Nececito ayuda con un rtc 1302
Necesito encender un led con un rtc 20 minutos cada 20 días pero no entiendo cómo funciona, es un rtc 1302
Es lo que tengo pero no entiendo :frowning:
#include <RtcDS1302.h>
ThreeWire myWire(4,5,2);
RtcDS1302 Rtc(myWire);
const int LED_PIN = 6;
bool ledOn = false;
unsigned long timerStart;
const unsigned long TIMER_DURATION = 15 * 60 * 1000;
void setup ()
Serial.begin(57600);
Serial.print("compiled: ");
Serial.print(__DATE__);
Serial.println(__TIME__);
Rtc.Begin();
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
printDateTime(compiled);
if (!Rtc.IsDateTimeValid())
    Serial.println("RTC lost confidence in the DateTime!");
    Rtc.SetDateTime(compiled);
if (Rtc.GetIsWriteProtected())
    Serial.println("RTC was write protected, enabling writing now");
    Rtc.SetIsWriteProtected(false);
if (!Rtc.GetIsRunning())
    Serial.println("RTC was not actively running, starting now");
    Rtc.SetIsRunning(true);
RtcDateTime now = Rtc.GetDateTime();
if (now < compiled)
    Serial.println("RTC is older than compile time!  (Updating DateTime)");
else if (now > compiled)
    Serial.println("RTC is newer than compile time. (this is expected)");
else if (now == compiled)
    Serial.println("RTC is the same as compile time! (not expected but all is fine)");
pinMode(LED_PIN, OUTPUT);
void loop ()
printDateTime(now);
if (now.Hour() == 10 && now.Minute() == 0 && !ledOn)
    ledOn = true;
    digitalWrite(LED_PIN, HIGH);
    timerStart = millis();
    Serial.println("LED on");
if (ledOn && millis() - timerStart >= TIMER_DURATION)
    ledOn = false;
    digitalWrite(LED_PIN, LOW);
    Serial.println("LED off");
if (!now.IsValid())
delay(10000);
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
char datestring[20];
snprintf_P(datestring,
        countof(datestring),
        PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
        dt.Month(),
        dt.Day(),
        dt.Year(),
        dt.Hour(),
        dt.Minute(),
        dt.Second() );
Serial.print(datestring);
Moderador:
Por favor, lee las Normas del foro
1. Edita tu título, usa uno que no tenga justamente lo que se considera un título inútil.
Ver en las normas (punto 5) como poner títulos adecuados.
2. Edita el código usando etiquetas.
Ve a edición, luego selecciona todo el código que has publicado, lo cortas y click en <CODE/>
