using the L293D arduino shield as well. This L293D shield is most commonly used for Arduino Uno, but figured if I looked at the pin layouts of the Uno and the Nano and wire appropriately it would be fine. (Refer to the images below for the pin layout diagrams referenced)
I connected one DC motor to just test it out, and used to the code:
#include <AFMotor.h>
AF_DCMotor motor(1, MOTOR12_64KHZ)
void setup(){
motor.setSpeed(200);
motor.run(FORWARD);
motor.run(BACKWARD);
motor.run(RELEASE);
I apologize if the code was copied wrong, but the original website I was referring to can be found here. This is from an Arduino Project hub so I thought it was pretty reliable.
But the error is that when I was trying to compile, I kept getting an error: "motor12_64hz was not declared in this scope." for the line "AF_DCMotor motor(1, MOTOR12_64KHZ)."
I tried to use the built in example code linked with the library, and even that code did not compile correctly.
So I was wondering if anyone knew why this bug is popping up, I've been trying to search around, and couldn't find anything that could fix this bug.
Thanks so much!
