I received an Arduino Nano Matter a couple of days ago and have managed to get it working with a Sparkfun BME280 board providing temperature data, using a modified version of the matter_temp_sensor example. I will say right up front that getting it to connect to Alexa via an Echo 4th Gen serving as a Thread Border Router is tedious and a balky process. Can't blame the Arduino Nano Matter for that; could just be the way the Alexa infrastructure works.
When the matter_temp_sensor example running on the Nano Matter connects to Alexa, it shows two devices: an Arduino hub, and the temperature sensor. Alexa might call them "first device" and "second device" when it initially discovers them, but you can name them something meaningful.
I wanted to use the Arduino Nano Matter + BME280 to report both temperature and humidity through Alexa. Silly me. While the Arduino Nano Matter Silicon Labs examples include matter_humidity_sensor.ino, Alexa has no interface for a humidity sensor per se.
So I thought about what the BME280 can provide. It can report temperature, humidity, dewpoint, and pressure. Well, dewpoint is a temperature. So I modified the matter_temp_sensor.ino example to report two temperatures, thusly:
Matter temperature and dewpoint sensor example
The example shows how to create a temperature and dewpoint sensor with the Arduino Matter API.
The example creates a Matter temperature and dewpoint sensor device and publishes the current
temperature and dewpoint through it.
The device has to be commissioned to a Matter hub first.
Compatible boards:
- Arduino Nano Matter
- SparkFun Thing Plus MGM240P
- xG24 Explorer Kit
- xG24 Dev Kit
Author: Tamas Jozsi (Silicon Labs)
Modified by Chip F. (Just 'Plane Circuits) 16 may 2024 to report temp and DP from a BME280
#include <Matter.h>
#include <MatterTemperature.h>
#include <SparkFunBME280.h>
MatterTemperature matter_temp_sensor1;
MatterTemperature matter_temp_sensor2;
BME280 mySensor; //Uses default I2C address 0x77
void initBME();
Matter.begin();
matter_temp_sensor1.begin();
matter_temp_sensor2.begin();
initBME();
Serial.println("Matter temperature and dewpoint sensor");
if (!Matter.isDeviceCommissioned()) {
Serial.println("Matter device is not commissioned");
Serial.println("Commission it to your Matter hub with the manual pairing code or QR code");
Serial.printf("Manual pairing code: %s\n", Matter.getManualPairingCode().c_str());
Serial.printf("QR code URL: %s\n", Matter.getOnboardingQRCodeUrl().c_str());
while (!Matter.isDeviceCommissioned()) {
delay(200);
Serial.println("Waiting for Thread network...");
while (!Matter.isDeviceThreadConnected()) {
delay(200);
Serial.println("Connected to Thread network");
Serial.println("Waiting for Matter device discovery...");
while (!matter_temp_sensor1.is_online() || !matter_temp_sensor2.is_online()) {
delay(200);
Serial.println("Matter devices are now online");
float current_temp1 = mySensor.readTempC();
float current_temp2 = mySensor.dewPointC();
matter_temp_sensor1.set_measured_value_celsius(current_temp1);
matter_temp_sensor2.set_measured_value_celsius(current_temp2);
Serial.printf("Current temperature: %.02f C\n", current_temp1);
Serial.printf("Current dewpoint: %.02f C\n", current_temp2);
delay(5000);
// Initialize the BME280 sensor
void initBME() {
Wire.begin();
mySensor.setI2CAddress(0x77); //The default for the SparkFun Environmental Combo board is 0x77 (jumper open).
//If you close the jumper it is 0x76
//The I2C address must be set before .begin() otherwise the cal values will fail to load.
if (mySensor.beginI2C() == false) {
Serial.println("BME280 sensor connect failed");
Serial.println("BME280 sensor initialization appears to have succeeded.");
The most urgent problem I'm currently experiencing is that if I move the Nano Matter + BME280 and the Amazon Echo Gen 4 serving as a Thread Border Router from my family room to my garage, the Nano Matter doesn't seem to reliably re-connect to Alexa. When I use the Alexa app on my phone to look at the temperature and dewpoint sensors, Alexa reports that they are connected to Echo Dot devices whose power supplies I unplugged after I moved the Nano Matter. (!!!) Is there a way, using the Silicon Labs-provided software, to detect a faulty Matter connection and re-initialize the connection?
I will also say that compiling simple sketches such as the above for the Arduino Nano Matter using the Arduino IDE is an extremely time-consuming and tedious process. Push the button, go out to lunch kind of tedious. And that's on a Windows 11 machine with 16 GB of RAM and an i7-1195G7 @ 2.90GHz. Makes troubleshooting very time-consuming.
TIA for any constructive comments.
