NB-IOT Cannot receive response information from the server at real times
I do not understand. ask for advice.
#include <Wire.h>
#include <SoftwareSerial.h>
#include "SSD1306Ascii.h"
#include "SSD1306AsciiWire.h"
#include <PZEM004T.h>
#include <Arduino.h>
#include <ArduinoJson.h>
#include "BC95Udp.h"
#include <Dns.h>
#include <TaskScheduler.h>
void t1Callback();
void t2Callback();
void t3Callback();
void read_s();
void volt();
void watt();
void amp();
void com();
float calBill(float Unit, float ft, bool over_150_Unit_per_month = false) ;
// Config time
int timezone = 7;
// Config bill
#define FIX_FT -15.90
int dst = 0;
unsigned long lastUpdateEnergy = 0, lastUpdateFirebase = 0;
float Power1,Power2,Power3,Power4,Power5;
unsigned long Energy = 0;
//PZEM004T pzem(51, 52); // (RX,TX) connect to TX,RX of PZEM
IPAddress ip(192, 168, 1, 1);
#define I2C_ADDRESS 0x3C
#define RST_PIN -1
SSD1306AsciiWire oled;
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
#include <AltSoftSerial.h>
AltSoftSerial bc95serial;
#elif defined(__AVR_ATmega1280__) || (__AVR_ATmega2560__)
#define bc95serial Serial1
#endif
BC95UDP udpclient;
DNSClient dns;
IPAddress remoteip;
IPAddress remoteip2;
IPAddress remoteip_old;
int x;
int dot = 10;
int ledPin1 = 31;
int ledPin2 = 33;
int ledPin3 = 35;
int ledPin4 = 37;
PZEM004T pzem1(50,51); // (RX,TX) conhhhh6nect to TX,RX of PZEM
PZEM004T pzem2(52,53); // (RX,TX) connect to TX,RX of PZEM
PZEM004T pzem3(10,11); // (RX,TX) connect to TX,RX of PZEM
PZEM004T pzem4(12,13); // (RX,TX) connect to TX,RX of PZEM
PZEM004T pzem5(62,63); // (RX,TX) connect to TX,RX of PZEM
Task t1(3000, TASK_FOREVER, &t1Callback);
Task t3(500, TASK_FOREVER, &t3Callback);
Task t4(100, TASK_FOREVER, &read_s);
Task t2(1000, TASK_FOREVER, &volt);
Task t5(1000, TASK_FOREVER, &watt);
Task t6(1000, TASK_FOREVER, &);
//Task t7(100, TASK_FOREVER, &com);
Scheduler runner;
float p1,p2,p3,p4,p5,i1,i2,i3,i4,i5,w1,w2,w3,w4,w5;
String str;
String stringOne;
uint8_t buff[64];
String head;
String body;
void reboot(){
oled.clear();
oled.setFont(Adafruit5x7);
Serial.print(F("Restrat...."));
oled.setCursor (0, 4);
oled.print("Restart...UDP Setting New IP Address");
setup();
void printHEX(uint8_t *buff, size_t len) {
Serial.println("Request...");
for (int i=0; i<len; i++) {
head = buff[11];
body = buff[15];
Serial.print(buff[i]);
Serial.println("");
if(head == "49"){
if(body == "49"){
digitalWrite(ledPin1, LOW);
}else{
digitalWrite(ledPin1, HIGH);
if(head == "50"){
if(body == "49"){
digitalWrite(ledPin2, LOW);
}else{
digitalWrite(ledPin2, HIGH);
if(head == "51"){
if(body == "49"){
digitalWrite(ledPin3, LOW);
}else{
digitalWrite(ledPin3, HIGH);
if(head == "52"){
if(body == "49"){
digitalWrite(ledPin4, LOW);
}else{
digitalWrite(ledPin4, HIGH);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
Wire.begin();
bc95serial.begin(9600);
BC95.begin(bc95serial);
BC95.reset();
Wire.begin();
Wire.setClock(400000L);
#if RST_PIN >= 0
oled.begin(&Adafruit128x64, I2C_ADDRESS, RST_PIN);
#else // RST_PIN >= 0
oled.begin(&Adafruit128x64, I2C_ADDRESS);
#endif // RST_PIN >= 0
Serial.print(F("Starting"));
while (!BC95.attachNetwork()) {
oled.print("Start");
oled.setCursor (dot*3, 4);
oled.print(".");
Serial.print(".");
dot++;
dns.begin();
dns.getHostByName("myhost", remoteip);
remoteip_old = remoteip;
Serial.print(remoteip);
Serial.print(F("NB-IOT module IP address : "));
Serial.println(BC95.getIPAddress());
udpclient.begin(8053);
udpclient.beginPacket(remoteip, 41239);
oled.print("Connection Success");
runner.init();
runner.addTask(t1);
runner.addTask(t2);
runner.addTask(t3);
runner.addTask(t4);
runner.addTask(t5);
runner.addTask(t6);
//runner.addTask(t7);
t1.enable();
t2.enable();
t3.enable();
t4.enable();
t5.enable();
t6.enable();
//t7.enable();
runner.execute();
void t1Callback() {
dns.getHostByName("myhost", remoteip2);
Serial.print(remoteip_old);
Serial.print("|");
Serial.print(remoteip2);
if(remoteip2 != remoteip_old){
reboot();
}else{
Serial.print("False");
