Nano not seeing ina 226
I was having trouble measuring current in a running sketch using an INA226.
To troubleshoot I bought a new Arduino Nano and a new INA226 breakout board.
I used Rob Tillaert’s demo sketch from GItHub verbatim. It compiled and uploaded fine.
I powered the nano by USB to my PC, running the IDE
I powered the INA 226 with its Vcc connected to the 5V pin of the nano and its GND connected to the GND of the nano.
I connected SDA of the INA226 to A4 and the SCL of the INA226 to pin A5 of the nano.
I got no current readings with in+ and in- connected to active shunt. I tried powering the INA 226 from 3.3 pin and still no connection.
So, I loaded an I2C scanner sketch onto the nano and it runs but finds no devices at any address.
I tried a UNO and a different (new) INA 226 breakout board.
All hardware is new and, I think it is correctly wired.
Any suggestions?
The most common reason is that SDA and SCL are swapped. If that isn't it, post the code and the verbose upload log both in code tags and a photo of a hand-drawn wiring diagram. Label any non-obvious parts.
  1. Here is the sketch:
#include <Wire.h>
  Wire.begin();
  while (!Serial); // Wait for Serial Monitor to open (for boards like Leonardo)
  Serial.println("I2C Scanner");
  byte error, address;
  int count = 0;
  Serial.println("Scanning...");
  for (address = 1; address < 127; address++) {
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0) {
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.print(address, HEX);
      Serial.println(" !");
      count++;
    } else if (error == 4) {
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
  if (count == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("Scan complete\n");
  delay(5000); // Wait 5 seconds before next scan
2) Here is the verbose output for upload:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\aredd\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\aredd\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\aredd\OneDrive\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0403_6001 -ide-version=10818 -build-path C:\Users\aredd\AppData\Local\Temp\arduino_build_55473 -warnings=none -build-cache C:\Users\aredd\AppData\Local\Temp\arduino_cache_573840 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\aredd\OneDrive\Documents\Arduino\i2c_scanner\i2c_scanner.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\aredd\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\aredd\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\aredd\OneDrive\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0403_6001 -ide-version=10818 -build-path C:\Users\aredd\AppData\Local\Temp\arduino_build_55473 -warnings=none -build-cache C:\Users\aredd\AppData\Local\Temp\arduino_cache_573840 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\aredd\OneDrive\Documents\Arduino\i2c_scanner\i2c_scanner.ino
Using board 'nano' from platform in folder: C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\sketch\\i2c_scanner.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\sketch\\i2c_scanner.ino.cpp" -o nul
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\utility\\twi.c" -o nul
Generating function prototypes...
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\sketch\\i2c_scanner.ino.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\sketch\\i2c_scanner.ino.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\sketch\\i2c_scanner.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\libraries\\Wire\\Wire.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\libraries\\Wire\\utility\\twi.c.o"
Compiling core...
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_pulse.S.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_digital.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\WInterrupts.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_pulse.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring.c" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\hooks.c" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\hooks.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_analog.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_shift.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\CDC.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\PluggableUSB.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\IPAddress.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Print.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\Print.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\Stream.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\Tone.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\WMath.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\USBCore.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WString.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\WString.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\abi.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\abi.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\main.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\main.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10818 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\new.cpp" -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\new.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_pulse.S.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\WInterrupts.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\hooks.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_analog.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_digital.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_pulse.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\wiring_shift.c.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\CDC.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\IPAddress.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\PluggableUSB.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\Print.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\Stream.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\Tone.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\USBCore.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\WMath.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\WString.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\abi.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\main.cpp.o"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\core.a" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\core\\new.cpp.o"
Archiving built core (caching) in: C:\Users\aredd\AppData\Local\Temp\arduino_cache_573840\core\core_arduino_avr_nano_cpu_atmega328_c40afd5767b6f69663c2f3b88d87da66.a
Linking everything together...
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473/i2c_scanner.ino.elf" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\sketch\\i2c_scanner.ino.cpp.o" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473/core\\core.a" "-LC:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473" -lm
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473/i2c_scanner.ino.elf" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473/i2c_scanner.ino.eep"
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473/i2c_scanner.ino.elf" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473/i2c_scanner.ino.hex"
Using library Wire at version 1.0 in folder: C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473/i2c_scanner.ino.elf"
Sketch uses 4038 bytes (13%) of program storage space. Maximum is 30720 bytes.
Global variables use 528 bytes (25%) of dynamic memory, leaving 1520 bytes for local variables. Maximum is 2048 bytes.
C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\aredd\AppData\Local\Temp\arduino_build_55473/i2c_scanner.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\aredd\AppData\Local\Temp\arduino_build_55473/i2c_scanner.ino.hex"
avrdude: writing flash (4038 bytes):
Writing | ################################################## | 100% 1.53s
avrdude: 4038 bytes of flash written
avrdude: verifying flash memory against C:\Users\aredd\AppData\Local\Temp\arduino_build_55473/i2c_scanner.ino.hex:
avrdude: load data flash data from input file C:\Users\aredd\AppData\Local\Temp\arduino_build_55473/i2c_scanner.ino.hex:
avrdude: input file C:\Users\aredd\AppData\Local\Temp\arduino_build_55473/i2c_scanner.ino.hex contains 4038 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.37s
avrdude: verifying ...
avrdude: 4038 bytes of flash verified
avrdude done.  Thank you.
Here is verbose output for compiling:
3) Here is verbose output from compiling:
Using cached library dependencies for file: C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Users\aredd\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\utility\twi.c
Compiling sketch...
Using previously compiled file: C:\Users\aredd\AppData\Local\Temp\arduino_build_55473\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\aredd\AppData\Local\Temp\arduino_build_55473\libraries\Wire\utility\twi.c.o
Compiling core...
Using precompiled core: C:\Users\aredd\AppData\Local\Temp\arduino_cache_573840\core\core_arduino_avr_nano_cpu_atmega328_c40afd5767b6f69663c2f3b88d87da66.a
"C:\\Users\\aredd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473/i2c_scanner.ino.elf" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\sketch\\i2c_scanner.ino.cpp.o" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473/..\\arduino_cache_573840\\core\\core_arduino_avr_nano_cpu_atmega328_c40afd5767b6f69663c2f3b88d87da66.a" "-LC:\\Users\\aredd\\AppData\\Local\\Temp\\arduino_build_55473" -lm
I will post requested picture in a moment, separately.
Thank you.
here is hand drawing of circuit. pretty simple.
Thank you.
here is the output:
I2C Scanner
Scanning...
Scanning...
Scanning...
That resistor (shunt) is going to burn up quickly, no?
I was trying to figure that bit of the schematic out myself. And yes, if the negative side of the battery is connected to ground as well, the shunt on the INA226 is going to be glowing in short order.
OP: the INA226 is supposed to be in series with the load, not in parallel.
Edit: the shunt resistor is in the INA226 itself? And can handle up to 15A? Colour me impressed.
Sorry guys. The shunt is a low side shut on the battery ground, measuring the charging current, net of loads. Loads come off the (not shown) positive side of the battery. Also, the shunt is 0.0001 ohms not 0.001 as written. Don’t think that changes anything.
As shown, it's not - as shown, it's a short from battery + to GND.
